rtx 3060 gets low fps i think cause of a power cap
baybay
14 (0.11/day)
My RTX 3060 has always gave very low fps and the fps jumps up and down alot GPUZ says its a power cap. idk what to do to fix it ive tried alot of things the past year.
Some pics of info- https://docs.google.com/document/d/1EFuXBRGRABWMePvNo48kVhxkw2e2Cs81vx_0Si3Me8s/edit?usp=sharing
comp specs-
OS- Windows 11
CPU- Intel Core i5-12600K Desktop Processor with Integrated Graphics and 10 (6P+4E) Cores up to 4.9 GHz Unlocked LGA1700 600 Series Chipset 125W
RAM- (x4 sticks 64GB) of Corsair VENGEANCE LPX DDR4 RAM 32GB (2x16GB) 3600MHz CL18 Intel XMP 2.0 Computer Memory - Black (CMK32GX4M2D3600C18)
MB- ASUS TUF Gaming Z690-Plus D4 LGA1700(Intel 12th Gen) ATX motherboard(PCIe 5.0, DDR4,4xM.2/NVMe SSD,14+2 power stages,WiFi 6,2.5Gb LAN,front USB 3.2 Gen 2 Type-C,Thunderbolt 4,ARGB headers)
GPU- MSI Gaming GeForce RTX 3060 12GB 15 Gbps GDRR6 192-Bit HDMI/DP PCIe 4 Torx Twin Fan Ampere OC Graphics Card
PSU- CORSAIR RM850x Fully Modular ATX Power Supply - 80 PLUS Gold - Low-Noise Fan - Zero RPM - Black
SSD- Samsung 870 EVO SATA III SSD 1TB 2.5” Internal Solid State Drive, Upgrade PC or Laptop Memory and Storage for IT Pros, Creators, Everyday Users, MZ-77E1T0B/AM
AIO Pump- CoolerMaster MasterLiquid ML120L RGB V2, Close-Loop AIO CPU Liquid Cooler, Gen3 Dual Chamber Pump, 120mm Radiator, SickleFlow 120 PWM ARGB, AMD Ryzen AM5/AM4, Intel LGA1700/1200 (MLW-D12M-A18PC-R2)
Monitor- ASUS TUF Gaming 27" 1080P Monitor - Full HD, 165Hz (Supports 144Hz), 1ms, Extreme Low Motion Blur, FreeSync Premium, Shadow Boost, Eye Care, HDMI, DisplayPort, Tilt Adjustable - VG277Q1A,Black
1,321 (0.87/day)
How lower is your FPS rate compared to other similar systems?
Is your card working at PCIe x16 or less (post GPU-Z screenshot)?
baybay
14 (0.11/day)
"Better than 48% of all results"
and 3DMARK is running the benchmark test in that pic with the sensors tab
6,960 (1.02/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Video Card(s) ASUS PROART RTX 4070 Ti-Super OC 16GB
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT
Case Lian Li O11 Air Mini
Power Supply Super Flower Leadex Platinum SE 1000W 80+ Platinum White
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
I had great results undervolting my 3060 12GB using MSI Afterburner. The result would be shedding 50 watts of power and it would be able to stay in boost all the time rather than throttling.
In MSI Afterburner, the settings I used was a voltage/boost curve that steeply rose to ~0.950Vcore, boost ~1950 MHz and then was horizontal across. Thats all I did, worked great.
baybay
14 (0.11/day)
This is what mine looks like. Do i just i move those dots one by one like you have yours and is there a easy/faster way to copy yours?
6,960 (1.02/day)
USA
Mouse Zowie EC3-C
Yeah theres a way to move everything as a horizontal line. From what I recall, you move the leftmost point up to where you want it, then click on that point then do shift enter and all the points to the right flatten out. To be quite honest, its really hard to use. All I can say is, don't move them individually unless you get really desperate, it should let you flatten it out with some combination of control or shift or enter. It isn't very intuitive and every time I use it I have to look at the guide I have in a text file:
5,831 (2.96/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
It's a 3060, what do you expect? You're maxing out the GPU load and you're hitting the power limit of the card. That's how boost algorithm works. Either lower the voltage (and probably clocks) or increase power limit (but then you might run into other limits). If you're getting low fps at full clocks, GPU load and while hitting power limit the fault is only one - it's a 3060.
