Ryzen 7 1700X Running Hot
1,611 (1.74/day)
Processor AMD Ryzen 5 1600X
Motherboard Biostar X370GTN
Cooling Custom CPU+GPU water loop
Memory 16GB G.Skill TridentZ DDR4-3200 C16
Video Card(s) AMD R9 Fury X
Storage 500GB 960 Evo (OS ++), 500GB 850 Evo (Games)
Display(s) Dell U2711
Case NZXT H200i
Keyboard Lenovo Compact Keyboard with Trackpoint
If it's an old AIO it's entirely possible that there's is growth, corrosion or other contamination either clogging up the cold plate or otherwise impeding flow. This wouldn't necessarily show on RPM readings or anything like that, but if that's the case you might be able to feel it just by touching various parts of your loop. If the pump/block housing and tubes close to it are hot to the touch but the heat seems to lessen before the radiator, you've got a flow issue. Also, moving the PC might have shaken loose debris in the AIO and caused it to accumulate in the tightest spots of the loop (typically the cold plate), thereby suddenly impeding flow even if the cooler worked fine previously.
Mussels
Moderprator
47,453 (8.60/day)
Australalalalalaia.
System Name Big Fella
Processor Ryzen R7 2700X (stock/XFR OC)
Motherboard Asus B450-i ITX
Cooling Corsair H110 W/ Corsair ML RGB fans
Memory 16GB DDR4 3200 Corsair Vengeance RGB Pro
Video Card(s) MSI GTX 1080 Gaming X (BIOS mod to Gaming Z) w/ Corsair H55 AIO
Storage 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000 Pro NVME
Display(s) Phillips 328m6fjrmb (32" 1440p 144hz curved) + Sony KD-55X8500F (55" 4K HDR)
Case Fractal Design Nano S
Audio Device(s) Razer Leviathan + Corsair Void pro RGB, Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Mouse Logitech G903 + PowerPlay mousepad
Keyboard Corsair K65 Rapidfire
Software Windows 10 pro x64 (all systems)
Benchmark Scores Laptops: i7-4510U + 840M 2GB (touchscreen) 275GB SSD + 16GB i7-2630QM + GT 540M + 8GB
I would plug the pump to either a dedicated waterpump header on motherboard (if its supported) or plug it directly to 12V just to be safe. Previously I use Seidon 240M and I get some pump noise when plug to motherboard but it disappear when plug directly to 12V PSU via adapter.
I never thought of that - i've had issues with AIO pumps in the past, i'll give that a try if it ever comes back
5,367 (2.00/day)
Memphis, TN
System Name Black Prometheus
Processor AMD Ryzen 9 3900X
Motherboard ASRock B350 Pro4
Cooling Corsair H70
Memory SK Hynix 32GB(8GBx4) DDR4 @2666MHz
Video Card(s) AMD Navi 5700 XT 50TH Anniversary Edition
Storage Sandisk X300 512GB + Seagate 2TB
Display(s) HP LA2405WG 24" Triple Monitor (5760x1200)
Case DeepCool Matrexx 55 w/ 3x120mm Intake + 4x120mm Exhaust
Audio Device(s) Samsung 5.1 Setup
Power Supply Corsair RM750X
Mouse Logitech Trackman
Keyboard Dell OEM
Software Windows 10 EDU x64
I currently put a cheap Gammaxx 200T that I had laying around on it and it idles around 36-49^C depending on the room ambient
But still a lot lower the idle on the AIO
4,598 (1.08/day)
Processor Undead CPU
Motherboard Undead TUF X99
Memory GSkill 128GB DDR4-3000
Video Card(s) EVGA 2080Ti
Display(s) Acer K272HUL, HTC Vive
Case Fractal Design R5
Audio Device(s) BOSE 2.0
Power Supply Seasonic 850watt
Mouse Logitech Master MX
Software Windows 10 Professional/Linux Mint
Just get a good air cooler and call it a day
1,611 (1.74/day)
Case NZXT H200i
That's what I did after the AIO in my partner's Threadripper workstation clogged. Haven't had a single hiccup since, and it's quieter too. And that's even with a relatively modest single tower Noctua cooler. No regrets there.
4,598 (1.08/day)
Grass is always greener on the other side. Moving with a gigantic air cooler is also a pain in the rear. So hopefully OP's problem gets sorted out.
What credit card did you buy your AIO with? A lot of credit cards offer additional 2~3yrs warranty. Might worth a try to claim it
1,611 (1.74/day)
Case NZXT H200i
We got it refunded, it failed within a year so no worries there (also that series of Threadripper AIOs from Enermax were notorious for clogging) but even beyond that Norway has fantastic consumer protection laws that enforce 5-year coverage of production faults and similar failures for anything meant to last significantly longer than 2 years - so all PC equipment, in other words.
468 (1.65/day)
Chicago Land
Processor 2700X @ x4 4400Mhz
Motherboard Asus B450-I Gaming
Cooling Stock Air
Memory Corsair 3000nhz 13-15-15-15-32-53 2T
Video Card(s) Asus strix GTX 980 OC
Storage SSD
Display(s) 21" - 55"
Case None
Power Supply Antec CP series 850w
Mouse Razar Mamba Tournament Edition
Keyboard Logitech G910
Software W7
Benchmark Scores Max Cpu clock 7685Mhz FX-8300 WPrime 32m 2.886 seconds AMD 2700x
That AIO pump must have been stalled (locked up somehow) or straight up failed. You should have similar temps with a decent air cooler as the H60 would do.
Think 36 degree is still a tad bit high, 49c idle is still too high.
Looking for 30c (give or take a couple) at windows idle.
What is your room temp though?
5,367 (2.00/day)
Memphis, TN
Cooling Corsair H70
Keyboard Dell OEM
My ambient ranges from 26*C to 35*C
PC is in my work shop which is a large garage which also works as my office
468 (1.65/day)
Chicago Land
Cooling Stock Air
Storage SSD
Case None
Software W7
The high ambient temps is what becomes the issue, Try to stay closer to that 26c or below ambient range if you can.
Gotta window? Can you use a portable A/C unit or something?
5,367 (2.00/day)
Memphis, TN
Cooling Corsair H70
Keyboard Dell OEM
Nearly impossible to keep temps stable in a garage
also no windows but there is a portable AC in here
7,635 (1.74/day)
Austin Texas
System Name _
Processor 8700K @ 5.1 Ghz
Motherboard MSI Z370-A PRO
Cooling 120mm Custom Liquid
Memory 32 GB 3600 Mhz DDR4 16-16-16-36-380 trfc - 2T
Video Card(s) Gigabyte GTX 2080 Ti Windforce (Undervolted OC 1905MHz)
Storage 3x1TB SSDs
Display(s) Alienware 34" 3440x1440 120hz, G-Sync
Case Jonsbo U4
Audio Device(s) Bose Solo
Power Supply Corsair SF750
Mouse silent click gaming mouse
Keyboard tenkeyless
Software Windows 10 64 Bit
your exhaust fan is blowing in and also missing a fan blade. Is that the H70 fan?
5,367 (2.00/day)
Memphis, TN
Cooling Corsair H70
Keyboard Dell OEM
