Very weird issues with USB ports, Audio hardware and...?
66 (0.02/day)
Three days ago I simply shutted down my tower (info below!) after a windows update, and set the power "off".
I came back today and when I re-powered up my machine a LOT of things happened.
1) My keyboard didn't recognized an attached usb key, I restarted then discovering the tower itself didn't do it when attacching it to free usb slots. No sound was emitted when attaching or deattaching usbs.
2) After the restart the keyboard was not powered enough, it didn't work, neither any of the USBs, and when trying to record audio with my microphone (that was attached and on, but not working like the keyboard) it gave me weird errors, like "ID not recognized"
3) Tried some different restarts and setups of cables and usb keys, everytime it said "ID not recognized", an error I've never seen in Windows 7 before. In the control panel, the "Audio" options showed that any hardware for rec was simply VANISHED and there was some unknown issue with the AMDA00 Interface.
4) After almost a hour the tower began to go "crazy" with "connected usb" sounds, as if it was actually remembering all my tests in the last restart, and things began to work again one after another, with some errors that were gone after a final restart. Still, in the "rec" tab of the Audio control panel everything disappeared, if not the external Blue Yeti mic I use.
...I do not understand, honestly. It is really an unique issue and it scares me for it's instability. I use this machine to work everyday and this is worrying me. Could it be because it was powered off (not only the OS, the tower itself had the alimentation switch turned off) for days? Or is it something that could have been the update's fault? I really can't decipher it.
(The PC's specs:
Case: Corsair Obsidian 650D
CPU: Intel i7-4930K Ivy Bridge Processor, 12 MB Cache, 3.40 GHz
MOBO: SUS X79-DELUXE
RAM: 2 pair of Corsair Vengeance 16GB 1600MHz DDR3
GPU: Sapphire TRI-X R9 290X 4GB GDDR5 OC (UEFI)
Optical Drive: LG BH16NS40 Blu-ray
HDD: one 500SSD and one 2TB HDD
PSU: Seasonic Platinum-1000)
719 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
This is a really blind shot in the dark.
But I might suspect the bios battery.
Sounds like you have had a low voltage default settings bootup probably with legacy usb. As the PC has been on for a while it's thrown some charge back into the cell. You probably did a bios reset as well towards the end by the sounds of your troubleshooting.
66 (0.02/day)
I didn't do a bios reset, at least not by my wish. I just kept restarting the machine, but if it was the case of the bios battery, is there any kway to change it by myself?
I do put the power supply off because, I still didn't find why (not something to do with updates it seems) the computer always turn on by itself during night.
7,124 (1.45/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Video Card(s) Sapphire Pulse RX 7900XTX + under waterblock.
Storage Optane 900P[W11] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO[FEDORA]
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 39 / Windows 11 insider
Wire problems?
13,210 (3.81/day)
Sunshine Coast
System Name Black Box
Memory G.Skill 16GB 3600 C18
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Turn off the Asus Overclocking software, or remove it completely.
42 (0.01/day)
Hamburg,Germany
System Name My PC
Processor Rysen 5 2600
Motherboard Gigabyte B450M DS3H
Cooling BeQuiet Dark Rock Advanced
Memory 2x8 G.Skill DDR4-2132
Video Card(s) Gigabyte 1080 turbo
Storage LiteOn 256GB SSD,Seagate 2TB+WD 4TB
Display(s) LG 29UC97C-B
Case Custom
Power Supply XFX Core 750W sleeved
Try reconnecting the 24 pin motherboard connector.
95Viper
Super Moderator
12,669 (2.24/day)
Try a "System Restore" to a point before the updates.
Or, you could try uninstalling the updates until you find the ones or one that may have caused the problem.
I would try the first one, if you have system restore turned on.
66 (0.02/day)
I do have a system restore ready, but ONLY one and it's not clear if it is before or AFTER the update. Is there any way to know or, maybe, to tell my machine to save MORE of them for future isseus?
Do you mean the AI Suite 3?
