Visiontek ATI Radeon Hd 2600 Pro Fan Noise
theaust22
5 (0.00/day)
Is there anything I can do to reduce the fan noise on this card. I like the card it works great, but it can be a bit loud. Is there any silencers out there or something like that? I'm new to all this stuff and I need some help hehe. Anything would be great thanks!
panchoman
Sold my stars!
9,595 (1.57/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
you can adjust fan settings using ati tool and i think rivatuner does it to.
welcome to the forums btw :) :toast:
theaust22
5 (0.00/day)
I downloaded that, and wasn't really sure how to work everything hehe. I didn't see any fan control settings. The problem I have with the fan noise is I don't hear it when I'm playing my games because the sound of the game overrides it. But when I am surfing the web late at night with no other sounds going it can get annoying. What I want to try and do is tone the fan down when I'm websurfing, and not really doing anything where the card has to work hard. Then return it back to default when I want to play my games, watch movies, etc. Does anyone know an easy way to do this? Thanks
dwax
180 (0.03/day)
Processor AMD Athlon 64 3400+
Motherboard MSI-7145
Cooling ZALMAN CNPS9700LED.
Memory 2Gig of PC4000 500Mghz Crucial Ballistix Tracer
Video Card(s) Nvidia XFX 8800GS
Storage 2 250 GB western digital HD External WD 250 HD
Display(s) Acer 22WS
Case Old eMachine modified
Audio Device(s) Sound Blaster X-Fi Extreme Fidelity
Power Supply Thermaltake TR2 W0070RUC ATX 430W
Software WinXP Media Center Edition
If you figgure out how to adjust the fan, let me know I have the same card. :laugh:
manman
1 (0.00/day)
I re-wire a 3 pin fan power line, (replace 12v to 5V to the power out),
even the fan is using 2 line connecter, I still can connection it to that 3 fan power line.
now the noise is less than the rest of computer's Fans , so I think it is OK.
the temp is too high, room temp : 22C, idle temp 50C , 99% load : 68C
room temp : 10C, idle temp 40C,
when I compare the temp in full speed and 5V speed, the different is less than 4~5C.
or you can try the 7V way (12V-5V = 7V)
