Ryzen 3950X Build Help
618 (0.13/day)
System Name Beaver's Build
Processor AMD Ryzen 9 3950X 3.5 GHz 16-Core
Motherboard Asus ROG Crosshair VIII Hero (WI-FI) - X570
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory - 16-19-19-39
Video Card(s) NVIDIA GeForce RTX 2080 Ti Founders Edition
Storage Inland 1TB NVMe M.2 (Phison E12) / Samsung 950 Pro M.2 NVMe 512G / WD Black 6TB - 256M cache
Display(s) LG - 27UD68-P 27.0" 3840x2160 60 Hz - FreeSync 1 / IPS
Case Fractal Design Design Define R6 USB-C
Audio Device(s) ROG SupremeFX 8-Channel HDA - ESS® ES9023P
Power Supply Corsair AX1200
Mouse Logitech G3
Keyboard Logitech K120
Software Microsoft Windows 10 Pro x64
Benchmark Scores 3dMark = https://www.3dmark.com/3dm/41362044? Cinebench R15 = 4038 Cinebench R20 = 9210
Someone over here is mentioning the B-die :
Aluminum said:
In roughly ascending order of B-die bin quality but also accounting for ~3600 being a great speed to optimize timings and keep 1:1 ratio on Zen2:
3200C14-14-14 8GB
3600C16-16-16 8GB
3200C14-14-14 16GB
3600C15-15-15 8GB
Non B-die will have inferior timings (this is an objective fact despite people wanting other ram IC to be "as good", they are not) but will be cheaper. You don't seem to be doing a budget build though
also E-die mentioned
r/Amd -How does micron E-die fare for memory overclocking?
4,638 (0.84/day)
Formosa
System Name Overlord Mk MXVI
Processor AMD Ryzen 7 3800X
Cooling Corsair H115i Pro
Memory 32GB Viper Steel 3600 DDR4 @ 3800MHz 16-19-16-19-36
Video Card(s) Gigabyte RTX 2080 Gaming OC 8G
Storage 1TB WD Black NVMe (2018), 2TB Viper VPN100, 1TB WD Blue 3D NAND
Display(s) Asus PG27AQ
Case Corsair Carbide 275Q
Power Supply Corsair RM750
Mouse Logitech G500s
Keyboard Wooting Two
Benchmark Scores https://valid.x86.fr/ztiub6
Yes, Samsung B-die has been good with Ryzen 1000 and 2000, but it seems like people are having a bit more hit and miss luck with it, so far, on Ryzen 3000.
I got the Hynix CJR by chance, but it has worked out well.
You can also have a look here at some Kingston modules with Hynix CJR. Might need some Google translate help though.
Someone in another thread were having major issues with Micron E-die memory, with 3600MHz rated modules that are having none of it with his 3900X.
Also, keep in mind that anything above 3600MHz 1:1 with the IF bus, might not work. It will depend on the board and your luck in the silicon lottery. Apparently I lucked out as far as the IF bus on my CPU goes.
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Motherboard ASRock Taichi X570
Cooling Water
Memory 32GB GSkill CL16 3600mhz
Video Card(s) Vega 56
Storage 2 x AData XPG 8200 Pro 1TB
Display(s) 3440 x 1440
Case Thermaltake Tower 900
Power Supply Seasonic Prime Ultra Platinum
More like 1-5% improvement by the review I linked. I personally bought fast memory because cpu speed is important to the workloads I do. I bought a 3600mhz Cas 18 kit and overclocked it to Cas 16.
Take a look at the 720 gaming benchmarks where cpu and ram become more important.
Another $100 could be a month of food for someone. It just depends.
If people are concerned that $100 spent on a ram upgrade will prevent them from eating for a month, perhaps a 3950X and 2080TI build wasn't the most prudent thing, eh? I doubt this build would help their situation in that regard would it?
That $100 is a fraction of the build cost.
5,883 (1.91/day)
Processor Ryzen 3900x
Motherboard Asrock X570m PRO4
Cooling Scythe Mugen 5 Rev B with push pull fans
Memory Corsair 4x8gb 3533mhz Cas 16
Video Card(s) EVGA 1060 3gb
Storage Adata SX8200 1tb
Display(s) Asus 144hz
Case Fractal Design Something
Power Supply XFX 850w
Software Windows 10 64 Bit
$100 here and there adds up.
Toothless
Tech, Games, and TPU!
