deepforest
- Feb 7, 2020
- 6 (0.00/day)
System Name | just ordinary potato system, but dont understimate potato.. |
Processor | ryzen raven ridge 2200g, ryzen 2600 upgrade:) |
Motherboard | msi b350 pc mate, biostars a320, asrock ab350m micro |
Cooling | x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh |
Memory | klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick |
Video Card(s) | back to square, using vega 56 now:D |
Storage | wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5 |
Display(s) | acer vgo 22inch fullhd 75hz |
Case | cheap segotep/dazumba mid atx, alcatroz mini atx |
Audio Device(s) | genius retro wood style, harman kardon stick iii |
Power Supply | be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w |
Mouse | rexus, genius ps/2, powerlogic ps/2 ball tracking |
Keyboard | rexus, random china product x3 |
Software | talking abt best software, autodesk/unity3d/notepad yes notepad!! |
Benchmark Scores | theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:) |
maybe the temperature abit hot, thats why it need extra power to spin the fans, mostly a normal 580 would run 20-30w in idle, depend whigc model have fan stop/non/a custom setupHello!) I am right that is totally normal for Sapphire 30w at idle? I want to know how technically explain this power consumption for Sapphire?
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
Processor | 11700 |
Motherboard | TUF z590 |
Memory | G.Skill 32gb 3600mhz |
Video Card(s) | ROG Vega 56 |
Case | Deepcool |
Power Supply | RM 850 |
System Name | My PC |
Processor | AMD 2700 x @ 4.1Ghz |
Motherboard | Gigabyte X470 Aorus Gaming |
Cooling | Zalman CNPS20X |
Memory | Corsair Vengeance LPX Black 32GB DDR4 |
Video Card(s) | Sapphire Radeon RX 570 PULSE |
Storage | Adata Ultimate SU800 |
Case | Phanteks Eclipse P500A |
Audio Device(s) | Logitech G51 |
Power Supply | Seasonic Focus GX, 80+ Gold, 550W |
Keyboard | Roccat Vulcan 121 |
sapphire support say that is normal for pulse and nitro, but dont explain why? And i whant to know why? Because on others 580 models power at idle ~10w.Ask sapphire
sapphire support say that is normal for pulse and nitro, but dont explain why? And i whant to know why? Because on others 580 models power at idle ~10w.maybe the temperature abit hot, thats why it need extra power to spin the fans, mostly a normal 580 would run 20-30w in idle, depend whigc model have fan stop/non/a custom setup![]()
I have second question. Advise which is better Sapphire rx580 Pulse or Gigabyte rx580 GAMING GV-RX580GAMING-8GD GB have 6 power phase and good cooler system it cover vram and vrm look screenshot. And in my country Sapphire have 2y warranty and Gigabyte have 3y warranty.maybe the temperature abit hot, thats why it need extra power to spin the fans, mostly a normal 580 would run 20-30w in idle, depend whigc model have fan stop/non/a custom setup![]()
One 60hz DVI monitorDo u use dual monitor setup?
Thanks. But why other models of 580 fron othrer brands have ~10w at idle?Yes, it is normal.
Techinacal side in simple: the chip has clock/voltage gating. So wont turn on full power if not necessary. Using that parts only what the actaul load needs, inside the chip.
Processor | i9-9900K @ 5.1GHz (H2O Cooled) |
Motherboard | Gigabyte Z390 Aorus Master |
Cooling | CPU = EK Velocity / GPU = EK Vector |
Memory | 32GB - G-Skill Trident Z RGB @ 3200MHz |
Video Card(s) | AMD RX 6900 XT (H2O Cooled) |
Storage | Samsung 860 EVO - 970 EVO - 870 QVO |
Display(s) | Samsung QN90A 50" 4K TV & LG 20" 1600x900 |
Case | Lian Li O11-D |
Audio Device(s) | Presonus Studio 192 |
Power Supply | Seasonic Prime Ultra Titanium 850W |
Mouse | Logitech MX Anywhere 2S |
Keyboard | Matias RGB Backlit Keyboard |
Software | Windows 10 & macOS (Hackintosh) |
Thanks! Yes my model have 2 bios. But default is Gaming. And i dont whant use Compute mode.there is at least one different revision of the Sapphire Pulse RX 580 8GB. Some have a BIOS switch. The first revision didn't, I have that one. Perhaps based on which revision you have, and if applicable, which position the BIOS switch is in, could impact this?
You may be splitting hairs here over a 20W difference
No i mean not temperature but POWER watts. And i have not Nitro but Pulse.I'd expect the Special Edition to be 1-2C higher![]()
Sapphire Radeon RX 580 Nitro+ Limited Edition 8 GB Review
The Sapphire RX 580 Nitro+ Limited Edition is a highly overclocked custom variant of the just-launched AMD Radeon RX 580. Performance now beats the NVIDIA GTX 1060, and in the box, Sapphire has bundled two user-replaceable semi-transparent fans with blue LEDs, if you want a little bit more bling.www.techpowerup.com
What make Sapphire better than other brands?Well it's their bios and they engineered the card. You can always switch brands.
