Variable power supply need some opinions
Discussion in 'Cases, Modding & Electronics' started by Hellraiser1981, Jun 14, 2005.
  1. Hellraiser1981
    Apr 15, 2005
    308 (0.07/day)
    32
    Green Bay, WI
    I am currently designing a high-current variable PWM switching power supply for 3 peltier coolers I will be using in the near future. I would like any opinions or new ideas regarding the design. Posted are the two modules I have designed so far. This power supply is a part of the custom exterior ATX PSU (computer case mounts on top of it) I am designing for use in my own system and will hopefully patent soon. (800W ATX with all independent, adjustable rails, dual +12, built in UPS, 12v standby, with a 500w+ variable, temperature controlled output for TEC's)
    The AC input is not designed yet, but will just be a bridge rectifier with a choke and Filter caps which will yield ~+145v from a 110VAC input.
    The partial design posted should work, I just haven't built it yet. Some of the parts aren't specified, but I will keep updating the pictures as I make progress.
    I am releasing these prototype schematics to the public in hope of getting some new ideas for it.
    Thanx in advance for any, and I mean ANY ideas.
    Added 6-13-05:
    Finished designing the AC input (here's another schematic). Very straight forward design and should be able to handle a lightning strike without blowing anything other than the replaceable surge module (outlined in grey on the AC circuit) It's overkill for just a 12v supply, but it'll also supply power to the ATX P.S. section of the unit.
    10 Year Member at TPU
  2. W1zzard
    W1zzard Administrator Staff Member
    May 14, 2004
    16,768 (3.46/day)
    17,507
    looks good from what i can see. maybe check out using a microcontroller (i like atmel) for the pwm part. it gives you much more flexibility, you have to know some c programming tho.
  3. Hellraiser1981
    Apr 15, 2005
    308 (0.07/day)
    32
    Green Bay, WI
    I do like the idea of using a microcontroller, but it isn't necessary for my application. Although, I could interface it with the computer and control it with software (any programmers out there?) I'm a hardware guru, so C is out of my league.
    I just need to built a multi-comparator circuit for the temp control and protection circuits (both in very rough draft on paper).