5,995 (2.88/day)
Washington, USA
System Name Volt // Dualie
Processor i7-4790k // E5-2680v2 x2
Motherboard MSI Z97 MPower // S2600IP4
Cooling NZXT Kraken X60 // Hyper 212 x2
Memory G.Skill Ripjaws 4x8GB // 16x4GB ECC
Video Card(s) MSI GTX1080 Ti Gaming X // GTX 750TI
Storage 250GB NVME boot + 250GB SSD + 5 HDDs // 240GB SSD + 300GB HDD
Display(s) LG 34UB88-P + 2x AOC 2425W + Dell 2007FP // Dell 2007FP
Case Nanoxia Deep Silence 6 // Gutted case
Audio Device(s) LucidSound LS30 // None
Power Supply Rosewill Fortress 750w // EVGA NEX650G
Mouse Logitech G602 // IBM J85845R
Keyboard G.Skill KM780 RGB (Brown switches) // Logitech M100
Software Windows 10 Professional // Windows 10 Professional
Benchmark Scores Technical term is PEBCAK issue, which stands for Problem Exists Between Chair And Keyboard
Who is gonna game at 720p with a build that has a 38xx/39xx in it?
618 (0.13/day)
Mouse Logitech G3
Seems to be more than $100 difference ...
CORSAIR VENGEANCE RGB PRO 32GB (4x8GB) DDR4 3600MHz C18 is $280
G.SKILL Trident Z Neo (For AMD Ryzen) Series 16GB (2 x 8GB) 288-Pin RGB DDR4 SDRAM DDR4 3600 (PC4 28800) is $280 (double the price for 32GB @ CL14)
Toothless
5,995 (2.88/day)
Washington, USA
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
Clearly nobody. But that isn't the point of the benchmark.
222 (1.54/day)
System Name Temp SFF Rig :'(
Processor Q9550
Motherboard HP OEM
Cooling just about...
Memory 8GB DDR2 :rockout:
Video Card(s) Gigabyte GT 1030 LP OC to 1850+ Boost!!!
Storage 120GB SSD & 160GB HDD :(
Display(s) Acer ED242QR - 24" Curved 1080p 75Hz Freesync
Case HP SFF Desktop
Power Supply HP SFF 260w
Software Windows 10 1903
Heres a set of 720p gaming benchmarks... BUT....... that's not the point of them.... muahaha (evil laugh) bonus points if you can work out what they really mean? o_O
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
Cheese and rice. Right from the article initially linked:
Game Tests: 720p
The low resolution of 720p serves to highlight memory performance differences because games are extremely CPU/memory-limited at this resolution. The CPU will run as fast as it can, and will almost never have to wait on the GPU to complete a frame.
Don't like the test? Take it up with @W1zzard
222 (1.54/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
I've no issue with what is written, however it is still at the end of the day 720p gaming benchmarks and real world benches for other applications don't behave this way so who gives a flying hoot if AMD is slower at 720p gaming I understand what W1zzard wrote, it still doesnt represent any other real world scenario other than 720p gaming, I think it highlights more if anything that most games are/were written or perform better on Intel CPU's/compilers and nothing else. Go look at the other tests and aside from a few that favour Intel it's fairly balanced and representitive of real world usage. It is still only representitive of 720p gaming and you said it wasn't? I know I have repeated myself a few times, hopefully it sinks in, the point that I'm trying to make though and it's not just me being douchey for the sake of it :p
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
I've no issue with what is written, however it is still at the end of the day 720p gaming benchmarks and real world benches for other applications don't behave this way so who gives a flying hoot if AMD is slower at 720p gaming I understand what W1zzard wrote, it still doesnt represent any other real world scenario other than 720p gaming, I think it highlights more if anything that most games are/were written geared towards Intel CPU's/compilers and nothing else. Go look at the other tests and aside from a few that favour Intel it's fairly balanced and representitive of real world usage. It is still only representitive of 720p gaming and you said it wasn't? I know I have repeated myself a few times, hopefully it sinks in, the point that I'm trying to make though and it's not just me being douchey for the sake of it :p
Again, the point of the test is not 720P gaming. The point is to create massive amounts of work for the cpu and memory. You can pick any other workload you want that is not dependent on storage or gpu. 720P gaming tests easy to generate and reproduce, especially games with repeatable benchmarks.
Forget about 720P Gaming in the headline and read it for what it is.
222 (1.54/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
real world tests that are not gaming dont do this was my point, they dont show the same discrepencies, this is a limited scenario so it doesnt really matter unless of course you are gaming on a $600 CPU with $60 RAM on a 2007 monitor
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
My my, isn't that exactly what the OP intends to do?
Edit:
Not sure where the OP is, but here is cl14 3200 for $240: https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232218
Edit 2:
Or cl16 3600 for $210: https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232861?Item=N82E16820232861
Edit 3:
The cheapest 3600 (cl19) is on sale for $140. So for $70 more you can get a good set of memory. Considering the OP will have about $2000 in CPU/GPU alone, I fail to see the reasoning not to do it.