System Name | BY-2021 |
Processor | AMD Ryzen 7 5800X (65w eco profile) |
Motherboard | MSI B550 Gaming Plus |
Cooling | Scythe Mugen (rev 5) |
Memory | 2 x Kingston HyperX DDR4-3200 32 GiB |
Video Card(s) | AMD Radeon RX 6800 XT |
Storage | Samsung 980 Pro, Seagate Exos X12 TB 7200 RPM |
Display(s) | Nixeus NX-EDG274K (3840x2160@144 DP) + Samsung SyncMaster 906BW (1440x900@60 HDMI-DVI) |
Case | Coolermaster HAF 932 w/ USB 3.0 5.25" bay |
Audio Device(s) | Realtek ALC1150, Micca OriGen+ |
Power Supply | Enermax Platimax 850w |
Mouse | SteelSeries Sensei RAW |
Keyboard | Tesoro Excalibur |
Software | Windows 10 Home 64-bit |
Benchmark Scores | Faster than the tortoise; slower than the hare. |
Then, no, not normal. 30-40w is normal for multiple monitors. Should be ~13w with a single monitor and no load:One 60hz DVI monitor
If anything, that number is low. I think it only takes into consideration the GPU and VRM. Doesn't take into consideration total board power.So, 30w is real values or incorrect sensor value?
System Name | Lynni with a Flare \ Lenowo TwinkPad T480 |
Processor | AMD Ryzen 7 7700 Raphael \ i7-8550U Kaby Lake-R |
Motherboard | Asus Prime X670-P WiFi Bios v. 1616 (Cheapest X670 around) \ Lenowo 20L60036MX Bios 1.47 |
Cooling | Noctua NH-D15 Chromax.Black (Only middle fan) \ Lenowo WN-2 |
Memory | G.Skill Flare X5 2x16GB DDR5 6000MHZ CL36-36-36-96 AMD EXPO \ Willk Elektronik 2x16GB 2666MHZ CL17 |
Video Card(s) | XFX Radeon™ RX 7900 XT Speedster Merc 310 20GB | Nvidia MX 150 2GB GDDR5 Micron |
Storage | Gigabyte M30 1TB|Sabrent Rocket 2TB|850EVO 1TB|Exos 16TB|10TB|1TB \ SKHynix 256GB 2242 3x2 |
Display(s) | LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | AUO 14" 1440p IPS |
Case | Fractal Design Meshify 2 Tempered Glass White/Black | Lenowo T480 chassis |
Audio Device(s) | Steelseries Arctis Pro Wireless |
Power Supply | Be Quiet! Pure Power 12 M 750W Goldie | 65W |
Mouse | Logitech G305 Lightspeedy Wireless | Lenowo TouchPad & Logitech G305 |
Keyboard | Akko 3108 DS Horizon V2 Cream Yellow | T480 UK Lumi |
Software | Win11 Pro 22H2 UK |
Benchmark Scores | 3DMARK: https://www.3dmark.com/3dm/89434432? GPU-Z: https://www.techpowerup.com/gpuz/details/v3zbr |
...and that's total board power, not according to software.![]()
Sapphire RX 580 Comparison – Pulse vs Nitro+! - KitGuru
Nvidia's RTX 20 series may be just weeks away, but if you want a mid-range graphics card from AMD, twww.kitguru.net
Are you running the latest drivers (20.2.2 WHQL)?
Task Manager in Windows 10 October update and newer shows GPU load under processes and the various GPU queues in the performance tab.
Yes 20.2.2, on Win7 and Win10 i have same values in Afterburner and Radeon driver.Are you running the latest drivers (20.2.2 WHQL)?
Edit: I suppose it is possible that Radeon Software is overestimating power consumption at low load and underestimating at high load.
System Name | KING-XEON |
Processor | Xeon 2697 V2(12c/24t) (OC-3,45Ghz-ALL*CORES----TURBO BOOSTING 4,03Ghz) |
Motherboard | Sabertooth X79 |
Cooling | Xigmatek LOKI SD963 double-Fan |
Memory | 64Gb DDR3 Kingston/Mushkin 1540Mhz Active clocks(9-9-9-24-162-1T) |
Video Card(s) | 1)RX 6700XT Power Color Fighter 12gb***2)MATROX M9120LP |
Storage | 2 x ssd-Kingston 240Gb A400 in RAID 0+ HDD 500Gb +Samsung 128gbSSD +SSD Kinston 480Gb |
Display(s) | BenQ 28"EL2870U(4K-HDR) / Acer 24"(1080P) / Eizo 2336W(1080p) / 2x Eizo 19"(1280x1024) |
Case | Lian Li |
Audio Device(s) | Realtek/Creative T20 Speakers |
Power Supply | F S P Hyper S 700W |
Mouse | Asus TUF-GAMING M3 |
Keyboard | Func FUNC-KB-460/Mechanical Keyboard |
VR HMD | Oculus Rift DK2 |
Software | Win 11 |
Benchmark Scores | Fire Strike=23905,Cinebench R15=1789,Cinebench R20=3791.Passmark=20689,Geekbench4=32885 |
Yep...I concur with you......I am using RX 480 Red Devil and 3 monitors and just checked in idle or while I am watching youtube power usage is 28W-30W......Then, no, not normal. 30-40w is normal for multiple monitors. Should be ~13w with a single monitor and no load:
