- Jul 14, 2018
- 29 (0.06/day)
- Florida
System Name | Patriot |
Processor | i5-6600K @ 4.5GHz |
Motherboard | Gigabyte Z170X - Gaming 7 |
Cooling | Corsair H100i v2 |
Memory | 16GB Geil Super Luce 2400MHz DDR4 (4x4GB) |
Video Card(s) | ASRock RX 580 8GB |
Storage | 250GB Samsung 850 EVO, 480GB SanDisk SSD, 500GB WD Black, 1TB WD Blue |
Display(s) | LG 34" Ultrawide w/Freesync 144Hz |
Case | White Corsair Air540 |
Audio Device(s) | HyperX Cloud/Logitech Z906 5.1/Sound Blaster Omni |
Power Supply | EVGA Supernova G2 550W |
Mouse | Razer Deathadder Chroma |
Keyboard | Redragon K556 |
Software | Win 7 x64 |
So, there's a built-in 10 fan fan hub. The 3 front fans and a molex for the PSU are connected out of the box. The rear fan's connector looks just like the front 3 fans' connectors, but will not fit any of the free fan connections on the hub. I took one of them off and the molex connector also and the holes in their connectors are flush with the bottom of the connectors while the holes on the rear fan's connector are not. They are raised a smidgen above being flush and so when I try to line up the pins on the hub with the holes on the connector, the bottom of the connector makes contact with the hub preventing the pins being inserted into the holes.
Is this a common thing to have happen? Is it poor manufacturing quality control? Am I doing something wrong? What do I need to do to fix this? Just buy a new connector and splice it in?
