Thermaltake Commander C Cases come with 200 mm ARGB Fans and Tempered Glass
W1zzard
Administrator
19,095 (3.46/day)
Processor Core i7-4790K
Memory 16 GB
Video Card(s) GTX 1080
Software Windows 7
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear and Enthusiast Memory solutions, launches the new Commander C Series Tempered Glass ARGB Mid-Tower Chassis. Designed to expand the gaming spirit, the Commander C Series Tempered Glass ARGB Mid-Tower Chassis takes the front panel design to the next level.
The Commander C Series inherits the Thermaltake classic chassis design and combines new design elements. The Commander C Series features six different models: C31, C32, C33, C34, C35 and C36, which target a wide range of PC gamers and enthusiasts. Each piece undergoes a rigorous process of survey, observation, experimentation, remodeling, and manufacture, to guarantee ultimate customer satisfaction. The Commander C Series features an enlarged tempered glass side panel, preinstalled two 200mm 5V ARGB front fans and one 120mm standard rear fan for optimal system ventilation. The 200mm 5V ARGB front fans deliver 16.8 million-color RGB illumination and sync with RGB capable motherboards from Asus, Gigabyte, MSI and ASRock.
The Commander C Series comes equipped with GPU mounting, advanced cable management and flexibility for high-end components. The Commander C Series supports the latest PC hardware, and is not only fascinating in appearance but also powerful in performance. With six different models, the new Thermaltake Commander C Series Tempered Glass ARGB Mid-Tower Chassis provides users limitless DIY options.
Exclusively "Tt LCS Certified"
Tt LCS Certified is a Thermaltake exclusive certification applied to products that pass the design and rigorous hardcore enthusiast standards that only the world's best LCS chassis are held to. The Tt LCS certification was created so that we at Thermaltake can clearly convey to power users and enthusiasts which chassis are built and tested to be best compatible under extreme liquid cooling configurations. This ensures you get the best performance, compatibility and features.
Dual Built-in 200mm 5V ARGB Case Fans
Preinstalled with two 200mm 5V ARGB front fans featuring hydraulic bearing, 9 addressable LEDs and 16.8 million-color illumination to guarantee high airflow and custom system designs to show off your PC design skills.
Built-in 5V RGB Switch Board
Thanks to the built-in 5V RGB switch board, the Commander C Series is able to deliver the addressable RGB lighting customization through the I/O port RGB button that cycles through 7 different lighting modes and a range of different color options. The 5V RGB switch board also supports synchronization with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync and ASRock Polychrome motherboards.
Superior Hardware Support with Excellent Cooling Capability
The Commander C Series is designed with outstanding expandability supporting a tower CPU cooler with a maximum height 180mm, a dual expansion slot for VGA of up to 310mm in length and reservoir and power supply length of up to 200mm. PSU Cover is also equipped inside the Commander C Series which improves airflow and hides those unsightly cables. Moreover, The Commander C Series is optimized for excellent cooling capability with two 200mm 5V ARGB front fans and one 120mm standard rear fan. The case is able to house up to two 200mm, two 140mm or three 120mm front fans, up to two 140mm fans on top to allow users to build a complete high-end system.
Riser GPU Support Bracket
Specially designed for dual GPU placement options, the Commander C Series has the support for vertical graphic card layout with dual PCI-E slots design. Integrated riser GPU support bracket not only prevents the graphic card from sagging, but also helps to reduce the weight on the motherboard PCI-E slots.
Seamless Tempered Glass Panel
The tempered glass side panel of the Commander C Series is built to be more durable and scratch resistant than older acrylic panels.
Handy I/O Ports
Dual 3.0 USB ports on the top-front panel grant direct access when needed. As well as an ARGB button for controlling 7 lighting modes of ARGB fans.
1,202 (0.58/day)
Depends.... on where YOU are
System Name The Big RED One
Processor i7-6700k, oc'd to 4.7 ghz
Motherboard Gigabyte G1 Gaming 7- Z170x
Cooling H110i-GT w/3-AF140's in custom config, 4-AF140 (side int) + 3-AF140 (rear/top exh) All w/Red LED's
Memory 32GB Corsair Vengence Red RBG DDR4-3200 (4x 8GB) in XMP 2x
Video Card(s) Zotac GTX 1060/6GB w/15% o/c
Storage 2x WD Black SN750 1TB nvme, 2x Sammy 960 Pro 256GB nvme on pcie risers, 2x WD Black 2TB spinners
Display(s) 2x Samsung 32" LCD's @1920x1280 60hz
Case Thermaltake TT900 Super Tower w/custom paint and trim treatment
Audio Device(s) Bluetooth 4 optical amplifier & Speakers, + standard onboard components
Power Supply EVGA G2 SuperNova 850W Modular
Mouse Logitech MX5500 combo
Keyboard see above
Software Windows 10 pro 64 bit, with all the unnecessary background shiite turned OFF !
Benchmark Scores Quicker than flies on a dung pile
Wow, 1 case with 6 different front panels...wOw....
such innovation should be heralded as "the leading PC DIY premium brand" :respect:
I just can't stand it, and have already ordered 10 of each one, hahaha !
79 (0.37/day)
System Name Lovely Milky Milky
Processor 7800X at 4GHz
Motherboard EVGA X299 FTW K
Cooling Custom milky loop
Memory 32GB Crucial Ballistix Sport LT 3200MHz quad channel
Video Card(s) MSI GTX1080Ti SeaHawk EK X
Storage A-DATA 512GB M.2, 750GB Samsung SSD, 2x 1TB Seagate Pipeline HDD's
Display(s) AOC CQ32G1 32" Curved 144Hz 1440p
Case Aerocool Quartz Pro
Power Supply Seagate Snow Silent 750W
Mouse Fnatic Flick 2
Keyboard Drevo Blademaster TE
Craziness aside, thumbs up for vertical GPU mounts
1,202 (0.58/day)
Keyboard see above
Well, thats certainly n.e.v.e.r. e.v.e.r. been offered before now......neither have top mounted USB 3 ports (but still no C), tempered glass, 200mm fans, and a psu shroud to hide cables.....
this is what I meant, with sooooo much friggin "innovation" in 1 product, it just makes me head spin :)
8,193 (2.43/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
They issue the certificate and they use by themself:D
1,960 (1.26/day)
Long Island
Phanteks has vertical mount
h ttps://www.youtube.com/watch?v=Qc7EUJMxfQo
and top USB ports (at least 5 years), tempered glass for about 3 years and PS shrouds too.... expect there's more.
1,202 (0.58/day)
Keyboard see above
1,960 (1.26/day)
Long Island
Damn that's what happns when I stay up past 10 pm without any sugar or cafeine consumed that day.
79 (0.37/day)
sorry guys, when I gave it a thumbs up for the vertical mount, it wasn't because no-one else provides them, it's because it is often overlooked when the price being asked and the space available due to case width should make it a given.
