Ryzen 3950X Build Help
618 (0.13/day)
System Name Beaver's Build
Processor AMD Ryzen 9 3950X 3.5 GHz 16-Core
Motherboard Asus ROG Crosshair VIII Hero (WI-FI) - X570
Cooling Corsair H115i RGB PLATINUM 97 CFM Liquid
Memory G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 Memory - 16-19-19-39
Video Card(s) NVIDIA GeForce RTX 2080 Ti Founders Edition
Storage Inland 1TB NVMe M.2 (Phison E12) / Samsung 950 Pro M.2 NVMe 512G / WD Black 6TB - 256M cache
Display(s) LG - 27UD68-P 27.0" 3840x2160 60 Hz - FreeSync 1 / IPS
Case Fractal Design Design Define R6 USB-C
Audio Device(s) ROG SupremeFX 8-Channel HDA - ESS® ES9023P
Power Supply Corsair AX1200
Mouse Logitech G3
Keyboard Logitech K120
Software Microsoft Windows 10 Pro x64
Benchmark Scores 3dMark = https://www.3dmark.com/3dm/41362044? Cinebench R15 = 4038 Cinebench R20 = 9210
Unless you plan on keeping your current system up and running I would try the ram you already have first and see if you can tighten the timings up with the Dram Calculator.
And if that doesn't work out only then would I grab something like this.
I think sticking with 2 dimms is your best bet as the majority of people I see having issues with memory on ryzen 3000 have 4 dimms.
what about CL14 2x16GB G.SKILL Trident Z Neo? that's what we really need, right?
130939
5,884 (1.90/day)
Processor Ryzen 3900x
Motherboard Asrock X570m PRO4
Cooling Scythe Mugen 5 Rev B with push pull fans
Memory Corsair 4x8gb 3533mhz Cas 16
Video Card(s) EVGA 1060 3gb
Storage Adata SX8200 1tb
Display(s) Asus 144hz
Case Fractal Design Something
Power Supply XFX 850w
Software Windows 10 64 Bit
If you want the best of the best...
587 (1.28/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3800 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
They don't come in 16GB dimms. I would also recommend the 3200 CL14 16GBx2 the performance difference if any is going to be small.
Again this is only if your memory either doesn't work or you can't get tight timings with it. I would definitely stick with Samsung Bdie regardless of what kit you choose to purchase.
618 (0.13/day)
Mouse Logitech G3
My current kit is 4x8GB 2400 MHz CL16 ... (Crucial Ballistix Sport 32GB Kit (8GBx4) DDR4 2400 MT/s (PC4-19200) CL16 DR x8 Unbuffered DIMM 288-Pin Memory BLS4K8G4D240FSA )
587 (1.28/day)
California
The goal would be to get it to around 3000mhz with decent timings.. I would definitely give that a shot first before spending $2-300 on memory.
Worst case scenario you have to buy an awesome kit of ram for your new 16 core CPU.
618 (0.13/day)
Mouse Logitech G3
heh with those Trident Z Neos it'd be closer to $600 :(
CL14 4x8GB 3600 MHz = ~ 580 USD
587 (1.28/day)
California
That kit would definitely not be worth the money.....
over this
or this
Given the choice I would stay away from 4 dimms and go with 2x16gb of 3600 16-16-16-36
4,652 (0.84/day)
Formosa
System Name Overlord Mk MXVI
Processor AMD Ryzen 7 3800X
Cooling Corsair H115i Pro
Memory 32GB Viper Steel 3600 DDR4 @ 3800MHz 16-19-16-19-36
Video Card(s) Gigabyte RTX 2080 Gaming OC 8G
Storage 1TB WD Black NVMe (2018), 2TB Viper VPN100, 1TB WD Blue 3D NAND
Display(s) Asus PG27AQ
Case Corsair Carbide 275Q
Power Supply Corsair RM750
Mouse Logitech G500s
Keyboard Wooting Two
Benchmark Scores https://valid.x86.fr/ztiub6
I'm just going to throw this out there, since we're discussing RAM here...
It seems like an odd conclusion though, but apparently four DIMMs are faster...
I'd like to see some testing from other sites on this as well, as I'm not convinced.
66 (0.65/day)
Processor Ryzen 9 3900X
Motherboard Gigabyte X570 Aorus Xtreme
Cooling Wraith Prism lol
Memory Ballistix Elite (Micron E-die) 3733 CL 16-18-18-18-64 1.48V
Video Card(s) (Waiting for my card to arrive) GT 705 I ripped outta a old Dell somewhere
Storage Samsung 970 Evo
Display(s) A old Dell 1080p 60Hz
Case NZXT H710i
Mouse Razer Deathadder ELite
Keyboard Razer Huntsman Elite
This is my $89 (equivalent local price converted) RAM. It's running way beyond my expectations and rated spec.
This is on a 3800X though, so you'd get higher writes on a 3900X or a 3950X.
Just FYI, a lot of people have reported having issues with Corsair RAM and Ryzen 3000. I also tested my old RAM, which was Corsair and it would not run at its rated speed of 3200MHz on the same setup.
How did you get your AIDA64 running like that?
Mine says "TRAIL VERSION."
131032
Toothless
Tech, Games, and TPU!
5,997 (2.87/day)
Washington, USA
System Name Volt // Dualie
Processor i7-4790k // E5-2680v2 x2
Motherboard MSI Z97 MPower // S2600IP4
Cooling NZXT Kraken X60 // Hyper 212 x2
Memory G.Skill Ripjaws 4x8GB // 16x4GB ECC
Video Card(s) MSI GTX1080 Ti Gaming X // GTX 750TI
Storage 250GB NVME boot + 250GB SSD + 5 HDDs // 240GB SSD + 300GB HDD
Display(s) LG 34UB88-P + 2x AOC 2425W + Dell 2007FP // Dell 2007FP
Case Nanoxia Deep Silence 6 // Gutted case
Audio Device(s) LucidSound LS30 // None
Power Supply Rosewill Fortress 750w // EVGA NEX650G
Mouse Logitech G602 // IBM J85845R
Keyboard G.Skill KM780 RGB (Brown switches) // Logitech M100
Software Windows 10 Professional // Windows 10 Professional
Benchmark Scores Technical term is PEBCAK issue, which stands for Problem Exists Between Chair And Keyboard
618 (0.13/day)
Mouse Logitech G3
heh, so regarding "waiting":
GN just released this:
also Budget 570 board VRMs might not be up to the task of handling the 3950X because some are already struggling with the 3900X
618 (0.13/day)
Mouse Logitech G3
139 (1.08/day)
System Name Neon Master
Processor AMD Ryzen 3900x
Motherboard x570 Aorus Master F10
Cooling H115i RGB Platinum 280mm/Case Fans NF-A14 x4
Memory 2x16GB 3733 C16 G.Skill Neo
Video Card(s) RTX 2070 Super Strix
Storage MP600 / 860 Evo / 4TB WDblack
Display(s) LG 27GL850-b
Case Phanteks Evolv X
Audio Device(s) BeyerDynamic DT 770 Pro (250 Ohms)
Power Supply Seasonic Prime Ultra Titanium 1000w
Mouse Scimitar Pro rgb
Keyboard K95 Platinum rgb
Software W10Pro 1909
They didn't test dual rank modules. 2x16 would probably be slightly faster than 4x8 single rank on AMD's Fly-By optimized MC
4,652 (0.84/day)
Formosa
You might need Google translate.
618 (0.13/day)
Mouse Logitech G3
Re: Crosshair VIII Hero
465 (4.65/day)
Thessaloniki, Greece
System Name None
Processor Ryzen 5 3600
Motherboard Gigabyte X570 Aorus Pro
Cooling Corsair H110i 280mm
Memory Corsair Vengeance LPX DDR4 2x8GB (1R) 3466MHz CL16-18-18-36 1T, B-die @3600 CL16-16-16-32 1T (1:1:1)
Video Card(s) ASUS ROG Strix RX580 OC 8GB
Storage Samsung NVMe 970Pro 512GB / SATA-III 850Pro 1TB SSD
Display(s) 24" EIZO FlexScan S2411W 1920x1200, 16:10 60Hz samsung S-PVA panel.
Case None
Audio Device(s) Sound Blaster Z / Logitech Z5500 5.1 500W
Power Supply Corsair HX750i
Mouse Logitech MX Master
Keyboard Logitech G15 v2
Software Windows 10 Home 64bit
Cannot agree more...
Less modules = less stress on CPU’s UMC (unified memory controller)
618 (0.13/day)
Mouse Logitech G3
618 (0.13/day)
Mouse Logitech G3
Keep your money in the bank ahead of time.
There is no way of knowing, really !
Maybe 3950X can work with 4000 Mhz RAM with 1:1 IF speed (2000 Mhz), something that the already released ones cannot (they top out at 1900)
Also, by the time 3950X is on the market, more memory models might launch, and prices could vary a lot.
However, I'm almost convinced that the best DIMMs will still use Samsung chips, that can do CL14 at 3600 without breaking a sweat. That Corsair you linked is C18 ... eww.
I really don't understand why waste your brain effort with something that doesn't exist yet ?
I really wonder if the 1:1 IF speed of 2000 MHz is possible with the 3950X ...
otherwise i'm looking at this kit :'(
5,884 (1.90/day)
As far as I know only some people are getting 1:1 3800mhz, but most can do 1:1 3600mhz
618 (0.13/day)
Mouse Logitech G3
1:1 IF 3600 MHz stock, or they have to tweak a bunch with voltage and clocks?
134 (0.53/day)
I was able to get the Team T force Nighthawk 3200 c14 ram to work at 3600 c14 with the 3800x. If you don't want lights then the Team dark pro looks the same but without lights. 2 or 4 sticks, both work. Its cheaper than the G.skill for AMD ram. That ram is expensive.
618 (0.13/day)
Mouse Logitech G3
587 (1.28/day)
California
Yeah that is definitely a shame especially considering it's happening on a $700 motherboard.
My Aorus Master has treated me good since day one boosting to 4.6ghz on multiple cores ( very briefly lol) with a 3900X while others have had nothing but problems with the same mobo.
I did a lot of budget ryzen 1000/2000 PC with every motherboard brand for people and never really noticed any major bios issues. My only issue was trying to run Corsair LPX memory on any of them at anything above 3000Mhz. I did make sure to only run 2 dimms on all systems though.
I did have an issue with a 2400G/B450 Pro Carbon system with a Dell monitor that wouldn't show anything on screen till the graphics driver loaded making it hard to get into bios.
618 (0.13/day)
Mouse Logitech G3
3950X delayed until November is rough, but hopefully the overall X570 is more stable by then anyhow ?
