Replace my new case fans with my previous fans?
692 (0.12/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x Kingston NV2 2 TB m.2 nVMe (since december 2024), 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
first, im sorry if i posted this in the wrong section, as i wasn't quite sure where to put this..
so. i got a NEW desktop pc with built-in fans; 2x corsair a1225m12s (120mm?), but some while ago, i bought 2 new fans for my OLD pc; 1x noctua nf-S12a pwm 120mm and 1x nf-a14 pwm 140mm.
my question is: should i replace 1 of those a1225m12s in my NEW case with the noctua 120mm from my OLD case, or? (i cant see where in my case i can mount the 140mm...)
note: i cannot figure out the name of my new case, for some reason... tried to look everywhere for a model name or so but none found... but here are 2 pictures of the case and possible places where i can place the 140mm-fan:
any ideas on this?
And what is the problem you're trying to fix?
Yeah you should, the Noctua are better. If the case only has 120mm you could mount the 140 with an adapter https://www.amazon.com/dp/B0043GMY1U/?tag=tec06d-20
View attachment 84935 View attachment 84936
any ideas on this?
If it is the case linked earlier, then you could mount the 140mm fan on the bottom of the case as an intake to create positive pressure, using only the rear 120mm as an exhaust.
I would also move one stick of Ram over so they are both in the same colored slots for Dual Channel for better efficiency.
no problem, really. i was just wondering if i would benefit more by replacing the corsair-fans with noctua-fans. pardon for being unclear on that.
This^^ Are you looking for additional cooling, quieter operation, etc?
And the case looks similar to a Corsair Carbide 200R
https://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
140mm fans will mount in the top if you want to add them there
thanks. i shall see what fits where then.
roger that. i will take a look on that.
many thanks for the tips.
ohh, i didnt even see that difference. my bad. thanks for notifying me on that! learned something new tonight then.
so i should mount the 140mm on the bottom of the case and 120mm on the rear? none on the top then?
yes, it is that corsair case, actually! im impressed how some of you know/notice these things so quickly! :eek:
Well you have the corsair fans, you could put them on top?
The Corsair fans are good fans. No need to replace. No harm though in installing the other fans as well, but I don't think your system needs them.
Your case is a Corsair 200r. Noctua fans are known to be better than most but I believe the ones that came with the case are fine too. It's up to you to decide if you want to replace them.
after mixing and such, i found out that my noctua fans are way more quiet than the corsair ones, so imma use the noctua fans. but, again i got some questions...
is this how my setup should be/look like, where the X'ed areas are places with NO fans (the fan on the right is now removed) and the arrows are showing the air flow. the circled area is my gfx card fan... will this have an impact towards the air flow? should i only have 2 fans, or 3 you reckon?
