Sharkoon Unveils V1000 RGB Micro-ATX Case
43,241 (7.97/day)
Sharkoon Technologies is an international supplier of high-quality, high-performance PC components and peripherals. With the V1000 RGB, Sharkoon has now widened its popular series of micro-ATX cases by introducing the first version with RGB elements. This micro-ATX case comes with three pre-installed 120-millimeter RGB fans and a side panel made of tempered glass. As with the previous models, the power supply unit and its adjacent cables can be concealed in the tunnel at the bottom of the case. Hardware cabling can also be led out of view using the cable passthroughs of the mainboard tray. Despite the compact form factor, a 240-millimeter radiator or a 40-centimeter graphics card can be installed inside.
A power supply unit with a length of up to 24 centimeters can be accommodated in the power supply tunnel. Using cable passthroughs, cabling can be routed through and behind the mainboard tray to enable an orderly cable management. The V1000 RGB comes with three pre-installed 120-millimeter RGB fans inside: two behind the front panel and one at the rear panel. Under the top panel, either three 120-millimeter fans or two 140-millimeter fans can be installed. As an alternative to having fans behind the front panel, a 240-millimeter radiator can be installed instead. The height of the radiator including fans can be up to 5.9 centimeters.
Compact Case for Large Components
Despite its compact form factor, larger components can also be installed in the V1000 RGB. Graphics cards with a length of up to 40 centimeters fit into the case as well as a CPU cooler with a height of 15.8 centimeters.
Lots of Room for Data Storage
If a lot of data storage is required, the V1000 RGB offers a number of options for installing HDDs and SSDs: A total of six 2.5-inch drives or a total of two 3.5-inch drives can be installed. There is also the option of installing a 5.25-inch drive.
Brightly Lit
In order to light up the case, the RGB controller of the V1000 RGB can be connected to the mainboard's RGB control using a mainboard pin-out of 5 V-D-G or 5 V-D-coded-G. Selected lighting effects can then be activated as desired through the RGB controller. The RGB of the case is compatible with all common programs for RGB control, such as MSI Mystic Light Sync or ASUS Aura Sync. Alternatively, the RGB controller can also be used to manually select pre-set lighting modes using the reset button on the I/O panel.
Price and Availability
The V1000 RGB is now available at the manufacturer's suggested price of 79.90 euros.
399 (0.13/day)
UK
Reminds me a bit of the Sharkoon MA-M1000 that had more drive bays, 140mm side air intake blowing cold air directly onto the CPU + VRM's, 4x front USB ports and was 2/5ths of the price 9 years ago...
25 (0.01/day)
Budapest, Hungary
System Name ASUS G15 Advantage
Processor Ryzen 9 5900HX
Memory ADATA 2x16GB 3200MHz CL22
Video Card(s) Radeon RX 6800M
Storage WDC SN850 512GB, ADATA SX8200 Pro 2TB
Display(s) BOE 15.6" QHD 165Hz, Philips Momentum 278M1R
Audio Device(s) Edifier R980T, HyperX Cloud Stinger
Power Supply Delta ADP-280BB B
Mouse Logitech G305
Keyboard Roccat Horde
Awesome! I have two of the original V1000-s, and I've been joking a while about how it only had a plexi version. This looks like a nice upgrade along with the included hub.
3,603 (1.12/day)
Behind that massive .44 mag that's in your face
System Name The Little One
Processor i5-8279u
Motherboard AZW Speed S
Memory 32GB Crucial DDR4-3200 (2x 16GB)
Video Card(s) Iris Plus 655
Storage WD Black SN750 2TB m.2 + WD 2TB external nvme
Display(s) 2x Samsung 43" LCD's @1440p
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ - all things considered !
As I have been forced to say about 1000 times over the past 2-3 years about so-called "NEW" cases.......
No C..No Buy...No Excuses....
'nuff said....
1,406 (0.49/day)
Leland, NC
System Name The Captain (2.0)
Processor Ryzen 5 3600
Motherboard ASRock B550 PG Velocita
Cooling ARCTIC LF II 240mm AIO; 2x 140mm and 2x 120mm case fans
Memory 16 GB (3200Mhz) G.Skill Trident Z Royal (Silver)
Video Card(s) MSI Gaming X GTX 1660 Super
Storage 1x Crucial MX500 500GB SSD; 1x Crucial MX500 500GB M.2 SSD; 1x WD Blue 7200 RPM HDD
Case Phanteks Eclipse P500A (non RGB)
Power Supply Seasonic FOCUS+ Platinum 750W
Mouse Razer Basilisk V3, Basilisk V2, Viper Mini, Deathadder V2 Mini, HyperX Pulsefire Surge
Keyboard HyperX Alloy Origins Core w/ HyperX Aqua switches
rare sighting of a modern case with 5.25" external drive bay
I know ODD's aren't "in" anymore with everything being digital now, but goddamn it, sometimes I just want to watch a DVD without it taking forever to load like it does on my crappy portable DVD drive. And sadly, my P500 case doesn't have a 5.25" bay. My Cougar Panzer MAX does though, but that mofo is ridiculously heavy and huge.
