Ryzen 3950X Build Help
27,925 (6.17/day)
3950X delayed until November is rough, but hopefully the overall X570 is more stable by then anyhow ?
ABBA
530 (0.11/day)
Processor Intel Xeon E5-2699 V3 18-core
Motherboard ASUS X99-DELUXE
Cooling Noctua NH-D14 SE2011
Memory 4x 8GB Corsair Ballastix Sport DDR4
Video Card(s) NVIDIA GeForce RTX 2080 Ti Founders Edition
Storage Samsung 950 Pro M.2 NVMe 512GB / WD Black 6TB 7200 RPM
Display(s) LG - 27UD68-P 27.0" 3840x2160 60 Hz
Case Cooler Master Elite 430
Audio Device(s) Realtek HDA
Power Supply Corsair AX1200
Mouse Logitech G3
Keyboard Logitech K120
Software Microsoft Windows 10 Pro
1,695 (0.42/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 1080 nilla
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Told ya, you aint getting a 3950K anytime soon........................the 3900K is the price of a 3950K(if you can get them).
1,452 (0.81/day)
System Name Suffering from random access memory loss.
Processor Intel Core i7 980X @ 4.42 GHz (when becnching op to 4.77 GHz)
Motherboard ASUS P6X58D Premium
Cooling Noctua NH-D14 CPU cooler with 3 x noctua nf-f12 industrialppc-3000 pwm 120 MM fans
Memory 12 GB DDR3 CORSAIR 1600 MHz TIMMINGS 9-9-9-24
Video Card(s) EVGA GeForce GTX 1080 Ti SC2 GAMING
Storage 2 x Samsung 950 PRO 256 GB M.2 NVME SSD, Crucial MX300 2 TB SSD, WD RED 4 TB + WD AV-GP 2 TB HDD.
Display(s) 24" SAMSUNG
Case ANTEC TWELVE HUNDRED
Audio Device(s) ONBOARD realtek sound card.
Power Supply THERMALTAKE TOUGHPOWER 1500 WATT
Keyboard LOGITECH G19s
Software WINDOWS 10 PRO 64 BITS
Benchmark Scores https://www.3dmark.com/fs/13514527 https://www.3dmark.com/spy/2333033
I feel your pain for the waiting. I am in the same boat as you with the Ryzen 3950X. Just waiting for it to come out, so i can replace my old I7 980X. Also because i believe intel 10000 series offering aint gonna give us any thing special as long they are on 14 NM.
Planning a very simular setup as yours.
Ryzen 9 3950X cooled by a Noctua NH-D15 AM4 version (might go for custom loop if needed, but i am not much for having water in side my pc)
ASUS X570 Crosshair VIII Hero board
G.Skill TridentZ Neo DDR4-3600 C14 32GB kit
Besides that keeps my current hardware i have now i the spec profile un til i have saved up some more.
Ad in later will be:
Samsung 980 EVO or PRO NVMe M.2 SSD i hope will be on PCIe gen 4.
RTX 3000 series card maybe RTX 3080 or 3080 TI depending on price then they come out
And some more like new PSU as my current one is over 10 years old.
Well for memory, my advice would be to go for 3600 MHz C16 as over C16 is gonna be exspensive and above 3600 MHz the infinity fabrik is not al ways stable at 1:1. Most ryzen 3000 chips seems to be fine on IF at 1800 MHz, but as you draw closer to 3800 MHz memory where the IF will run 1900 MHz more and more ryzen chips will fail that task. Not many can run fully stable at 1900 MHz. Thats why i stick to 3600 MHz and then you can al ways try to nock up memory a bit and see if the cpu IF can handle it and if not dial back again. While it would be annoying to buy 3800 Mhz memory and the cpu might not can use it any way. That is also why i stick to 3600 MHz memory and then i get the CPU try to dial in manuel 3733 MHz or 3800 MHz on the memory and fine tune timmings for that accordingly to memory clock.
Else with a RTX 2080 TI and so on looks fine. You might want a new NVMe SSD as Samsung 950 PRO is not the fastes any more, but then again is stil faster than a sata SSD. I have a samsung 950 PRO as well in my X58 system and that will not be used in my ryzen setup. That will be up to you to deside and of cause your use case.
530 (0.11/day)
Mouse Logitech G3
Hoping maybe we'll seea 3950X leak prematurely on eBay
365 (0.84/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ X570 Aorus Master
Cooling Corsair h150i Pro Push/Pull. 5x Corsair ML120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 3600mhz Corsair RGB Pro/ 32 GB 3200 CL14 @3600 CL16
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Case Corsair 500D SE RGB/ Phanteks Evolv X
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
Very nicely planned build. I would expect the D15 to handle it no problem even assuming its similar to an overclocked 9900k in terms of thermal density.
The 3900X is pretty easy to manage with a Corsair h115i Platinum.
Temps for me were about 10c higher on a the h100i platinum unless I maxed out the fans so I swapped it out.
It would most likely be an ES sample if it did and I wouldn't touch one of those.
1,452 (0.81/day)
Yeah. I have my pc´s for a long time before replacing them (just look at X58 i have now) and then i so buy a new one. I always go all out on parts. I dont think so much on value but more on raw power/performance and reliability for long time use.
I also exspect the D15 to be suficiant. The noctua NH-D14 i have now, have done well together with my old I7 980X.
