Upgraded Hardware!
2,341 (0.34/day)
Tyne & Wear, UK
System Name AMD '13
Processor FX-6300 @ 4.43GHz (1.35v)
Motherboard Gigabyte GA-970A-DS3 rev 1.0 (F6)
Cooling Cooler Master T2 + x2 case fans
Memory 2x4Gb Crucial Ballistix Sport DDR3-1600 (Stock)
Video Card(s) Gigabyte GTX650 Ti OC 2Gb @ 1110/1500
Storage Corsair 240Gb SSD / Seagate 500Gb HDD + old skool IDE HDD's x 3
Display(s) Acer 23'' LED
Case Billy Basic
Audio Device(s) Onboard 8.1 HD
Power Supply Corsair CX600
Benchmark Scores Smenchmarks
Hi folks,
Got a new mobo and some ram, see specs!
Have just done a sm2.0 test @ stock speeds and i'm not very happy with the outcome to be honest! Can you have alook @ the attached image and see what you think!
My previous mobo (asrock dual-775vsta) and ram (Elixir DDR400) clocked fsb was 220 1:1 with ram and same cpu as I have now @ 3.77Ghz got me 1208...
So is it basically my cpu holding me back or do you think a good oc'ing will get me some better scores?
This mobo has so many different things to play with I cant wait but I just want abit of advice first!
Thanks guys
i wanna see that desktop wallpaper :D
I will put it in the sticky if you give me some advice ;)
deal :D
update your mobo bios to latest then start giving it a good OC. once you do that, your score should increase quite nicely :cool:
Cool,
Ive already updated bios ;) Is it ok to clock straight away? Do I not need to give it a run in at all?
running in isnt something that typically really has to be done. besides any run in it gets will be better done OCd as the stuff is pushed a bit harder, allowing it to wear in faster. aside from GPUs tho, the running in scenario is more myth than reality
No run in needed and you should go c2d with that rig.
R.I.P :( who got him, and why :confused:
woah
maybe something happened in the hotgirls thread
no idea.. but it couldnt of been THAT bad surely?
He posted a topless woman with huge nips after the mods warned everyone to turn it down a notch.
