- Nov 24, 2022
- 34 (0.28/day)
System Name | Evolv Beast |
Processor | 7600X |
Motherboard | Asus Strix B650E-E |
Cooling | Deepcool AS500 PLUS |
Memory | Corsair Vengeance RGB 2x16GB DDR5-6000 CL36-36-36-76 CMH32GX5M2D6000Z36K |
Video Card(s) | MSI RTX 3080 Suprim X 10GB |
Storage | Samsung 990 PRO 1TB |
Display(s) | Acer Predator XB3 XB253QGWbmiiprzx, 24.5" 1080p 280Hz (UM.KX3EE.W01) |
Case | Phanteks Evolv X + 6x Phanteks M25 140m PWW D-RGB fans |
Power Supply | Fractal ION+ 860W Platinum |
Mouse | Razer DeathAdder V3 Pro |
Keyboard | Razer Huntsman V2 Red optical switches |
Hi, guys!
I'm planning to build new PC with new AM5 platform. I was thinking about 13600K/13700K but since November i can't find a good Z790 DDR5 mobo from MSI there in my country, even on amazon EU. Sold out atm or i need to wait. Only Z790 DDR4 motherboards are available right now.
My idea was build PC with 7600X then switch it with Ryzen 7000 3D cache in 2023. So 7600X is temporary solution for me. Performance of 7600X should above 9700K anyway and enough for gaming.
My current PC:
CPU: 9700K
Mobo: MSI Z390 Gaming Edge
Cooler: Dark Rock 4
RAM: Corsair VENGEANCE RGB PRO 32GB (2 x 16GB) DDR4 DRAM 3200MHz C16 Black (CMW32GX4M2C3200C16)
GPU: MSI RTX 3080 Suprim
SSD: Samsung 970 PRO 512GB
PSU : Fractal ION 860W Platinum (1 version)
Case: Phanteks Evolv X
Monitor: Acer Predator 25" 1080p 280hz
New PC platform would be looks like:
CPU: 7600X
MOBO: MSI B650 Carbon or Edge. For sure MOBO should be futureproof to handle Ryzen 7000 3D cache.
RAM: CMH32GX5M2B6000Z30 or F5-6000J3038F16GX2-TZ5NR Link to compare Corsair vs G.Skill
SSD: Corsair MP600 LPX 1TB, WD SN850X 1TB or MSI Spatium M480 Play 1TB. Which one you would choose? MSI's SSD would match to MOBO
GPU: MSI RTX3080 Suprim for now (but if AMD RX 7000 XTX will be better i may switch to RX 7000 next year)
Cooler: I was thinking about good AIO with ARGB. Please, advice me what to pick. Or air cooler enough?
My list of AIO:
1) Fractal Lumen 360mm RGB
2) be quiet! Pure Loop 2 FX 360mm
3) MSI MAG CORELIQUID C360
4) MSI MPG CORELIQUID K360 V2
5) MSI MEG CORELIQUID S360
PSU: Is my current PSU good? I can order Corsair HX1000 Platinum
Case: Since Evolv X is pretty much closed case without enough airflow, would you recommend to change case or do i need just change stock fans to better one?
My case list looks like if i would change Evolv X:
Fractal Meshify 2 RGB
Eclipse-G500A-DRGB there is no dust filters, only mesh on top and front. I guess Fractal has better dust filters.
Corsair iCue 5000X RGB
OS: Windows 11 PRO 64bit
BUDGET - around 1500 +/- EURO. Country Poland.
PURPOSE OF THE BUILD - FPS games like quake champions and casual usage
ITEMS YOU NEED/ALREADY HAVE - In need - new cpu, mobo, ram, ssd, cooler. I have - case and psu.
OVERCLOCK OR NOT? - NO
I would like to have fast, responsible silent beast PC after 4 years of using my current 9700K setup.
Feel free if you have extra questions, I will be happy to answer.
Thank you guys for help!
My current PC:
CPU: 9700K
Cooler: Dark Rock 4
CPU: 7600X
My list of AIO:
