RTX 3090 FE - Maximum Junction Temperature (TJ Max or Tjunction Max) @ 106C Too much?
106C Memory Temp?
  • Total voters
    29
1,047 (0.16/day)
System Name Beaver's Build
Processor AMD Ryzen 9 5950X
Motherboard Asus ROG Crosshair VIII Hero (WI-FI) - X570
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory - 16-19-19-39
Video Card(s) NVIDIA GeForce RTX 4090 Founders Edition
Storage Inland 1TB NVMe M.2 (Phison E12) / Samsung 950 Pro M.2 NVMe 512G / WD Black 6TB - 256M cache
Display(s) Alienware AW3225QF 32" 4K 240 Hz OLED
Case Fractal Design Design Define R6 USB-C
Audio Device(s) Focusrite 2i4 USB Audio Interface
Power Supply SuperFlower LEADEX TITANIUM 1600W
Mouse Razer DeathAdder V2
Keyboard Razer Cynosa V2 (Membrane)
Software Microsoft Windows 10 Pro x64
Benchmark Scores 3dmark = https://www.3dmark.com/spy/32087054 Cinebench R15 = 4038 Cinebench R20 = 9210
Noticed (without overclocks) that my Memory Temperature hits 106C while randomly gaming, is this enough to be concerned with on a FE - RTX 3090 card?
"104C is still crazy, crazy hot. This article from September sheds some light on what an acceptable/safe temperature might be:"
For reference, Micron rates its GDDR5, GDDR5X and GDDR6 memory chips with a Maximum Junction Temperature (TJ Max or Tjunction Max) of 100C (degrees Celsius). The typical recommended operating temperatures ranges between 0C to 95C. The reading materials on Micron's GDDR6X don't reveal the TJ Max for the new memory chips so there's still a bit of mystery to the topic. According to Igor, the general consent is around 120C before the GDDR6X chips suffer damage. This would mean that the Tjunction value should be set at 105C or up to 110C.
put a noctua fan ont he back of the card and the memory still hot:
1,302 (1.35/day)
Thailand
System Name Shoebox
Processor 3600x
Motherboard Msi b550m Mortar +WiFi
Cooling Cryorig m9
Memory Crucial Ballistix c16 B-die 2x8gb
Video Card(s) Powercolor rx570 4gb
Storage WD black sn750 256gb (OS), crucial mx500 1tb(storage),Hitatchi ?? 7200rpm 500gb(Temp files)
Display(s) Samsung 65" TU7100
Case Zzaw b3
Audio Device(s) Yamaha rx-v363
Power Supply Corsair sf750
Mouse Logitech g300s
Keyboard Custom Skyloong sk64s
Software Windows 11Pro
Many of the rtx cards were pumped out of production at such speeds that QC was almost non existent so many issues with thermal pads and such have come to light if your ok with doing so below is a link to jayztwocents recent video on fixing the issue.
8,253 (1.23/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
the card will throttle at 110 C... i think high memory temps are pretty normal..
trog
40,435 (6.59/day)
Thanks for posting this, I was going to post the same video.
@erek, watch the video
1,047 (0.16/day)
i understand those and seen the video before, but i want to know if the temp is actually typical and expected for FE cards or if my card is way outside the range?
1,302 (1.35/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
As jay stated in the video nvidia's use of their sub standard white thermal pads is a joke your card is overheating like the majority of all the 3080ti's and 3090's with ram chips on the rear of the card. No consumer electronics should run over 100°c.
8,926 (3.36/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Every 3000 series FE model is absolute rubbish as far as VRAM cooling goes. So yes, it's within the expected range of being terrible.
1,302 (1.35/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
That's why ekwb seems to have focused all their new blocks on Fe cards I guess.
40,435 (6.59/day)
Yes it's too hot.
You readily vaporize water over 100°C (212°F)
Do the mods in the video and press on
200 (0.03/day)
You need to repad to fix that.
Thermalright TFX (full spread) on the core.
Follow this template for Gelid extremes for the front side. (one pack 1.5mm, one pack 2mm)
Backside, use Gelid Extreme OR Gelid ultimate 1.5mm (you'll need two packs).
1,047 (0.16/day)
3,449 (0.71/day)
Processor AMD 5900x
Motherboard Asus x570 Strix-E
Cooling Hardware Labs
Memory G.Skill 4000c17 2x16gb
Video Card(s) RTX 3090
Storage Sabrent
Display(s) Samsung G9
Case Phanteks 719
Audio Device(s) Fiio K5 Pro
Power Supply EVGA 1000 P2
Mouse Logitech G600
Keyboard Corsair K95
Here's an ideal use case for justifying a waterblock. Any decent waterblock with a standard backplate will keep junction temps below 90c.
Simpleris
17 (0.02/day)
My Gigabyte 3090, stays easily at 70-80 °C on gaming, barely using 4GB of VRAM. But on deep learning with all VRAM employed and it becomes an oven getting near 90-110 °C after 30-90 minutes of training c: I've read some post on s1 reducing the temps by using fans and heatsinks on the backplate... I should try this.
Edit: My VRAM temps are usally about 10 to 20 °C higher than the GPU temp itself, according to OHM.
ir_cow
3,767 (0.66/day)
USA
I believe the actually rating is up to 105 °C for GDDR6X You can find it on Micron website. Personally over a 100 °C is a real concern for longevity as I noted in my RTX 3070 Ti, RTX 3080 and RTX 3080 Ti in the review coverage I have done.
Slap a waterblock on it, or fix the thermal pads yourself. Who knows how long it will last. GDDR6X has built in ECC so small errors will not pop up or crash the system, but it will give you a performance dip. if the game is memory bandwidth hungry.
3,062 (1.13/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) LG OLED CX48"
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Viper Ultimate
Keyboard Corsair K75
Software win11
The temp rating for GDDR6X is Tcase, while the sensor is reporting Tjunction. Tjunction is around 15C hotter, that means GDDR6X can operate at full speed up to 110C Tjunction (correspond to 95C Tcase), passing 110C Tjunction it will thermal throttle and risk of degradation at 120C (Tjunction)
ir_cow
3,767 (0.66/day)
USA
Hmm the date sheet suggests 95°C Tcase and 105 °C for the Tj. That would be 10°C not 15°C above.
2,204 (0.87/day)
If I had these expensive card, I should be able to afford the best Thermal pads. That's Fujipoly 17W m/k as used on both my Nano cards. Be aware once the pads are fitted never take it apart, It's forever & permanent. Taking the card apart will damage the pads..
3,062 (1.13/day)
Software win11
Data sheet is quoting Tcase for both temp, 95C before thermal throttle and 105C before degradation (110C/120C for Tjunction)
Nvidia set 110C Tjunction as the thermal throttling point in BIOS, at 104C Tjunction the fans are commanded to max speed I think.
But yeah I would rather not see VRAM reach boiling temp at all, who knows the BGA on VRAM might just fail due to high thermal swing (happened to Turing already)
Simpleris
17 (0.02/day)
Could it be possible to underclock(/undervolt?) GPU memory so it reduces temps on it? has anybody tried ever?
3,062 (1.13/day)
Software win11
Yes under intensive workload that stress the memory (DL or mining), it's better to underclock the memory, reducing the power limit and increasing fan speeds as much as you can handle help too.
1,047 (0.16/day)
@ThaiTaffy
so if i just replace the pads on the back that will be a big help?
1,302 (1.35/day)
Thailand
System Name Shoebox
Processor 3600x
Cooling Cryorig m9
Case Zzaw b3
@ThaiTaffy
It's become such a problem with these cards there has been an influx of aftermarket backplates now, personally I would take a look, Many can be had extremely cheap compared to the cost of the cards.
Replace the junk Nvidia pads for gelid or some other quality product and slap some form of cooling backplate on it should cost you less than $60 for the lot which is nothing if you had to replace the whole card if it went up in smoke.
1,047 (0.16/day)
i got it down to a max of 100C so far just be repadding the back VRAM only, re-used all the other thermal pads.
still way too hot, or within acceptable operating parameters at least? (dead of winter though)
3,062 (1.13/day)
Software win11
Been 17 months since 3090 launched and I haven't heard of any large scale VRAM related failure despite many many people mine on their 3090, so i assume you would be fine with VRAM running at 100C.
Though if you want your 3090 to live 5+ years then maybe try to keep VRAM temp below 90C.
1,047 (0.16/day)
5 years would be real extreme, I usually upgrade within 3, so we’ll see. Was incredibly hard to acquire this FE. Lucked out at MSRP via another forum