530 (0.11/day)
Mouse Logitech G3
Looks like Jay was wrong:
530 (0.11/day)
Mouse Logitech G3
732 (2.71/day)
Poland
Processor Ryzen 7 3700X
Cooling BeQuiet Dark Rock 4
Memory 2x8 GB Crucial Ballistix Sport LT 3200 CL16 @ 3466 CL 14
Video Card(s) EVGA 1060 6GB SSC
Display(s) BenQ BL2411PT
Mouse SteelSeries Rival 300
Keyboard Generic Dell
Jay being Jay. But it's easier to bash people for downvoting instead of actually inspecting the board you were given for review. I guess he learned his lesson.
530 (0.11/day)
Mouse Logitech G3
530 (0.11/day)
Mouse Logitech G3
1,444 (0.46/day)
Greece
Processor AMD FX-8350 4GHz@1.3V
Motherboard Gigabyte GA-970A UD3 Rev3.0
Cooling Zalman CNPS5X Performa
Memory 2*4GB Patriot Venom RED DDR3 1600MHz CL9
Video Card(s) XFX RX580 GTS 4GB
Storage Sandisk SSD 120GB, 2 Samsung F1 & F3 (1TB)
Display(s) LG IPS235
Case Zalman Neo Z9 Black
Audio Device(s) Via 7.1 onboard
Power Supply OCZ Z550
Mouse Zalman ZM-M401R
Keyboard Trust GXT280
Software Win 7 sp1 64bit
Benchmark Scores CB R15 64bit: single core 99p, multicore 647p WPrime 1.55 (8 cores): 9.0 secs
Patriot Viper Steel 16GB DDR4-4000MHz (PVS416G400C9K) is a nice choice that doesn't cost much.
530 (0.11/day)
Mouse Logitech G3
Doh! Maybe should have waited?
1,444 (0.46/day)
Greece
2021 at the earliest for anything competitive (middle tier by then). Let's hope that Navi will be proven a long-lasting efficient arch until then to have competition in all segments. Or else... :banghead: for any PC gamer.
15,753 (4.36/day)
It hasn't started that way... :(
530 (0.11/day)
Mouse Logitech G3
Not the best being a 4x8 GB kit for Ryzen 3000 series? been hearing that it's preferrable to run only 2x DIMMs with Ryzen 3000 series
530 (0.11/day)
Mouse Logitech G3
So far now: (parts already owned)
Corsair AX1200
Western Digital Black 6TB
NVIDIA GeForce RTX 2080 Ti FE
LG - 27UD68-P 4K IPS
Corsair H115i RGB AIO Water Cooler
Inland 1TB NVMe M.2 (Phison E12 Controller)
G.SKILL Trident Z Neo (For AMD Ryzen) Series 32GB (2 x 16GB) 288-Pin RGB DDR4 SDRAM DDR4 3600 (PC4 28800) Desktop Memory Model F4-3600C16D-32GTZNC
Need to buy / considerations:
Fractal Design Define R6
Asus ROG X570 Crosshair VIII Hero
Ryzen 9 3950X
898 (0.28/day)
Not really. It's running 4 ranks total. You can do it by running two dual rank modules (ie. 16gb dimm) or 4 single rank (ie. 8gb dimm) which gets you to the 4 rank ideal.
775 (10.33/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g
Motherboard msi b350 pc mate
Cooling x2 cheap china handmade
Memory klevv dual channel 3000mhz (upto 3800 bcox it is abt hynix)
Video Card(s) vega 8/56, favorite 580 nitro / red devil
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
Who is gonna game at 720p with a build that has a 38xx/39xx in it?
count me in, i can bear with it, even lower:cool:
anyway is aviable preorder 25 nov, that ryzen 9th coming soon than later, around $900 here(tax+shipment), obviously skipped by me:D
775 (10.33/day)
898 (0.28/day)
not happend here, barely can get used condition one
No idea where here is but people are selling on the more populated forums. I've seen two on H for example. We'll see more as we get closer to actual release date.
Myself, I've caught myself contemplating going for it, but then sanity kicks in and the reality is I don't need one. But I DO want one, lol.
MxPhenom 216
Corsair Fanboy
12,195 (3.62/day)
Longmont, CO
System Name The Battlestation
Processor Intel Core i7 8700k
Motherboard MSi Z370 Gaming Pro Carbon AC
Cooling EK Supremacy w/ EK Coolstream PE360
Memory G. Skill Trident RGB 32GB 4x8GB @ 3866mhz 16-16-16-36
Video Card(s) MSi GTX1070 Gaming X 8GB @ 2GHz
Storage Samung 970 EVO 250GB (OS), Samsung 970 EVO 1TB (Games)
Display(s) Dell S3220DGF 32" 1440p Freesync 2 (G-Sync) HDR 165Hz - Curved
Case Phantek Enthoo Evolv ATX TG
Audio Device(s) MSi Gaming AudioBoost ALC1220 w/ Sennheiser Game Ones
Power Supply Seasonic Flagship Prime Ultra Platinum 850
Mouse Glorious Model O w/ Hyper X Mat
Keyboard Corsair K70 w/ MX Browns and Red Backlit
almost 600 (or double the price for CL14) seems quite a bit for what seems not much difference in performance unless i'm wrong :-\
With Ryzen, youll want the tightest timing RAM you can get at 3200 or higher.
530 (0.11/day)
Mouse Logitech G3
I ended up pulling the trigger on:
