- Dec 6, 2018
- 342 (0.17/day)
- Hungary
Processor | i5-9600K |
Motherboard | ASUS Prime Z390-A |
Cooling | Cooler Master Hyper 212 Black Edition PWM |
Memory | G.Skill DDR4 RipjawsV 3200MHz 16GB kit |
Video Card(s) | Asus RTX2060 ROG STRIX GAMING |
Display(s) | Samsung Odyssey G7 27" |
Case | Cooler Master MasterCase H500 |
Power Supply | SUPER FLOWER Leadex Gold 650W |
Mouse | BenQ Zowie FK1+-B |
Keyboard | Cherry KC 1000 |
Software | Win 10 |
Note: I'm not using MSI Afterburner for OC, only for custom fan profiles and temp monitoring
The sound can be described as a distinct HDD write sound, without the mechanical nature. It's a varying toned humming pitch. Sounds a little bit like a fan unnaturally changing speeds so fast that is mechanically impossible, like 3-4 different speeds in a second. Sometimes with 1 second pauses. All the while the fans run normally at an even speed and emit a natural sound.
This noise sounds like a second set of "phantom fans" running in a different realm. That's why I couldn't locate the sound for so long, because the fans emit a normal sound upon sticking my ears to them.
The sound is noticable in Windows, but under load it's quite loud.
I thought, what if a program is trying ot mess with the cards fan speeds? I closed Msi Afterburner and the sound vanished!
I ran Resident Evil 2 at almost max settings and didn't hear anything besides the usual faint(ish) buzz.
Ok, so MSI Afterburner is causing the sound. (I'm using the most recent beta)
What is happening here?
I unticked all the monitoring to no avail. No overclocking going on.
I don't have any installed monitoring software besides ASUS AI suite 3, but it has no conflicting GPU functions.
Any ideas why Afterburner is doing this?
