Two more questions about case fans and temps.
7 (0.23/day)
Processor Ryzen 5 3600X
Motherboard ASUS Tuf Gaming X570 Plus Wi-Fi
Cooling Stock Wraith Spire Cooler without Mount using a 40x40mm Innovation Cooling Graphite Pad
Memory 2x16gb T-force Vulcan DDR4 3200 (32GB)
Video Card(s) Stock/Founder Edition's RTX 2070 Super
Storage 256GB NvMe ADATA Xgroup M.2 SSD, External 4tb usb 3.0 Western Digital HD
Display(s) Acer 22" IPS 4ms 1080p75hz
Case DeepCool Matrexx 50
Audio Device(s) Built-in Motherboard sound out to a Tribit MaxSound Plus Bluetooth Speaker through 3.5mm connect
Power Supply 650W 80+Gold EVGA GQ2
Mouse Cheap Logitech wired mouse
Keyboard Cheap Logitech Wired keyboard
Software Win 10 1903 "Education"
Haven't gotten my new cpu cooler yet but I got the fans. I installed two 140mm fans as exhaust on the top of the case but it didn't make a difference! In fact my cpu is acting just like it did and my gpu is actually idling at 31 to 33 now when it used to idle at 27 to 29.
Also I couldn't install my front case fans because I just cannot remove the front case. I looked up two videos and seen that they put the glass part back on after installing the fans. Is there a way I can get longer screws or something and mount them from the reverse side? Or if I can't should I send back the fans and just get two higher quality 140mm case fans with more airflow, static pressure, etc. And just make the fan closer to the front an intake and leave the one closer to the rear as an exhaust fan?
Thank you very much. I should probably look up how to undervolt my cpu because just running steam and chrome goes up to the low 80s temp wise.
483 (1.69/day)
Chicago Land
Processor 2700X @ x4 4400Mhz
Motherboard Asus B450-I Gaming
Cooling Stock Air
Memory Corsair 3000nhz 13-15-15-15-32-53 2T
Video Card(s) Asus strix GTX 980 OC
Storage SSD
Display(s) 21" - 55"
Case None
Power Supply Antec CP series 850w
Mouse Razar Mamba Tournament Edition
Keyboard Logitech G910
Software W7
Benchmark Scores Max Cpu clock 7685Mhz FX-8300 WPrime 32m 2.886 seconds AMD 2700x
According to your specs you are using the stock cooler without the mount?
I think thats your main issue with cpu temps right there.
Hopefully the new cooler, you use the mount or perhaps use the mount with the stock heat sink probably would help a great deal.
Case fans are way behind the importance of a nice tight cooler mounting.....
1,434 (1.60/day)
System Name Best AMD Computer
Processor AMD TR4 1920X
Motherboard MSI X399 SLI Plus
Cooling Alphacool Eisbaer 420 x2 Noctua NHU-14S TR4
Memory Gskill RIpjaws 4 3000MHZ 48GB
Video Card(s) Sapphire Vega 64 Nitro, Gigabyte Vega 64 Gaming OC
Storage 6 x NVME 480 GB, 2 x SSD 2TB, 5TB HDD, 2 TB HDD, 2x 2TB SSHD
Display(s) Acer 49BQ0k 4K monitor
Case Thermaltake Core X9
Power Supply Corsair HX1200!
Keyboard Logitech G510
Software Windows 10 Pro 64 Steam. GOG, Uplay, Origin
Benchmark Scores Firestrike: 24955 Time Spy: 13500
With a case like that the best thing to do for your CPU is get a AIO. With the front being totally cut off and the bottom having a PSU shroud it would be difficult for any fan (regardless of specs) to give you a better experience in terms of air flow. With an AIO (max I would get is 240) you could install it at the front and use the fans that come with it for push/pull. The other fan on the bottom at the front could be used to provide airflow to the GPU. In terms of exhaust I would put one in the middle of the top and let that and the rear exhaust fan handle pulling hot air out.
483 (1.69/day)
Chicago Land
Cooling Stock Air
Storage SSD
Case None
Software W7
An AIO is no good if he doesnt use the mount.....lol
1,434 (1.60/day)
I agree he would have to remove that graphite pad ( which I hear are not that good) but I was quoting an AIO more for the design of the case.
1,489 (0.48/day)
US of A
System Name gaming
Processor Intel i7-9700k @ 4.9ghz
Motherboard Gigabyte Z370 AORUS Gaming 3
Cooling Noctua U12A
Memory 16GB Corsair Vengeance LPX 3000mhz
Video Card(s) Gigabyte GTX 1660 Ti OC 6G
Storage Crucial MX500, Crucial P1 NVMe, ScanDisk Ultra 3D
Display(s) Dell - SE2717HR 27" IPS LED FHD FreeSync Monitor
Case Phanteks P400A w/ Noctua fans
Audio Device(s) Klipsch pro-media 2.1 speakers
Power Supply Seasonioc Focus Plus 650w
Keyboard Logitech G15 original
Software Win 10
Benchmark Scores i can finally play crysis
You don't put a fan on the top front fan mount as you will choke your CPU cooler. That mount needs to be open to allow the CPU fan access to outside air for it to pull in. You stick an outake fan there and your CPU fan is playing a tug of war game with it and forcing the CPU fan to use air inside the case.
Your best bet would be to use the 120mm fan that came with the case in the rear exhaust. Use your two new 140mm in the front as intake and that will help lower your GPU temps (see below). Down the road you purchase another 140mm for a top rear exhaust (leave the top front open). According to Deepcool you can even add a third 140mm up front for intake.
Cooling Fans Support Optional: Front:140mm×3/120mm×3; Top:140mm×2/120mm×2 Pre-installed: Rear:120mm×1
Also that stock cooler is ok but even a $20 cooler will help lower temps
Most likely because the top front exhaust fan is pulling out the cooler outside air from your front air slits before the back GPU fan can use it forcing it to use air within the case.
247 (0.59/day)
ideally you would want a positive air pressure configuration which mean having more intake fans than exhaust. ex: two front intake fans, and one exhaust fan on the back, or 3 front intake fans and one exhaust fan on the back and one exhaust on the back top ( optional ) of the case
Postie air pressure means means lower temperature and low dust build up inside the case
