Switching to a better Mobo help with lowering Ryzen 9 3900x CPU temps?
Antonis_35
8 (0.13/day)
Computer Type: PC/Custom Build
Case: Corsair 400R Mid Tower
GPU: MSI GeForce RTX 2080 8GB SUPER VENTUS OC Graphics Card
CPU: Ryzen 9 3900X
CPU Cooler: AeroCool P7-L240 AIO Cooler
Motherboard: Asus X470 Prime Pro
BIOS: Version 5406, 1.0.0.4 patch B (Latest)
RAM: G.Skill Sniper X 32 GB (4x8) DDR4 3200Mhz RAM
PSU: Corsair HX750 CMPSU-750HX 750W ATX12V 80 PLUS SILVER
Operating System & Version: Windows 10 Pro, Version 2004
GPU Drivers: Geforce 446.14
Chipset Drivers: AMD Chipset Drivers 2.04.28.626
Description of Problem:
My CPU is facing high temperatures, i.e 40-55 degrees Celsius on idle and up to 75-85 degrees Celsius on high loads. I am worried about the longevity of my CPU.
I disabled all CPU overclocking from the BIOS,re-pasted the CPU with Arctic mx4-2019 and made sure my system is well ventilated and clean. The PC is located in an A/C room with average temps 22-25 degrees Celsius.
After doing some research I found that the VRM implementation of my motherboard is mediocre at best. Would switching to a motherboard with better VRMs improve CPU temps?
My 2 choices are:
a) Asus TUF Gaming X570-Plus WiFi
b) MSI X570 Tomahawk WiFI
Thank you
Toothless
Tech, Games, and TPU!
6,292 (2.71/day)
Washington, USA
System Name Veraltet
Processor 3700x
Motherboard AsRock Taichi Ultimate x470
Cooling NH-D15 Chromax
Memory G.Skill 2x16GB 3200mhz
Video Card(s) MSI GTX1080 Ti Gaming X
Storage 2 NVMEs + 5 HDDs
Display(s) LG 34UB88-P + 2x AOC 2425W
Case Cosmos 1000
Audio Device(s) SteelSeries Arctis 5
Power Supply Rosewill Fortress 750w
Keyboard G.Skill KM780 RGB (Brown switches)
Software Windows 10 Professional
Benchmark Scores Brrrrrrr
Nope. Those chips like to run hot and ain't much you can do besides underclocking to the point of well, no point.
Leave it at stock settings and the chip will take care of itself.
4,332 (1.77/day)
Kiev, Ukraine
System Name WS#1337
Processor Ryzen 5 1600X
Motherboard Gigabyte x470 AORUS Ultra Gamin
Cooling Xigmatek Scylla 240 AIO
Memory 2x8GB Team T-Force Vulkan DDR4-3000
Video Card(s) MSI RTX 2060 Super Armor OC
Storage Adata SX8200 Pro 1TB
Case Chieftec AL-01B-OP
Audio Device(s) ALC1220
Mouse Logitech G603
Keyboard Zalman K500 modded (Gateron brown)
Software Windows 10, Ubuntu 18.04 LTS
What temperature monitoring tool are you using?
I'm not sure about 3000-series, but with Zen 1000/2000 your Tctl = Tdie + Toffset.
For non-X CPUs this offset is usually zero, but for X parts it's around 20°C.
Also, if your CPU_VCORE is on AUTO, monitor how high it gets during heavy loads.
1,484 (0.48/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
As @Toothless stated changing mobo will not help. Custom water loop would be best to lower temps but I will let those with water loops chime in as I am still on air with a 2700...
4,332 (1.77/day)
Kiev, Ukraine
System Name WS#1337
Mouse Logitech G603
He has a 240mm AIO, which is more than enough for 3900X.
748 (1.20/day)
south wales uk
System Name 1. The Devils Dialysis VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .
Processor 1.2700x @4.2 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus b450 elite 2. z270-a asus prime
Cooling 1.soft tube loop, cpu and gpu 2. soft loop cpu only
Memory 1.hyperx preditor @3600 16gb 2.vengence 32gb @3000 3. 16gb hyperx @2400
Video Card(s) 1.MSI 1080 8gb with EKWB 2. Sapphire Nitro+ rx580 8gb @1450 3. gtx 1060 3gb
Storage 1.256gb M.2,500gb ssd, 2 3tb HDs 2. 256gb ssd, 2tb 3. 256 m.2. 1tb ssd
Display(s) 1.LG 50inch UHD , oculus rift VR headset with touch. 2 SONY bravia1080p flat pannel 3. 17 inch
Case 1. Thermaltake P5 2. loop
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard
Power Supply 1.seasonic gx 850w 2. thermaltake 600w rbg
Software 1. win 10 enterpise 2. win10 pro 3, win10 home
Benchmark Scores 1.1950 cb 2. 1106 cb 3.cb 970
full custom loop is the way with at least 2 240 rads if thay will fit in your case, a 240mm AIO is good but just not as good as a custom jobbie. goodluck.
8,587 (2.27/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
nope, better saving for better HSF or liquid based cooler
actually you need no worry for that as long as your system runs well
8,984 (4.25/day)
Sunshine Coast
System Name Black Box
Processor Intel i5-9600KF
Motherboard NZXT N7 Z370 Black
Cooling Cooler Master 240 RGB AIO / Stock
Memory Thermaltake Toughram 16GB 4400MHz DDR4 or Gigabyte 16GB 3600MHz DDR4 or Adata 8GB 2133Mhz DDR4
Video Card(s) Asus Dual 1060 6GB
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
If you MUST choose, get the MSI motherboard.
First question is how many fans does your case have?
Which are the intake and which are the exhaust?
and a suggestion, remove the drive cage from the front as it restricts the front fans.
713 (0.21/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
Do yourself a favour before you buy a new motherboard. Buy a Sata or molex to fan adapter. And run the pump with that to see if it cools it more.
I've had an issue recently with my Pump header not been able to supply enough amps to run a pump at 100%.
After swapping to the SATA adapter my temps went from 40/85 on my water cooler to 25/60. For the sake for £4 it's worth the test.
Antonis_35
8 (0.13/day)
I am using Ryzen Master and Open Hardware Monitor.
Interesting. I will try it. Thnx!
I have 2x 120mm intake fans in the front, 1x 120mm in the bottom, my AIO and 1x120mm exhaust fan in the back.
I will be changing to a new case soon, the Phanteks Eclipse P400A which does not have a drive cage, so I will see if it makes a difference.
175 (0.48/day)
Processor Ryzen 3600
Motherboard Gigabyte B450m DS3H
Cooling BeQuiet dark rock slim
Memory Crucial Ballistix sport 3000cl15 2x8@3733cl16 dram calc
Video Card(s) Sapphire 5700XT blower
Storage WD green 480GB m.2
Display(s) Samsung S24F354
Case Cooler master Q300L
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Run your CPU at fixed voltage/speed, preferebly 4.0-4.1 if you can do that below 1.1V, you will lose a few percent single core perf, but temps will be greatly improved. A guy I know runs his 3900X@4.0@1.05V. It decreased temps in games by 10-20C and in cinebench by 20-25C, he uses stock prism cooler btw. Consumption in CB dropped from 140W to 80W.
AsRock
TPU addict
16,583 (3.46/day)
UK\US
Processor 2500k \ AMD 3900X+NH-D15
Motherboard ASRock Z68 \ ASRock AM4 Pro 4
Memory Samsung low profile 1600 \ Patriot 2x16GB PVS432G320C6K
Video Card(s) eVga GTX1060 SSC \ XFX R9 390X
Storage 2x Intel 80Gb (SATA2) WD 250Gb \ Team SSD+Samsung Evo 250Gb+500Gb+ 2xCorsair Force+WD250GbHDD
Display(s) Samsung 1080P \ Toshiba HDTV 1080P
Case HTPC400 \ Thermaltake Armor case ( VE2000BWS ), With Zalman fan controller ( wattage usage ).
