Upgrading motherboard to 1156. Need help
Status
Not open for further replies.
2,452 (0.41/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 32GB Corsair Vengeance DDR4 3000mhz
Video Card(s) PALIT RTX 4070 Dual 12Gb
Storage 2X Crucial MX500 2TB SSD, Samsung 850 pro 512gb SSD
Display(s) DELL C34H89x 34" Ultrawide
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
Software Windows 10 64bit
this motherboard is very attractive to me. http://pricespy.co.nz/product.php?p=789412
That ASROCK a decent budget board, good features and will overclock well for you.
I think the rest of the members are getting pissed because you dont seem to be taking anyones advice and are going around in circles asking the same questions.
It is a bit of a minefield at first, so I understand your concern, but they have given decent advice and you should stick with it if you want help on this.
Basic summary:
1.)Go with 1555 sandybridge
2.)Go with either i5 2500K or i7 2600K CPU's
3.)Ensure you have a "B3 revision" motherboard
4.)Ensure you have a P67 / Z68 motherboard if you want to overclock
5.)Dont get a P67-M motherboard as they dont support overclocking like a lot of the MATX sandybridge motherboards.
This is basically what you need to look at... if in doubt, put the motherboards model number into google and check out a review showing how it overclocks etc... that way you will know if its worthwhile.
Fortunately SB motherboards are almost all great overclockers and they will generally hit 4.5+ghz easily (CPU dependant) so you dont have to buy the most expensive one there is. Just find one with good reviews and proven overclocking capability with good features and make up your mind ;)
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
Wholeheartedly agree with you except for one item:
If it means getting a much better board by "downgrading" to say an i5 2400, then do it! That cpu can still overclock easily to 3.9-4Ghz without a voltage bump, just don't expect ANYTHING past that range. It would be able to do it on STOCK cooling so no need to get an aftermarket cooler for it.
bigg34
106 (0.02/day)
JrRacinFan: Thank you. But what if i buy a non B3 motherboard? non revised?
like that Asrock? its a good board but not B3.
i heard its SATA 3 has problems but is it a severe issue or i can still game and use my PC on that board?
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
I myself, if I were purchasing I would make sure I had a B3 OR a dedicated SATA raid card just to have more than 2 SATA ports for use without issue. It has been said in the past that the SATAII ports on non B3 boards suffer hardware failure but as far as how long into it's lifespan, unsure.
But yes as long as you use the motherboard integrated SATAIII ports only it will work without failure.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
its SATA 2 or 3? because i heard its sata 3 has issues.
It's the SATAII ports that has the issues.
Quick excerpt:
On January 31, 2011, Intel issued a recall on all 67-series motherboards due to a flaw in the Cougar Point Chipset. A hardware issue, in which the chipset’s SATA-II ports may fail over time, cause failure of connection to SATA-II devices, though data is not at risk. Intel claims that this problem will only affect 5% of users over 3 years. However, heavier I/O workloads can exacerbate the problem.
Source
bigg34
106 (0.02/day)
thanks. so it means i might not be affected after all. since only 5% of users might be in trouble and not ALL.
but i can still use the SATA 3 connections and not sata 2 without having a problem overtime.
im going to buy that board. i cant find a cheap motherboard like that which has many features and can overclock well.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
If you need more ports, get a SATA card later on.
brandonwh64
19,542 (3.66/day)
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
Brandon....
:D Been waiting to use that FOR A LONG TIME!
bigg34
106 (0.02/day)
brandonwh64: if u dont like it, then dont post here. you are wasting the space of my thread.
i will buy that i5 2500k and will overclock it to 4.7ghz. it will be faster than your CPU which is at 4.00ghz :).
brandonwh64
19,542 (3.66/day)
This guy makes me laugh. I came back to this thread to see how much fail it has accumulated.
Telling everyone your going to have a heart attack and die is pretty lame.
JR!!! nice one!
bigg34
106 (0.02/day)
brandonwh64: i have an illness. i am sick. i should avoid people like u who make me nervous and pressure me by your nonsense.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
crazyeyesreaper
Not a Moderator
9,764 (1.77/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI GTX 1080 Ti Gaming X
Storage 3x SSDs 2x HDDs
Display(s) Dell U2412M + Samsung TA350
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
stop being a pussy work harder save more money buy what you want
oooh i have a heart condition my buddy survived cancer twice and has a leak in his Aortic valve in his heart, told him not to weight lift he does anyway, hes alive and well so again stop being a pussy and man up if you drop dead from words on a forum you wouldnt be missed.
oh and so i dont forget to poke fun at my buddy cancer boy
2,361 (0.48/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 NVME SSD (OS), Toshiba 3TB (Storage), Toshiba 3TB (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell P2312H @ 1080p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7 (Speakers), Creative Zen Hybrid headset | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse Roccat Kone Air| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
Don't use your condition as an excuse to get people to stop being mean to you.
Man up and post coherantly, or don't post at all. Simple as that.
455 (0.10/day)
System Name ---
Processor Ryzen 1600
Motherboard ASRock Taichi X370
Cooling Noctua D15
Memory G.Skill 3200 DDR4 2x8GB
Video Card(s) EVGA 1080 TI SC
Storage 500GB Samsung Evo 970 NVMe + 860 Evo 2TB SSD + 5x 2TB HDDs
Display(s) LG CX 65"
Case Phanteks P600S (white)
Power Supply Corsair RM850x (white)
...seriously though this thread is freaking huge. I'm sure a heap of good advice has already been given. Time to make a decision.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
its a soul wrecking decision.
Wait a moment, what are you having difficulties deciding on? Whether or not to go through with the upgrade or what parts to get? I think this thread is well past the point of you getting advice.
JrRacinFan
20,073 (3.21/day)
Youngstown, OH
Storage 20+ TB
crazyeyesreaper
Not a Moderator
9,764 (1.77/day)
Keyboard Mionix
trollin trollin trollin trollin keep them trolls a trollin, TROLLING!!!!! its Epic WiNNING!!!!
Status