6,960 (1.02/day)
USA
Mouse Zowie EC3-C
I think he just needs to undervolt it. If its like the one I have, both undervolt and overclock can be done simultaneously and the result is it won't throttle.
5,831 (2.96/day)
Poland
But with UV at some point he'll be also trading performance for power.
1,755 (2.67/day)
Brazil
System Name G-Station 1.17 FINAL
Processor AMD Ryzen 7 5700X3D
Motherboard Gigabyte X470 Aorus Gaming 7 Wi-Fi
Cooling DeepCool AK620 Digital
Video Card(s) Sapphire Pulse RX 7900 XTX
Case Thermaltake Level 20 MT
Mouse Razer Viper Ultimate
@Chomiq 3060 that it may be, if his results are below 50% of all similar hardware on 3DMark there should be margin to improve with some tinkering.
Unless I'm misinterpreting, and that's a global 48% (would it be in line with 3060 results?).
@baybay when you ran 3DMark, what score did it give you in comparison to similar hardware?
baybay
14 (0.11/day)
I'm not super computer smart sorry, i saw im hitting a power limit from GPUZ, how do i not do that. I used the OC thing on MSI Afterburner and thats what it put the clocks at, I just want it to run smoothly. not quite sure how/what to do thou
nice okay ill try it out and see how it goes, ty. Ill let you know after a couple matches and a benchmark test
Top 41%
my score-20802
average score-23122
5,831 (2.96/day)
Poland
Unless I'm misinterpreting, and that's a global 48% (which would in line with a 3060?).
Userbenchmark, also:
Are they really?
baybay
14 (0.11/day)
looking at these 3dmark scores, ppl with the same hardward have their cpu clocked at 5200, and their gpu clocks at 2200-2300. wouldnt they be hitting power limits also if not more?
Are they really?
1,755 (2.67/day)
Brazil
Top 41%
my score-20802
average score-23122
3DMark indicates your system is indeed underperforming, but I wouldn't know how to pinpoint the root cause. It may not be only your GPU with untapped potential here.
I'd rather not bother much with Userbenchmark, though. Their methodology is bogus at best, outright maliciously biased at worst.
5.2GHz on the CPU is overclocking. Your 12600K in turbo mode should be hitting 4.9GHz reliably, though. For the GPU, those are overclocked numbers as well (ootb it should hit ~1850MHz when boosting).
Did you look at the highest scoring 12600K/3060 combos?
551 (0.09/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
I can't read your screenshots. I think they are accidentally in farenheit for some reason.
For computers, everyone uses Celcius. 100 Celcius is terrible. 90 C is 90% of terrible. 80 C, is 80% of the way. 60 C, your only 60% of the way to terrible.
Farenheit? 148/212ths of the way? What is that?
Don't be a goof.
5,831 (2.96/day)
Poland
Undervolting by OptimiumTech:
Run your card at default, without the OC curve. See what clocks it reaches at around 95%+ GPU (sustained) load.
Take that clock, follow optimum guide with voltage at around 875 mV and run 3D Mark with GPU-Z active. See if you're still hitting power limits. Worse case you'll have driver crash due to too low voltage.
953 (0.29/day)
System Name The Banshee
Cooling CM Hyper 212 Plus
Memory 16GB 2x8 G.Skill Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2100MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
Your card's working like it supposed to, the numbers look right for a stock 3060.
Top 41%
my score-20802
average score-23122
I would ignore "Average score" because it gets skewed massively by all the bugged scores on the 3DMark leaderboard.
40,677 (6.54/day)
Don't be a goof.
212°F is the same as 100°C, 373.15°K or 671.67°R which is the water boiling point.
32°F is the same as 0°C, 273.15°K, or 491.67°R which is water freezing point.
It is said that water at 125°F can scald a person (51.67°C)
551 (0.09/day)
Pacific Coast
Mouse EVGA TORQ X10
No kidding! Did it take you two weeks to come up with the conversion?
I didn't know we had an unorthodox scientist in here.
The mental math is unnecessary, avoidable, and everyone avoids it. Just because you can use any unit doesn't mean you should.
40,677 (6.54/day)
You flipped your wig there:laugh:
6,960 (1.02/day)
USA
Mouse Zowie EC3-C
Kelvin is the only reasonable temperature unit.
40,677 (6.54/day)