Audio Device(s) Yamaha RX-A820 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000 Paradigm 5SE + Tannoy Mercury F4
Power Supply PC&Power 750w \ Seasonic 750w MKII
Keyboard Logitech K120 \ ROCCAT MK Pro ( modded amber leds )
CPU idle temps look kinda high to me, mine idle's around 35c-40c (room temp 78f), while playing RDR2 i see cpu temps go to 55c but i am only using a 390X so that be a factor too. Running Cinebench 4 times right after each other i get 75c max temp.
I am thinking the same as @micropage7 , a better cooler is needed. Better air flow though the case might help if that's possible.
Every thing is on auto
581 (0.18/day)
Processor Intel core i9 10900k @5.5ghz
Motherboard Asus Maximus XII APEX
Cooling Custom loop 3*360 45mm thick+ mo-ra3 420
Memory 2x16gb Gskillz Trident Z 4400mhz cl17
Video Card(s) EVGA FTW3 RTX 2080Ti
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) LG Ultragear 27" IPS 1440P 144HZ
Case Dynamic XL
Power Supply Corsair RM1000x
Mouse Model O-
Better board gives you better vrm temp. It does not cool down your cpu. Upgrade your cooler .
Antonis_35
8 (0.13/day)
I've set it in Ryzen Master to 4.1 GHz and 1.1 Volts.
After 1-2 hours, the temp remains around 40-45 degrees on idle and around 70-75 degrees when running Cinebench R20.
713 (0.21/day)
coventry UK
System Name Gwafwar
Software Win10 Pro
I just tested this on my 3600.
1.2v 4.2Ghz 3743 R20 56celcius lol that's a 10 deg cooldown for a 100mhz all core overclock with less voltage..... lol.
1.2v 4.250Ghz 3779 57C
1.2v 4.3Ghz 3816 58C
Crashed at 4.35 1.2v
1.25v 4.35Ghz 3879 61C
1.25v 4.4Ghz 3915 63C
Utterly mental.
1,892 (1.24/day)
System Name Bro2
Processor Ryzen 2700X
Motherboard MSI X470 Gaming Carbon
Cooling Corsair h115i pro rgb
Memory G.Skill Flare X 3200 CL14
Video Card(s) RX Vega 64 Red Devil / Sapphire 5600XT pulse
Storage M.2 Samsung Evo 970 250MB/ Samsung 860 Evo 1TB
Display(s) LG 27UD69 UHD
Case Fractal Design G
Audio Device(s) realtec 5.1
Power Supply Corsair AXi 760W / Seasonic 750W GOLD
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
Sure but consider this. If the CPU is running long term and the vrms are running and getting hotter (because they are not so great). Without a proper air circulation the temps inside will rise with time and thus the CPU temps may go higher than usual.
For instance. I got 2 TR's 3970x. when I've installed 4 fans 120mm (2 front, 1 back, 1 top) the temps for the cpu dropped by 10 deg C while running heavy tasks. The TR with the additional fans also boosts higher. I know it is a different type of CPU but maybe there is something to it?
Antonis_35
8 (0.13/day)
I've contacted my AIO's manufacturer, AeroCool for support and/or possible RMA.
In regards to upgrading my CPU cooler I'm considering the below:
Air Cooler:
a) Scythe Fuma 2 Twin-Tower
280mm AIOs:
a) NZXT Kraken X63
b) Corsair H115i PRO RGB
1,466 (2.10/day)
California
System Name His & Hers
Processor i9 9900k @5ghz/ R9 3900X Stock
Motherboard Asus Maximus XI Code/ROG Crosshair VIII Hero
Cooling Corsair h150i Pro 6x Corsair QL120 + 4x Corsair LL120/ Corsair h115i Platinum
Memory 32 GB 4x8GB 4000CL15 Trident Z Royal/ 32 GB 3200 CL14 @3800 CL16 Team T Force Nighthawk
Video Card(s) Asus ROG Strix 2080 ti/ Titan XP
Storage lots of SSD.
Display(s) Asus ROG PG278QR / MSI 27 inch VA panel.
Audio Device(s) Arctis Pro + gaming Dac/ Corsair sp 2500/ Logitech Z 625
Power Supply Seasonic Ultra Prime Titanium 850w x2
Mouse Logitech G903 Lightspeed/ Logitech G Pro Hero.
Keyboard Corsair K95 RGB Platinum/ Logitech G Pro
I have the h115i platinum on my 3900X I'm happy with it's performance.
Changing motherboards can have effect on temps due to how a motherboard tunes voltages with it's stock settings in my CH8H my temps are lower than in my aorus master because at stock settings the Asus board runs the CPU at 0.05 less vcore under heavy load.... So technically you could see an increase or decrease in temperature switching boards...
Now if you go in and set everything identical manually every voltage etc then every board should perform within margin of error on temperature.
Like others have said buying a better cooler and having good airflow through your case is the best coarse of action.
125 (0.26/day)
System Name Violet
Processor AMD Ryzen 3600 4.4Ghz 1.41v
Motherboard ASRock x570 Phantom Gaming X
Cooling Be quiet! Dark Rock Pro 4
Memory G.Skill Flare x 16GB 3400Mhz
Video Card(s) MSI RTX 2070 Super Gaming X Trio 8GB
Storage Western Digital WD Black SN750 1TB
Display(s) 3440x1440
Case NZXT H440 New Edition Window
Mouse Razer NAGA TRINITY
Software Windows 10 64bit
normaly the 3900x is idle 31/32c, gaming load around 50/52c and cinebench load ~65c. (Dark Rock Pro 4)
so i think that you must check the cooler and the airflow from your case.
Antonis_35
8 (0.13/day)
Strange. In several reviews I've seen usually this chip runs a bit hotter than that. Maybe you got a really good chip!
1,466 (2.10/day)
California
Yeah comparing temps from people with different ambient on different chips with different motherboards is pointless even with identical coolers.
I can say I wasn't overly happy with a 240 aio and switched it out for a 280mm when normalizing noise on both coolers the 280 is way better at least with my ambient which sits at 20-21C
103 (1.05/day)
My 3900x runs wayyyy cooler on the stock heatsink compared to the OP. Undervolting does help because some boards tend to run the cpu at higher voltage than necessary (asus, fingers at you).
Antonis_35
8 (0.13/day)
Like I've mentioned already I'm switching to a new PC case, the Phanteks Eclipse P400A. I will install my AIO on the front of the case and see if that makes a difference. I've also raised a case with the AIO manufacturer, AeroCool to T/S further and RMA if possible.
93 (0.03/day)
Processor Ryzen 9 3950X
Motherboard MSI MEG X570 ACE
Cooling Fractal Design S36+ Prisma
Memory G.Skill Trident Z 32GB (8GB x 4) @ 3200MHz
Video Card(s) MSI RTX 2080 Gaming X Trio
Storage WD Black NVMe 1TB + Corsair Neutron XT 480GB + WD Black 1TB + WD Gold 4TB
Display(s) Alienware AW3420DW
Case be quiet! Dark Base Pro 900
Audio Device(s) Bose Soundbar 500 with Bass Module 500 + Philips X2
Power Supply EVGA SuperNOVA 1000 P2
Mouse Logitech G900
Keyboard Razer Huntsman Elite
Have you tried running a negative voltage offset within the BIOS? Most people recommend a -0.05 or -0.1 offset which will hit your single core performance slightly but help temperatures in a significant way.
I'm running -0.1v and noticed my max temperature for the day (about a 10 hour uptime) drop 10C from ~80C to ~70C on a 3950x.
125 (0.26/day)
System Name Violet
In reviews they mostly use a open test bench system, not a normal pc case. So they have very bad airflow.
