Temps from FX to Ryzen, What is GOING ON?
1,053 (0.73/day)
Buenos Aires, Argentina
System Name Ryzen Monster
Processor Ryzen 5 2600X
Memory Corsair Vengeance 32GB (4x8GB) 2400Mhz
Video Card(s) Asus ROG Strix RX580 OC 8Gb
Storage 250Gb Samsung EVO SSD, OCZ 500Gb SSD WD M.2 500Gb, plus three spinners up to 1.5Tb
Display(s) Samsung C27F591 curved monitor 27" with FreeSync
Mouse AFX LMO216
Software Windows 10 x64 Start 10
Benchmark Scores 3DMark Time Spy 4532
...and lets not forget when AMD brought in Thermal Margin, which my head simply would never get itself around.
When I see a temperature on HW Monitor of 8c and the room is 26c, I scratch my head and then remember Thermal Margin and AMD Overdive.
3,336 (2.38/day)
Processor Ryzen 5 3600
Motherboard MSI B450 Tomahawk ATX
Cooling Scythe Kotetsu with AM4 bracket
Memory PNY Anarchy-X XLR8 Red DDR4 3200 MHz C15-17-17-17-35
Video Card(s) MSI GeForce RTX 2060 GAMING Z 6G
Storage Samsung 970 EVO NVMe M.2 500 GB, SanDisk Ultra II 480 GB
Display(s) Samsung SyncMaster C27H711 OC refresh rate 110Hz
Audio Device(s) EVGA NU Audio
Power Supply EVGA 850 BQ
Mouse SteelSeries Rival 310
Software Windows 10 Professional 64-bit v1903
727 (1.28/day)
Haswell, USA
System Name Matrexx 55 | Clevo P770ZM
Processor i7 8700K 5GHZ 1.35v | 4790K 4.6ghz 1.3V |
Motherboard Z390 Gaming X | Z97 Clevo |
Cooling Macho Rev B | Laptop heatsinks
Memory 64GB | 32GB 2400MHZ SODIMM
Video Card(s) Vega 56 | GTX 980M
Storage 512GB MX100 + 1.5TB Spinpoint HDD | 256GB MX300 + 1TB HDD|
Display(s) 1080P 144HZ/1200 66HZ (2)/ 1440P 60HZ | 1080P 75HZ 15.4 |
Case Matrexx 55 | Laptop shells
Audio Device(s) Various sound cards
Power Supply 750W | 330W |
Mouse too many
Keyboard K552 | Acer and Dell OEM KB's |
Software Windows 8.1/Windows 10/OSX "Mojave"
FX doesn't display temps properly due to AyyMD using a custom scale that gets marginally more accurate the hotter you get.
No idea how you managed to a push a Ryzen CPU that hot, even with a tinfoil POS heatsink, its a mobile based arch that runs cool and clocks low
1,316 (0.59/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
Noticed the difference myself between the two and I also was like "WTF" over temps but after seeing they do run hotter with no issues I just went with it.
I did upgrade the cooler over the Wraith with a Scythe and it helped but not by alot - But hey, I'll take what I can get short of doing water on my daily.
trickson
OH, I have such a headache
6,941 (1.26/day)
Planet Earth.
Processor AMD Ryzen7 1300X 4.0GHz
Motherboard MSI X470 Gaming Plus
Cooling Noctua
Memory Gskil TridentZ RGB DDR4 3000MHz RAM
Video Card(s) GeForce GTX 1050
Storage WD 3T
Display(s) 50" Samsung and a 23" asus LCD 1080p
Case Antech LanAir Pro.
Audio Device(s) Denon AVR3802
Power Supply Corsair TX750
Mouse Optical
Keyboard K120 Logitech
Software Windows 10 64 bit Home OEM
Benchmark Scores [url=https://valid.x86.fr/jkke77][img]https://valid.x86.fr/cache/banner/jkke77-2.png[/img][/url]
H100i
I am thinking of getting this, is this thing any good at removing heat , keeping the CPU below 85 and even 91c?
I am wondering if there really is anything that can.
1,316 (0.59/day)
Alabama
Memory C.R.S.
Software Win 7
There is but you'll have to do a little on your part to make it work.
As it was with the FX 9590 AMD tends to overshoot what it really needs to run (Based on stock speeds) and that's just how they do it.
Note my chip is a 2700X instead of a 1700X.
I did drop voltage manually from where it was to about 1.21v's in the BIOS and it runs fine that way, you'll have to see what your chip needs to run where you want it to be and go from there. If you've tried all that already then big air or water would be the next step. The Noctua cooler mentioned would be good but I'd do better than the H100i, get a unit with a rad having at least three fans instead of just two for better cooling capacity.
761 (0.73/day)
Tanagra
Processor AMD 2700X
Motherboard Gigabyte B450M DS3H
Cooling Scythe Mugen 5
Memory G.Skill 16GB DDR4 @ 3200
Video Card(s) Sapphire Pulse RX 570 4GB
Storage Inland 512GB NVMe
Display(s) LG 27UL500-W
Case NZXT H510
Audio Device(s) My ears
Power Supply EVGA 500W
A few other things to consider, the transistor density of Ryzen is considerably higher than the FX chip. More transistor density means more thermal density—the CPU will heat up quicker and then start throttling once it reaches the thermal limits. In this case, the later generations of boost technology will allow a CPU to bump up to this limit with boost clocks before dropping to the rated “all core” speed. As long as it is thermally safe to do so, the chip will boost beyond that speed. Another point is that GPUs have long had this 85C+ thermal limit with no problem, so this higher temperature doesn’t mean that your CPU is going to melt through the socket. The technology is simply different after a few generations, and unlimately it is about the chip performing as advertised. AMD, Intel, and NVIDIA all have a rated max-temp, but I don’t believe any of them throw out an “ideal” operating temp. The chips protect themselves if cooling is insufficient.
Low quality post by trickson
trickson
6,941 (1.26/day)
Planet Earth.
Cooling Noctua
Storage WD 3T
Mouse Optical
Shacka when the walls fell.
Timba, his arms wide.
Zaulock and Jalad at Tinagra!
477 (0.15/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage JBOD: 2+1+1TB 7200RPM HDD
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
That's normal. FX cpus had pretty low temperatures while ryzens are hotter but within reasonable and coolable by most cpu coolers. I observed the same thing when i upgraded my own pc. Here you can see the differences:
Mussels
Moderprator
47,516 (8.50/day)
Australalalalalaia.
System Name Big Fella
Processor Ryzen R7 2700X (stock/XFR OC)
Motherboard Asus B450-i ITX
Cooling Corsair H110 W/ Corsair ML RGB fans
Memory 16GB DDR4 3200 Corsair Vengeance RGB Pro
Video Card(s) MSI GTX 1080 Gaming X (BIOS mod to Gaming Z) w/ Corsair H55 AIO
Storage 1TB Sasmsung 970 Pro NVME + 1TB Intel 6000 Pro NVME
Display(s) Phillips 328m6fjrmb (32" 1440p 144hz curved) + Sony KD-55X8500F (55" 4K HDR)
Case Fractal Design Nano S
Audio Device(s) Razer Leviathan + Corsair Void pro RGB, Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Mouse Logitech G903 + PowerPlay mousepad
Keyboard Corsair K65 Rapidfire
Software Windows 10 pro x64 (all systems)
Benchmark Scores Laptops: i7-4510U + 840M 2GB (touchscreen) 275GB SSD + 16GB i7-2630QM + GT 540M + 8GB
H100i
if you're running stupid settings on ryzen, especially first gen they'll just run hot - the thermal throttle will keep it as hot as you feed it.
They had single core boost lower than the all core clocks for a reason, and that reason is heat.
my 2700x with a h115i (the 280mm version of the one you linked) still runs at around 70c on STOCK SETTINGS.
Better cooling will get you better clocks, but may not get better temps due to the way the boost works - and it wont help much at all (if at all) if you're running a manual, all-core OC because you were probably at the OC ceiling of a first gen ryzen.
Getting a 1700 above 4GHz is a dream anyway, very few people can do that.
trickson
6,941 (1.26/day)
Planet Earth.
Cooling Noctua
Storage WD 3T
Mouse Optical
One thing is for sure I did not buy the MB, RAM , Video card and CPU NOT to overclock them, After all this is top of the line equipment meant to do just what it is doing. I can get to 4.1GHz but the Voltage and subsequent heat production over powers my tiny 4 heat pipe air cooler, They are amazing Chip's and I will find a way the Big air coolers seem to be what I need.
I can't wait for the day AMD installs thermal electric cooling into the chips themselves. That would be so cool.
3,336 (2.38/day)
Your attempting to overclock Zen that was made on Global Foundries 14/12nm Low Power Process. Running your 1700 at 4 GHz puts it at or outside the sweet spot of clockspeed, voltage, and power consumed. The lithographic process tech used was geared towards fabricating a ARM smartphone SoC. With TSMC's 7nm process hopefully clockspeed moves up from a maximum of 4,250 MHz for Zen/Zen+
29,004 (6.32/day)
I'd be willing to bet the temps on your FX chip are much higher in reality than what that sensor reports. Those sensors were terrible, didn't even read the core temps at all... and it wasn't an uncommon thing for them to even report temps below ambient... :kookoo:
My temps on my rig were correct 43 idle, 55 gaming, 75 on blender.
Course running it at 5.0 with 1.476vcore that rises to 1.524 on blender
727 (1.28/day)
Haswell, USA
Mouse too many
Again, people have seemed to gloss over it, so I'll throw it out there again, but FX doesn't read temperature correctly due to AMD's custom scale used, based on not Kelvins, Celsius, or Fahrenheit. Dunno how he managed 90C+ on a Ryzen chip though
3,336 (2.38/day)
Not enough thermal paste, poor quality paste, bad mount, and paste didn't spread out.
Edit: The heatsink is under speced for a high TDP octa core CPU.
1,605 (0.34/day)
Oshkosh, WI
System Name ChoreBoy
Processor 8700k
Motherboard Gigabyte Z390 Master
Cooling Silverstone HE01
Memory CMK16GX4M2B3000C15 2x8GB @ 3000Mhz
Video Card(s) EVGA 1080 SC
Storage 250GB Samsung 850 EVO and the trusty old 250GB Barracuda
Display(s) Pixio PX329 and Dell E228WFP
Case Fractal R6
Audio Device(s) On-Board
Power Supply 1000w Corsair
Benchmark Scores A million on everything....
+1 to Fouquin's last post.
I seem to remember my old FX-8300 idling WELL below ambient temps. The sensors on those chips were garbage. Mine would sit below 60C @ 4.6-4.7Ghz, I think vcore was 1.45 or something. Yet still a TON of heat would come out the back of the case---probably because a most of the heat was actually leaving the chip. At stock speeds the 8300 was a very modest chip, especially with a good cooler.
Heat gets trapped more in newer chips because so much is crammed into a smaller package. I dunno, newer chips can safely run hotter than old chips.... Either that or the sensors are more accurate--hence the 115c temps on the Radeon VII.
Intel chips can also run a 5Ghz all day long--at 95C, unless you delid/liquid metal. Mine runs below 70C--literally all day long, at 4.3-4.4Ghz, crunching while I'm at work. My case is probably pretty loud compared to most people's. I've gotta pretty large cooler on it, same one I used for my FX chip.
Nothing to see here... move on.... or just buy a bigger cooler/remount your current cooler.
