Utorrent auto start/shutdown
freaksavior
To infinity ... and beyond!
8,095 (1.20/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
is there a program that can auto start utorrent or a torrent program at a certain time, then close it at a certain time?
Utorrent has a built in scheduler. It won't start the program and stop it automatically, but it will start and stop the downloading automatically, or limit the bandwidth available to utorrent at certain times.
If you need the actual program to start and stop, you can use task scheduler to start utorrent when you want, and use taskkill in a batch file to kill utorrent, then schedule the batch file using task scheduler to kill utorrent when you want.
You can create a micro?
how do i do this?
I understand task scheduler but the other part, no idea
Open Notepad
Copy and paste this: taskkill /IM uTorrent.exe /F
Save the text document as whatever name you want(except taskkill), but change the txt at the end to bat.
Then when you schedule the task to shutdown utorrent, point it at the bat file you just created.
That should do it.
