- Oct 9, 2007
- 46,277 (7.69/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Thermaltake, a leading premium gaming tower manufacturer, launches the new Level 20 MT ARGB Mid-Tower Chassis and the Level 20 GT ARGB Full Tower Chassis. Both chassis come with addressable 5V ARGB LED fans which can deliver 16.8 million-color RGB illumination. Furthermore, the Level 20 MT and GT ARGB are ready to sync with RGB capable motherboards from ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync and ASRock Polychrome. The Level 20 MT ARGB and Level 20 GT ARGB take our latest case innovations and wrap them in an ultra-modern style that is utterly unique in the case market today.
Constructed with an enlarged side panel window to show off the internal components, the Level 20 MT ARGB ATX mid-tower chassis delivers a sleek look to complement its excellent cooling. The Level 20 MT ARGB is preinstalled with three 120mm 5V ARGB LED front fans and one 120mm rear fan to illuminate and dissipate heat more efficiently. The Level 20 GT ARGB edition is a premium full tower that features four tempered glass panels with locking hinged doors, E-ATX motherboard support, patented PCI-E slot design and a removable power cover. The Level 20 GT ARGB comes preinstalled with two 200 mm 5V ARGB LED front fans and one 140mm rear fan. The new Level 20 MT ARGB Mid-Tower Chassis and the Level 20 GT ARGB Full Tower Chassis offer premium design, newest technology, and ultimate compatibility.
Features of the Thermaltake Level 20 MT ARGB Mid Tower Chassis:
Trio Built-in 120mm 5V ARGB LED Fans
Preinstalled with three 120mm 5V ARGB LED front fans featuring hydraulic bearing, 9 addressable LEDs and 16.8 million-color illumination to guarantee high airflow and custom system designs to show off your PC design skills. The 5V ARGB LED fans can be controlled using a simple interface built into the I/O panel that cycles through 7 different lighting modes and a range of different color options.
Sync with Motherboard RGB Software
Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync and AsRock Polychrome. It supports motherboards that have a 5V addressable RGB header, allowing you to control the lights directly from the above-mentioned software without installing any extra lighting software or controllers. For more details, please visit ASUS, GIGABYTE, MSI and AsRock official websites.
Built-in 5V RGB Switch Board
Thanks to the built-in 5V RGB switch board, the Level 20 MT ARGB is able to deliver the addressable RGB lighting customization through the I/O port RGB button or the synchronization with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync and ASRock Polychrome motherboards.
Power Cover Design
The Level 20 MT ARGB is designed with a power cover, which can be used to organize unused cables to make for a tidy-looking system.
Dust Reduction
Fitted with a superb top filter, side filter and bottom PSU filter. Providing excellent protection and reduction against dirt and dust.
Tempered Glass Window
The left side of the Level 20 MT ARGB features a full length 4mm thick tempered glass panel, which is more durable and less prone to scratches and dust than acrylic panels.
Superior Hardware
The Level 20 MT ARGB supports up to ATX motherboards, CPU coolers up to 170mm in height, VGA lengths up to 366mm without radiator on the right side and PSU sizes up to 170mm in length.
Excellent Cooling Capability
Preinstalled with three 120mm ARGB fans and one 120mm rear fan for optimal cooling performance, this case can house up to three 120mm front fans, one 140mm or two 120mm fans on the top and a radiator size up to 360mm at the front. This allows the user at the same time to build a complete high-end system to suit their needs.
Features of the Thermaltake Level 20 GT ARGB Full Tower Chassis:
Dual Built-in 200mm 5V ARGB LED Fans
Preinstalled with two 200mm 5V ARGB LED front fans featuring hydraulic bearing, 9 addressable LEDs and 16.8 million-color illumination to guarantee high airflow and custom system designs to show off your PC design skills.
Thanks to the built-in 5V RGB switch board, the Level 20 GT ARGB is able to deliver the addressable RGB lighting customization through the I/O port RGB button or the synchronization with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync and ASRock Polychrome motherboards.
Superior Hardware and Liquid Cooling Support
The Level 20 GT ARGB supports up to E-ATX motherboards, CPU coolers up to 200mm in height, VGA lengths up to 310mm and PSU sizes up to 220mm in length.
Patented Rotational PCI-E 8 Slots Design
Our brand new patented rotational PCI-E system allows you to stack multiple GPUs either vertically or horizontally, depending on how you want to build your system.
Vertical Radiator Placement
Whether you're building a custom loop or running an AIO CPU cooler, the Level 20 GT ARGB lets you mount your radiator against the back panel to show off your RGB fans. The back panel provides adequate exhaust while putting your fans on display, with support for up to a 420mm radiator as well as radiator support on the front and top of the chassis.
Power Cover Design
The Level 20 GT ARGB is designed with a removable power cover, which can be used to organize unused cables to make for a tidy-looking system.
Four Tempered Glass Panels
The Level 20 GT ARGB features tempered glass panels on the front, top and both sides. The left and right hinged doors are also equipped with smart lock security systems to secure the inner components of your case.
Modern I/O Support (USB Type-C & USB 3.0)
The top-right panel features two USB 3.0 and two USB 2.0 data transfer ports, along with one USB 3.1 Type-C port.
DMD: Dismantlable Modular Design
Strip your case down to the bones and install elements when and as you need them with our modular design. The level 20 GT ARGB features modular panels, racks, brackets, and pre-design mounting arrays. No more unreachable screw corners or gaps, installation can be a breeze with our Dismantlable Modular Design.
For more details on Thermaltake Level 20 MT ARGB Mid Tower Chassis, please visit this page. For more details on Thermaltake Level 20 GT ARGB Full Tower Chassis, please visit this page.
Power Cover Design
Dust Reduction
Superior Hardware
Power Cover Design