222 (1.54/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
Edit:
no iirc it was 3000/3200 CL16 RAM that for all you know can run CL 14 and maybe clock up to 3400/3600, I bought 3000mhz CL16 RAM that overclocked to 3333 CL14 for $75, he simply stated native CL14 RAM was twice as expensive where he is from for very little benefit according to W1zzards review also, nowhere was it mentioned he planned to game on a 720p monitor considering he has a 2080 Ti as well, well done for part editing my quote to make yourself look good though :clap:
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
Good lord. What is it with the 720P? The OP isn't likely to game on a 1080P monitor with that 2080ti either. If they did, it would be an epic waste of money all the way around.
222 (1.54/day)
Processor Q9550
Motherboard HP OEM
Case HP SFF Desktop
Nothing. Apart from that was whole basis of your so-called point :kookoo:
5,883 (1.91/day)
2,358 (1.36/day)
System Name Wut?
Processor 3900X
Cooling Water
Are you purposefully being thick? The whole basis of my point has nothing to do with gaming on a 720P monitor. It was all about memory limited applications. I fail to see the reason to spend about $3000 on a build and then complain about less than $100.
In any point, this is going no where. The OP can buy top shelf components everywhere else and skimp on the memory all the OP wants. For $70, they can guarantee good specs and be done with it. It doesn't affect my gaming from here so have a nice day.
5,883 (1.91/day)
How many people frequently use programs that are limited by memory performance? It isn't a common problem.
I think it is entirely justifiable to skimp on memory. Those $100 additions add up over time, and maybe that $100 would better serve you in a retirement portfolio. Whatever his reason, he has made that decision.
618 (0.13/day)
Mouse Logitech G3
274 (1.05/day)
Denmark - Aarhus
System Name Iglo
Processor Intel® Core™ i7-3770K CPU @ 3.50GHz OC to 4000 mhz (Ivy Brigde)
Motherboard Asrock Z77 Extreme 9 Socket 1155 LGA
Cooling 240 mm water
Memory 16 gb 2600 mhz ddr3
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage Ssd ´s in raid.
Display(s) BenQ XL2420Z
Case corsair obsidian 650d
Audio Device(s) Logitech Z-2300 THX-Certified 2.1 Speaker
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse G900
Keyboard Hyper x
Software win 10
Benchmark Scores Super-PI 1M Time : 9,265 sec CPU-Z scores Version 2017.1 (x64) S-T 395 M-T 1945
579 (1.27/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
Yeah, been known for a September release
i'm just looking for motherboard / ram advice toward the build at the moment. Considering the Crosshair VIII Hero for the motherboard, but up for any recommendations
Unless you plan on keeping your current system up and running I would try the ram you already have first and see if you can tighten the timings up with the Dram Calculator.
And if that doesn't work out only then would I grab something like this.
I think sticking with 2 dimms is your best bet as the majority of people I see having issues with memory on ryzen 3000 have 4 dimms.
418 (0.16/day)
Babylon 5
System Name DaBeast! DaBeast2! HTPC
Processor AMD AM4 Ryzen 9 3900X/Intel LGA2011 i7 3960X/LGA 1150 i7 4770K
Motherboard Gigabyte X570 Aorus Xtreme/Asus ROG Rampage IV Extreme/ASRock Z87 Extreme6
Cooling Thermaltake Water 3.0 360/Corsair H150i Pro/Thermaltake Floe Riing 360
Memory 32GB XPG D60G DDR4 3200/DDR3 2133Mhz Corsair Dominator Plat/RipJawsX 16GB 1600Mhz
Video Card(s) PowerColor Vega 64 Red Devil/CF 2x Gigabyte RX VEGA 64 Gaming OC/Leadtek GTX 1080
Storage 256GB Sabrent Rocket NVMe M.2 + 2TB 860 QVO + 4TB 860 EVO + 2x 1TB 850 EVO + 6TB WD Black HDD
Display(s) Acer XR341CK 75Hz Freesync/Samsung LC49HG90DMEX 32:9 Freesync 2/Panasonic 65" UHD TV
Case CoolerMaster H500M/Caselabs Magnum M8/Tt View 31
Audio Device(s) Oppo HA-1 + Philips Fidelio HTL9100/iFi Micro iDSD Black Label/Fostex HPA4
Power Supply Corsair HX1000 Platinum/Seasonic X-1250/Enermax MaxRevo 1500W
Mouse Tecware Vector Pro/Logitech G703I/Logitech G603 WL
Keyboard Armaggeddon MKA-5R RGB Hornet/Logitech G613/Logitech K345
Software 64bit Win10 Pro/64bit Win10 Pro/64bit Win10 Pro
Aw shoot! When I'd read the thread title, I'd thought the 3950X was already released!o_O My philosophy is, IF you're willing to pony up all that cash for a high end CPU, why scrimp on everything else? IF OP wanna build a kickbutt rig and go all out, why not? I'm always willing to help others spend an inordinate amount of dinero on their builds.:pimp:
