Speed Shift from TS Not Taking Higher Number While Plugged In - Warm Temperatures While Plugged In
DrixlRey
4 (0.05/day)
I've figured out why my X1G2 Thinkpad is warm when plugged in it seems to be that Speed Shift goes to 84 on the lowest battery setting when plugged in. When I unplug it, Speed Shift is at 178.
Problem is when I try to set 178 as default for plugged in, I notice temperatures does go down sometimes, sometimes not. When it doesn't I check FIVR and I notice Speed Shift will display 84 then quickly jump to 178. When is happening the laptop is still warm.
So is there other settings I have to set in order to achieve 178 for when the laptop is plugged in? Why isn't TS able to control the Speed Shift?
