Ryzen 2700x OC air cooling and a scratched heatsync base.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Motherboard ASUS x470 prime
Cooling Fans
Memory gskill ripjaw 3200
Video Card(s) Zotac GTX1080 mini
Storage 120Gb OCZ Vertex 2E SSD - 500Gb Games - 1.5tb Storage and Media
Case CM HAF 932
Power Supply Corsair TX750
Software Win 10
#1
Hi all. I've been busting my ass installing and reinstalling my CPU cooler hoping to get better temps than I have been. Maybe my expectations are too high.
I replaced the stock cooler a) because it's really loud when it's effective and b) because I figured I could get more from a massive heatsync. Enter the Cooler Master MA620P. It's huge, It has good fans, and 6 heat pipes vs the 4 pipes on the stock cooler. Not to mention its almost 4x the surface area of the stock cooler.
In the end the temps Im getting arent as good as I expected...
As I remounted the cooler for the 4th time I decided to look closer. I did notice scratch/deformity in the base of the MA620p and I wondering if it's been part of the problem.
I should also mention that I've tried a few different methods of applying the TIM and Ive tried the included CM Master Gel and AS5.
What temps should I expect when running the CPUz stress test or Prime95 Small FFTs?
Here's a photo of the base for consideration.
23,789 (5.69/day)
Likes
7,703
hat
Enthusiast
19,970 (4.53/day)
Likes
4,141
Ohio
Processor i7 2600k :: Athlon II x4 630
Motherboard ASUS P8P67 Pro :: GIgabyte GA-770T-USB3
Cooling Corsair H70 :: Thermaltake Big Typhoon
Memory 2x4GB DDR3 1866 :: 2x1GB DDR3 1333
Video Card(s) 2x PNY GTX1070 :: none
Storage Plextor M5s 128GB, WDC Black 500GB :: Mushkin Enhanced 60GB SSD, WD RE3 1TB
Display(s) Acer P216HL HDMI :: None
Audio Device(s) Onboard - iLive IT153B Soundbar (optical) :: None
Power Supply EVGA 500w 80 Plus :: Wounded Corsair CX600
Benchmark Scores >9000
#3
That scratch looks nasty, but shouldn't really impact performance all that much unless it is deep enough to ruin the heatpipe. What are your before/after temps? Also, note that prime95 is pretty stressful (especially with AVX) so it'll cook your CPU pretty good. Here's two screenshots of coretemp: the first represents what I'd call "normal" load. It's just WCG at 100%. The second is prime95 (avx). Notice the ~30w higher power consumption and higher temps.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#4
Admittedly, I wasnt that thorough with recording before temps but I was monitoring them onscreen while gaming and benching. I can tell you what Im seeing now temp wise and it's only ~4-5c better than the stock cooler. Ignoring prime95 results... Running Cinebench @ 4.2 Ghz 1.35v I hit 85c and CPUz stress test looks to hit around the same.
23,789 (5.69/day)
Likes
7,703
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#6
2,181 (1.55/day)
Likes
1,829
On The Highway To Hell \m/
#7
That'd be a big fat...NON-ISSUE...in my book. I mean...I probably wouldn't like it...but I'd get over the thought of it pretty quick. Because I'd bet it makes no measurable/observable difference whatsoever in terms of cooling performance. Shit...the surface finish on those pipes is HORRID anyway. Not that that matters too much either. But that little scratch can't be making things too much worse. Use some top of the line TIM and forget it.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#8
I agree, the finish quality of the whole base is quite poor.
hat
Enthusiast
19,970 (4.53/day)
Likes
4,141
Ohio
#9
What stock cooler, wraithripper? It's supposed to be quite good, but not sure how good exactly... I haven't seen any test that compares it to other coolers. Still, 85c is kinda scary... especially when we're talking cpuz "stress test" which doesn't push my system any harder than WCG, so even prime95 produces higher temps.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#10
Wraith Prism? Its not bad, just loud.
hat
Enthusiast
19,970 (4.53/day)
Likes
4,141
Ohio
#11
It doesn't look like it should only be 5c better than the Wraith Prism. Maybe the old cooler was throttling? IIRC, 4.2GHz @ 1.35v is quite a lot for these chips...
