Surface Mount LED and electrical tape
6,051 (1.08/day)
USA
System Name #1 Gaming / #2 Office
Processor Intel i5 8600K / Xeon W3680 @ 4.1GHz
Motherboard Asrock Z370 Taichi / Asus P6X58D-E
Cooling Phanteks PH-TC14PE CPU HSF, Arctic MonoPlus VGA HSF / CM V8
Memory G-Skill TridentZ 2X8GB F4-3200C14D-16GTZ / Samsung 3x4GB DDR3L Green 1600 30nm YK0
Video Card(s) Zotac 1060 6GB Mini ZT-P10600A-10L / XFX Radeon 7850 DD 2GB
Storage Samsung 970 Pro 512GB NVMe, Phison E12 1TB NVMe, WD Black 4TB HDD / Samsung 950 Pro 512GB NVMe
Display(s) Dell S3220DGF 32" 2560x1440 165Hz / Asus VH242H 24" 1080P
Case Lian Li PC-A05NB / Lian Li PC-A05NB
Audio Device(s) Audiotechnica ATH M50X, Antlion Mod Mic 4, SYBA SD-CM-UAUD, Xenyx 302USB / JLab Rewind Retro BT
Power Supply Seasonic SS-660XP2 660 Watt Platinum / EVGA 650P2 650 Watt Platinum
Mouse Zowie EC2-A / Zowie EC2-A
Keyboard Filco Majestouch 2 Tenkeyless Red / Filco Majestouch 2 Tenkeyless Brown
Software Win 10 LTSC 1809 / Win 10 LTSC 1809
I bought a 5.25 to 3.5 hotswap cage (iStarUSA BPN-DE110SS) and it works excellent but it has an extremely annoying blue surface mounted led inside which is persistent enough to leak around gaps in the frame. I have some 362K UL certified black electrical tape. Putting a tiny piece of black electrical tape over the small LED on the board eliminates the problem completely for me. Is there any risk of fire with this tape over the surface mount LED? I didn't want to de-solder it because I would like a solution that is reversible.
304 (0.12/day)
Processor Amd 2400g/Amd 3800x
Display(s) 50" LG 4k hdr
Case scratch build
I would'nt loose sleep over it, man.
You could try black sharpie if you want too.
6,051 (1.08/day)
USA
Haha losing sleep is exactly why I am covering up this laser cannon.
2,586 (0.73/day)
US of A
System Name gaming
Processor Intel i7-9700k @ 4.9ghz
Motherboard Gigabyte Z370 AORUS Gaming 3
Cooling Noctua U12A
Memory 16GB Corsair Vengeance LPX 3000mhz
Video Card(s) Gigabyte GTX 1660 Ti OC 6G
Storage Crucial MX500, Western Digital 550N NVMe, Crucial P1 NVMe, SanDisk Ultra 3D, WD Blue 3D
Display(s) LG 27GL83A-B & Dell - SE2717HR 27"
Case Phanteks P400A w/ Noctua fans
Audio Device(s) Klipsch pro-media 2.1 speakers
Power Supply Seasonioc Focus Plus 650w
Keyboard Logitech G15 original
Software Win 10
Benchmark Scores i can finally play crysis
electrical tape can withstand heat over 200F, LEDs (my company makes and sells LEDs lights) barely break 100F in temp and I doubt your LED is pulling anywhere near the kind of power you need to even reach 100F.
30,442 (6.10/day)
You are ok
Ahhzz
6,936 (1.46/day)
System Name Ironic
Processor Intel 2500k 4.4Ghz
Motherboard ASROCK|Z68 PROFESSIONAL Gen 3
Cooling Corsair H60
Memory 32GB GSkill Ripjaw X 1866
Video Card(s) Sapphire R9 290 Vapor-X 4Gb
Storage Samsung 860 EVO 1Tb/WD BLACK SN750 500GB NVMe
Display(s) 22" Dell Wide/ 22" Acer wide/24" Asus
Case Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Keyboard K68 RGB — CHERRY® MX Red
Software Win 7 Ult 64 bit
I've got a strip of LEDs in the bathroom that I've got taped up with Purple and red, and there's been no problem at all for 4 years. except for needing to replace the tape, since steam and electrical eventually do mix :)
newtekie1
Semi-Retired Folder
27,628 (4.95/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) ASUS Strix GTX 1080Ti
Display(s) QNIX QX2710 1440p@120Hz
Case Fractal Design Define S
