Those are antistatic bags, they don't keep out times effect
yea but the motherboard is not ancient nor was my bridge i brought over, maybe little over a year. on both rigs that came with bridges
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
Processor | R5 5600X |
Motherboard | ASUS ROG STRIX B550-I GAMING |
Cooling | Alpenföhn Black Ridge |
Memory | 2*16GB DDR4-2666 VLP @3800 |
Video Card(s) | EVGA Geforce RTX 3080 XC3 |
Storage | 1TB Samsung 970 Pro, 2TB Intel 660p |
Display(s) | ASUS PG279Q, Eizo EV2736W |
Case | Dan Cases A4-SFX |
Power Supply | Corsair SF600 |
Mouse | Corsair Ironclaw Wireless RGB |
Keyboard | Corsair K60 |
VR HMD | HTC Vive |
Have you tried building SLI? My GTX970s were showing exactly the same about SLI in Nvidia control panel. When drivers were hacked, voila, SLI magically started working. Worth a shot. Different cards not working for SLI is very common.If people would look at the screenshots, the nVidia driver IS saying the system is ready for SLI. That means the different cards don't matter, the motherboard is fine, if either was an issue it would say the system can't use SLI. The nVidia control panel is saying to use SLI, connect a bridge. The problem is for some reason, the nVidia driver doesn't think there is an SLI bridge connected.
Processor | Intel Core i7 10850K@5.2GHz |
Motherboard | AsRock Z470 Taichi |
Cooling | Corsair H115i Pro w/ Noctua NF-A14 Fans |
Memory | 32GB DDR4-3600 |
Video Card(s) | RTX 2070 Super |
Storage | 500GB SX8200 Pro + 8TB with 1TB SSD Cache |
Display(s) | Acer Nitro VG280K 4K 28" |
Case | Fractal Design Define S |
Audio Device(s) | Onboard is good enough for me |
Power Supply | eVGA SuperNOVA 1000w G3 |
Software | Windows 10 Pro x64 |
None of the screenshots really say system is ready for SLI. It just recommends connecting with SLI cable. And if drivers dislike something, they will not detect SLI.
System Name | Widow |
Processor | Ryzen 7600x |
Motherboard | AsRock B650 HDVM.2 |
Cooling | CPU : Corsair Hydro XC7 }{ GPU: EK FC 1080 via Magicool 360 III PRO > Photon 170 (D5) |
Memory | 32GB Gskill Flare X5 |
Video Card(s) | GTX 1080 TI |
Storage | Samsung 9series NVM 2TB and Rust |
Display(s) | Predator X34P/Tempest X270OC @ 120hz / LG W3000h |
Case | Fractal Define S [Antec Skeleton hanging in hall of fame] |
Audio Device(s) | Asus Xonar Xense with AKG K612 cans on Monacor SA-100 |
Power Supply | Seasonic X-850 |
Mouse | Razer Naga 2014 |
Software | Windows 11 Pro |
Benchmark Scores | FFXIV ARR Benchmark 12,883 on i7 2600k 15,098 on AM5 7600x |
Has anyone confirmed OP is ising a double wide sli bridge, or single wide sli bridge? iirc, isnt a double wide required?
Wait double is for 3 or more
also to your comment but you can confirm that sli does in fact work on that board. just needs a new bought bridge? and with buying a new bridge should i just spend the 40 dollars for a sturdy nivida one or just a new firm bridge for like 10 bucks worK? or does it matter new to sli if i didnt say that before xD.... i personally just buy the newest top of the line cards when i can so i dont have to sliive been buying asrock boards since they have been in business. I own that exact board you have , its SLI bridge didnt work BNIB. believe what you will, but it happnes, i had to find another i had lying around...i dont know why it didnt work, but theyre cheap, & if its important for you to get SLI working, its a cheap remedy.
You could also try the Asrock software suite i linked earlier, it will tell you what you need updated, if anything.
i came to the conclusion that even if i did get it to work would the performance even matter
Processor | i7-4790K 4.6GHz @1.29v |
Motherboard | ASUS Maximus Hero VII Z97 |
Cooling | Noctua NH-U14S |
Memory | G. Skill Trident X 2x8GB 2133MHz |
Video Card(s) | Asus Tuf RTX 3060 V1 FHR (Newegg Shuffle) |
Storage | OS 120GB Kingston V300, Samsung 850 Pro 512GB , 3TB Hitachi HDD, 2x5TB Toshiba X300, 500GB M.2 @ x2 |
Display(s) | Lenovo y27g 1080p 144Hz |
Case | Fractal Design Define R4 |
Audio Device(s) | AKG Q701's w/ O2+ODAC (Sounds a little bright) |
Power Supply | EVGA Supernova G2 850w |
Mouse | Glorious Model D |
Keyboard | Rosewill Full Size. Red Switches. Blue Leds. RK-9100xBRE - Hate this. way to big |
Software | Win10 |
Benchmark Scores | 3DMark FireStrike Score : needs updating |
About buying a bridge, there are 3 different bridge speeds. The standard bridge (400MHz), the LED bridge (540MHz) and the HB bridge (650MHz). The LED bridge was introduced with Maxwell iirc and the cards were made to accept the higher speed of the newer bridge. The HB bridge is compatible with Maxwell I'm just not sure if Maxwell is still running at 540MHz and not 650MHz. I believe its still 540MHz but the HB bridge using both fingers is supposed to alleviate some stutter.
Software | Win10 |
Maxwell* cause of (540MHz SLI fingers)All the bridges are interchangeable, at least to get SLI working. If you put a HB bridge on an older card it will still work, the bridge will just run at the lower clock speed. The same with putting an older original bridge on on newer cards(up to pascal ovbiously). You can run GTX1080Ti's in SLI using the old school single wide bridge.
Processor | 3700x @ 4.3 |
Motherboard | Crosshair 7 hero |
Cooling | Kraken X62 |
Memory | 16GB Trident-Z 3200 |
Video Card(s) | EVGA RTX2080 XC Ultra |
Storage | Samsung 960 evo 500gb NVME |
Display(s) | ASUS ROG Swift PG348Q |
Case | NZXT H500 |
Audio Device(s) | Phillips SHP 9500s.....Audio Technica AT 2035 microphone.....Scarlett 2i2 audio interface. |
Power Supply | EVGA 850W Supernova G2 |
Mouse | Model O |
Keyboard | Corsair K65 |
Software | Windows 10 |