1,555 (0.31/day)
Kolkata, India
System Name Coffee | Maximus
Processor Intel Core i7 9700K @ 5.2 GHz with AVX, 4.8 GHz cache clock | i7 9700KF @ 5.0 GHz/4.7 GHz cache
Motherboard ASUS Maximus X Formula | ASUS Maximus VIII Ranger (modded BIOS for Coffee Lake)+TPM2.0 module
Cooling Cooler Master ML240 Illusion | Cooler Master ML120L RGB
Memory 2*16 GB (32 GB) Kingston Fury Beast @3600 MHz CL17 | 4*8 GB (32 GB) HyperX Fury @3200 MHz CL14
Video Card(s) Zotac RTX 3070 8 GB Twin Edge | Galax RTX 2060 Super 8 GB
Storage Samsung PM981a 1TB NVMe+480GB SATA SSD+2 TB HDD | Crucial P5 1TB, Crucial P1 500GB+2.5TB HDDs
Display(s) LG OLED 55 G3, 4K 120 Hz, VRR, ALLM, GSync, FreeSync | Samsung 43AU9070 4K TV, VRR, ALLM
Case Corsair Crystal 460X RGB | Lianli Lancool 215
Audio Device(s) Creative Sound Blaster Z SE | Realtek ALC1150 (Supreme FX)
Power Supply ASUS ROG Strix 750G (80+ Gold) | Cooler Master MWE 650 V2 (80+ Bronze)
Mouse Cooler Master MM731 19000 DPI gaming mouse
Keyboard Cooler Master CK721 65% mechanical gaming keyboard (tactile)
Software Windows 11 Pro x64 |Windows 11 Pro x64
Benchmark Scores Cinebench R20 MT 4200,ST 547 CPU-Z MT 4871, ST 620 | R20 MT - 4158, ST - 534, CPU-Z MT 4798, ST 603
The PSU might be at fault. The capacitors might take more time to charge up and allow the PSU to give stable power.
66 (0.02/day)
Thing is that after some time the machine is working "fine", except for the audio hardware disappeared. Is there any way to do some diagnostic? To understand if the PSU takes too much time to power up stably or anything related?
Moreover, I find it strange to have only 2 system restore points, oneeven activated Yesterday. I checked the options and it seems it should make one almost everyday, but it's not happening.
p.s.: knowing how to tell my pc to NOT POWER ON by itself during night could also be of great help indeed.
13,210 (3.81/day)
Sunshine Coast
Mouse Yes
Keyboard Of course
1,555 (0.31/day)
Kolkata, India
For testing if its a PSU related issue, the only way I see is to try your PC with a different PSU and check if the problem persists.
13,210 (3.81/day)
Sunshine Coast
Mouse Yes
Keyboard Of course
From memory, it plays with the power states and can cause your system to power up overnight, even when switched off.
66 (0.02/day)
There are a lot of programs from that AI Suite, do I have to unistall ALL of them? I really think not since there are some useful things in there, am I wrong?
13,210 (3.81/day)
Sunshine Coast
Mouse Yes
Keyboard Of course
You'll have to wait for another opinion on what to remove, if anything.
I was basing my suggestion on what I have read in the past that has affected others with similar problems, I have never had this issue myself.
OneMoar
There is Always Moar
8,744 (1.71/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Cooling Enermax ETX-T50RGB
Storage ADATA SX8200PRO NVME 512GB, Intel 545s 500GBSSD, ADATA SU800 SSD, 3TB Spinner
Mouse Kone burst Pro
Keyboard EVGA Z15
AI charger and usb 3.0 boost are known to cause weird issues with usb devices
that being said I don't know if that's all you have going on
it sounds likea chipset driver update failed,the sounds you heard where windows re-installing the drivers
1,180 (0.21/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
Keyboard Logitech G710+
Sounds like an update problem to me. When you said you "shut down after the update" Did you shutdown just after it installed or did you wait for it to reboot, finish loading the updates then shutdown? It sounds like you've powered off half way through the update process. This is something Microsoft warns about NOT doing. As has been suggested, system restore should fix things, if you haven't got a restore point, or its a really old restore point you might need to do a repair install
66 (0.02/day)
Uhm.. Roger that. I might try to uninstall these for example, since I'm looking forward stability more than faster transfers.
The update installed while shutting down, so yes, I of course let it power off by itself after the installation was complete, but it didn't reboot since the order I gave to the machine was actually a shut down.
Just to know, since it will be surely helpful, how should/could I do a repair-install? And furthermore is there any way to tell windows to just do MORE restore points?
95Viper
Super Moderator
12,669 (2.24/day)
I told you that you need to increase the amount of space allowed, this will increase the number of restore points.
There is no setting the number of restore points with specific number. Unless, you find some third party software that has that ability.
However, you can use the task scheduler to let windows know when to create the restore points.
Change How Often System Restore Creates Restore Points in Windows 7 or Vista
OneMoar
8,744 (1.71/day)
Rochester area
Keyboard EVGA Z15
you can create restore points by hand
odds are it was just windows updating a chipset driver that will cause a bit of wonk if it doesn't go right the first time ,which if ai suite was running is fairly likely
66 (0.02/day)
Found it! I only read the part about the Task Scheduler, but I found my restore space was ONLY 2%. Now I upgraded it to 15%, hope this will help in the future.
Urhmrmrm... Scary. Do you have any suggestion then? Any way to know "everything is all right" or "NOT Alright"? I don't know what has been updated, after all... And this AI Suite is quite a mess I see.
66 (0.02/day)
Even with "powercfg lastwake" I got no response from the PC, that says "reactivation count - 0" (it may be not literal since I sadly have the OS in another language)