2,523 (1.15/day)
Likes
2,154
Jyväskylä, Finland
Processor AMD Phenom II X4 955 BE @ 3.8/2.42GHz
Motherboard Asus M3N78 SE
Cooling Watercooled
Memory 4GB DDR2-800 5-5-5-12
Video Card(s) Gigabyte GTX 780 @ 1202/1750
Storage 256GB SSD + 500GB HDD + 2TB HDD
Display(s) 3x 1920x1080
Case Corsair Carbide Air 740
Power Supply Super Flower Golden Green 500W
Mouse Logitech G400s
Keyboard Logitech G410
Benchmark Scores TS: 5128, FS: 14018
#12
A scratch doesn't matter much, if not at all. Never seen a direct touch heatsink to be lapped, those have always less or more scratches, that's not the problem.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#13
@hat No thottling on either cooler. I should mention my clocks were locked across all cores. No boosting of any nature. From what I've read some people and sites are needing 1.42v+ for anything over 4.2. I dont even think mines stable until 1.37v at 4.2. The gamers nexus article about Ryzens vcore to clock scaling is a good read.
1,475 (1.48/day)
Likes
1,623
AK, USA
Processor Ryzen 5 2600X
Motherboard MSI B350M Gaming Pro
Cooling Scythe Kotetsu with AM4 bracket
Memory PNY Anarchy-X XLR8 Red DDR4 3200 MHz C15-17-17-17-35
Video Card(s) XFX RS RX 480 GPU @ 1288 MHz - 1.040 mV from 1.175 | GDDR5 @ 2075 MHz
Storage Samsung 850 EVO 250 GB, SanDisk Ultra II 480 GB
Display(s) IP2362 OCed refresh rate - 76Hz (Freesync supported over HDMI with CRU)
Audio Device(s) Realtek ALC887 (dead)
Power Supply EVGA 850 BQ
Mouse Kingston HyperX Pulsefire FPS
Keyboard Logitech K520
Software Windows 10 Professional 64-bit
#14
My Hyper 212+ had a nice sized gouge into one of the middle heatpipes and lapping looked as well done as OP.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#15
Looks like my last effort remounting the HS is producing better results but I need to test more before I decide to keep this unit or dump it for a 240/280 Aio.
I clocked down to 4ghz 1.29v and despit not breaking 55c while playing Destiny (fairly CPU intensive) I still feel like the heat from CPU isn't transferring to the HS very well, or as well as I hoped.
23,789 (5.69/day)
Likes
7,703
#16
The direct contact units tend to be uneven. Better to have a base plate model
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#17
You mean direct contact to the heat pipes vs having a solid block mounted to the his?
23,789 (5.69/day)
Likes
7,703
#18
Solid block tends to stay even. Look at my cooler for example.
3,987 (2.01/day)
Likes
2,414
USA
#19
@TRIPTEX_CAN
If it were me, I'd get some 2000 grit sand paper and lap the bottom of it. However as is, it should not allow the CPU to get above the high 70's under load without an OC, unless your case has bad airflow, which based on your specs, it shouldn't. With your above stated OC, only liquid cooling is going to keep those temps below 80c under load. Drop your OC to 4GHZ and the voltage shouldn't need to go higher than 1.3ish volts which will drop your temps a decent margin.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#20
@lexluthermiester Thanks, I'll probably do that if I do decide to keep it.
Update: 4000mhz 1.3v, i ran prim95 small fft until temps leveled out and at stayed at 70c. I guess i cant say im disappointed with that. Ill be lapping the base anyway since its terrible looking. I cant imagine that it wont help even a little.
hat
Enthusiast
19,970 (4.53/day)
Likes
4,141
Ohio
#21
Be careful lapping HDT coolers. The pipes are thin and lapping them only makes them thinner... potentially not good things could happen.
3,987 (2.01/day)
Likes
2,414
USA
#22
This is true, special care is required. However, with 2000grit sandpaper it should be ok.
hat
Enthusiast
19,970 (4.53/day)
Likes
4,141
Ohio
#23
You won't be taking very much off with 2000 grit either, though... so it could still be quite scratchy.
3,367 (0.85/day)
Likes
737
BC.CAN
Processor 2700x
Cooling Fans
Case CM HAF 932
Software Win 10
#24
I figured from the depth of that gouge without actually having penetrated the pipe there must be some thickness to the wall there either way even a minor superficial shining can be an improvement to that surface.
3,987 (2.01/day)
Likes
2,414
USA
#25
If it's done with a wetting agent like water or a mild oil, 2000grit work really well. It just takes longer than 1500 grit would.
That's what I was thinking too. Then again that gouge goes at an angle through the pipe so it might not be as thick as it appears.
