So I recently got a HyperX Cloud, the one with 3.5mm audio jack. I get very loud noise from the mic when i connect it to my laptop. But I got no noise if i record my voice from my phone. After a bit of research I found that an usb audio card can fix the problem, possibly because of grounding issues. But then, there is a lot of option for usb sound card. Any recommendation for a good and cheap one? Also if you have any other solution please share with me too.
Thanks!!!
Thanks!!!