4,960 (1.15/day)
Australia
Processor AMD R7 2700X | Ryzen 1600X | i7 970
Cooling AMD Wraith cooler| Stock Cooler, Copper Core)| Big shairkan B
Video Card(s) ASUS GTX 970 OC in Sli | Inno3d GTX 1050 TI | MSI RX 580 8GB
Storage 250GB Plextor SSD Por 5 /1TB WD Black | 500GB SSD WD, 2x1TB, 1x750 | WD 320/Seagate 320
Power Supply Silverstone 750 | Silverstone Mini 450W | Corsair CX-750
Software Windows 7 Pro 64 | Windows 7 Pro 64 | Windows 7 Pro 64/Windows 10 Home
I have both the FX 8350 and Ryzen 2700X on stock coolers and they never get over 70c, mid 60's most of the time flat out.
Hows your air flow in your case?
10,775 (5.51/day)
Mars
Processor i7 8700k 4.7Ghz @ 1.26v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
So I got this on my FX 8300 System. I was doing this to compare temps from my Ryzen systems.
I got to say this FX CPU is WAY COOLER than the Ryzen CPU's. Hell I seen 91C running this test on my Ryzen 7 1700.
Granted the FX has a Cooler Master V8 cooler but still. The R7 1700 is tapped out Can not go Higher than the 4.0Ghz.
Is it just me or are the Ryzen Chips just way more "heat sensitive"?
They seem to heat up way faster and the heat is way harder to get rid of. It is literally incrementally based on the frequency of the chip it seems. for every 100 MGHz there is a 10*c rise in the temperature of the silicon No matter what I do the temps are so close to the top end it's just utterly frustrating! I mean I really have NEVER seem this before in ANY CPU offering from AMD. This may not be a huge issue, BUT I think it is.
I may have to go liquid.
Intel is not having this issue is it?
Intel can hit 5.0+GHz all day long AMD can't pass 4.1GHz on a good day!
I am not trying to knock the Chip or anything it's just,, What the HELL is AMD doing?
The only thing I can think of is poor silicon, Silicon valley must be running out of good stuff and now this is it? (LOL)
Any thoughts on this?
I am NOT going to back off the OC ON any machine I have. I built them with all the BEST parts I could Get (Best my money could get me. My Opinion for the money I had at the time).
I'll tell you what I wont back off any OC till the smoke clears! LOL.....
Every node shrink increases density = more power per mm2. This means the peak temp is higher, but that heat also gets moved out to the heatsink faster (because higher temp delta). You're also looking at radically different CPUs and even your cooling is different.
What'd you expect here :D But to answer your question; we already saw this higher heat and higher sensitivity to it since 22nm Ivy Bridge. At the same time, FX also has a much lower temperature cap than Zen or Intel Core does. Times have changed abit.
1,053 (0.73/day)
Mouse AFX LMO216
Is that under load or idle?
Mussels
Moderprator
47,516 (8.50/day)
Australalalalalaia.
5,963 (1.89/day)
Somerset, UK
System Name Not so complete or overkill
Processor 5960X @ 4.20Ghz @ 1.06v - For Crunching!!
Motherboard MSI X99 Titanium Gaming
Cooling Custom loop with old bits and pieces that I need to replace
Memory G Skill TridentX 3466 non RGB..
Video Card(s) 2 x EVGA GTX 1080 Ti SC Black Edition
Storage Sandisk 120Gb SSD, 2 x 2Tb Sammy 3.5" drives - Need more drives!!
Display(s) 3 x 23" LG IPS panels (can't remember model!!)
Case 10mm thick MDF on plastic risers.. It's kinda a case??
Power Supply EVGA T2 1200w
Mouse Corsair thingy
Keyboard Corsair thingy
Benchmark Scores It's not to bad.. More importantly, it works!!
I've two air coolers on my 1700X's at home, both not properly mounted but with a single fan on each of them. One is a 14D cooler and the other is some 140mm Phantek cooler, under 100% load with WCG, I can't get the temps above 55C on the 14D and about 52C on the Phantek, so if your using a H100i and your hitting 91C, there's something definitely wrong there.. Check the mount, thermal paste and make sure all is setup correctly, as everyone has suggested.. Post up some pictures if you like :)
16,358 (4.45/day)
Didnt we go over this at OCF already trickson? Where the discussion of heat and temperature were brought up and clarified already???
Ryzen offset, chip density etc... all covered. TPU said the same things. :)
https://www.overclockers.com/forums/showthread.php/794044-It-is-here!!?p=8112258&viewfull=1#post8112258
491 (0.14/day)
System Name PHaS3XIV
Processor AMD Ryzen 7 1700 @ 4.00GHz
Motherboard MSI X370 Gaming Plus
Cooling Corsair H105 (AM4 Retention yay!)
Memory 16GB Corsair Vengeance LPX DDR4 2400 C14 @ 3066 C16
Video Card(s) Gigabyte Radeon RX 5700 Stock Cooler
Storage PC- Crucial MX200 SSD + Intel Pro SSD 2500 + WD Black 750 / Server- 10TB
Display(s) Dell P2417H + Samsung 5 Series 32" LED FHD TV
Case Fractal Design Define R4
Power Supply Corsair RM750
Mouse Logitech G500S
Keyboard Razer Blackwidow Ultimate
Benchmark Scores @_@
Always a similar topic with this dude, in the Ryzen Zen Garden thread too. Throws a fat rage, calls all AMD CPUs shit, then goes quiet for a while. Its a pattern.
My 1700 @ 4025MHz @1.425Vcore (in specs) tops out at 70°C rendering in Resolve, full CPU load, with my H105 and tuned fan curves. No problems.
trickson
6,941 (1.26/day)
Planet Earth.
Cooling Noctua
Storage WD 3T
Mouse Optical
LMAO. Yeah I call them shit ,That's why I own 3 AMD systems, NO YOU call them shit , slow and things like that trying to always knock them down against Intel's Always AND I MEAN always posting Intel's faster than your AMD CPU score IN EVERYTHING. (I know you will not understand what I am saying here as well.) Then after all that bashing I get totally pissed and concede to YOUR will and talk the way talk about it and this some how surprises you? For know it all's you all are really dumb.
I Can post where I want and get different views and opinions and even others that may NOT be there HERE. Plus I do not get email notifications and alerts like I do from this forum.
You know?
So with "THIS Dude" it is what it is like it or stop posting in my threads? It is like a personal attract really, A micro aggression and a bully tactic designed to point out I am stupid and unless I meat your expetiez then I am shit.. So I can't post what I want where I want? I can not talk about things unless you YOUR glorious all knowing know it all say's it is okay?
And you wonder why I leave?
IT IS BECAUSE OF YOU!
Any way I do understand a bit better from the people here now that there is a lot more to this "heat" than I thought and for that I thank you.
I will need some better cooling for sure And yes I do run it at 4.0GHz 1.38 Vcore this does get hot when fully loaded (85c) but it could be because I have topped out the HSf or even poor sensors and things built in that are making it read higher to prevent morons like me from burnning a house down. And could also be just the way it runs no biggie really I can live with it if the CPU can LOL.
6,942 (1.93/day)
Manchester uk
System Name RyzenGtEvo
Processor Amd R7 3800X@4.350/525
Motherboard Crosshair hero7 @bios 2703
Cooling 360EK extreme rad+ 360$EK slim all push, cpu Monoblock Gpu full cover all EK
Memory Corsair Vengeance Rgb pro 3600cas14 16Gb in two sticks.
Video Card(s) Sapphire refference Rx vega 64 EK waterblocked
Storage Samsung Nvme Pg981, silicon power 1Tb samsung 840 basic as a primocache drive for, WD2Tbgrn +3Tbgrn,
Display(s) Samsung UAE28"850R 4k freesync, LG 49" 4K 60hz ,Oculus
Case Lianli p0-11 dynamic
Power Supply corsair 1200Hxi
Mouse Roccat Kova
Keyboard Roccat Iksu force fx
Benchmark Scores 8726 vega 3dmark timespy
You know?
Dude playing fair you do come across quite angry and just called us all dumb, some were genuinely trying to help.
Chill out a bit.
