Water cooling loop
Discussion in 'Overclocking & Cooling' started by Chewy, Apr 17, 2010.
  1. Chewy
    Chewy New Member
    Jul 9, 2006
    3,287 (0.83/day)
    148
    Halifax, Canada
    Hello, I'm going to install my new GPU block and rad to my loop. I'm wondering what would be best:
    Config1. Pump, Rad1, CPU, GPU, Rad2, Pump.
    Config2. Pump, Rad1, CPU, Rad2, GPU, Pump.
    My set-up consists of:
    Luna Cpu Block
    Swiftech Komodo 5850 Block
    Den Danger CPX-Pro
    •Flow Max - 800 Liters/hour (211.3 gallons/hour)
    •Max Height - 4 meters (13.1 ft)
    Swiftech MRC220 Rad
    Swiftech MRC220 Rad with built-in Res
    I'm using 1/2 Tubing, also my rear exaust will be reversed to intake some fresh air to the top rad. I'm using a Noctra S12 on that so it wont be hauling much air.
    here are some pictures:
    Config1
    [​IMG]
    Config2
    [​IMG]
    10 Year Member at TPU
  2. sneekypeet
    Apr 12, 2006
    23,838 (5.91/day)
    8,454
    seems config 2 would be the coolest temps on each component, although with two rads it may not matter much either way. Thats a lot of water to heat up, with a bunch of dissipation area.
  3. bogmali
    bogmali Moderator Staff Member
    Mar 16, 2008
    7,211 (2.16/day)
    4,539
    Pacific Northwest
    Config2 for sure.....Since the water would cooler coming from the 2nd rad as opposed to coming from the CPU block. I have that very same case and it sucks that you cannot mount a thicker rad on there:banghead:. You might wanna also try to mount a single 120MM rad right where the exhaust fan is unless you're already set on an external 2X120MM mounting.
  4. Chewy
    Chewy New Member
    Jul 9, 2006
    3,287 (0.83/day)
    148
    Halifax, Canada
    Thanks man, I just wasent sure of my pump :p Nicx.ca only had this pump for sale. I wanted a swiftech lol.
    Den Danger CPX-Pro
    Theres not much extra tube in config2 I guess.
    Finnally My computer is becoming complete, it took 2 years of some upgrading here n there... but I always planned on water-cooling my gpu/cpu.
  5. Sasqui
    Sasqui
    Dec 6, 2005
    9,160 (2.20/day)
    3,235
    Manchester, NH
    Vote = Config 2 hands down. You'll definitely see a GPU temp drop that way.
    Den Danger CPX-Pro
    That's an unimpeded 3.5 GPM. In reality with all the blocks and fittings, you;ll probably see about 1.5 GPM, it's just the nature of the beast.
    Chewy says thanks.
    10 Year Member at TPU Crunching for Team TPU
  6. Kreij
    Kreij Senior Monkey Moderator Staff Member
    Feb 6, 2007
    13,826 (3.70/day)
    5,631
    Cheeseland (Wisconsin, USA)
    I like your l33t photochop skillz ! :D
    How about Pump -> CPU -> Rad1 -> GPU -> Rad2 -> Pump
  7. Chewy
    Chewy New Member
    Jul 9, 2006
    3,287 (0.83/day)
    148
    Halifax, Canada
    ^^ ty. Indeed I am the Leetest Photochopper on TPU. Ty for the extra config Idea when installing I will decide which one.
    Bogmali, I'm using a swiftech rad mount for the rear Rad.
    Where did you mean you cannot mount a thicker rad? I've read you could mount a bigger rad inside the top of the case. I was thinking about getting a Thermochill PA120.2, but I could use the extra saved money elsewhere and I figured another Swiftech 240mm, would cool good enough considering Im not trying to break [/s]any many records.
  8. Kreij
    Feb 6, 2007
    13,826 (3.70/day)
    5,631
    My thought was why not send the coolant directly to a Rad after it has cooled a component.
    In config 2 you send hot water to the pump from the CPU (which is okay), but why not cool it first?
    They as it travels from the Rad through the pump and back to the CPU it has a little more time to dissapate a little more heat. It may not be much, but the longer the water is away from the components the more chance it has to cool.
    Another option would be to use seperate loops for the GPU and TPU.
    Chewy says thanks.
  9. Chewy
    Chewy New Member
    Jul 9, 2006
    3,287 (0.83/day)
    148
    Halifax, Canada
    thats a real good idea thanks. I think it would look neater too, trough the window.
    That vertical tube from pump to rad might be a little in the way of cables. I was thinking of using my clear tube for that run, since my 10ft of black tube will not cover the whole thing :p ohwell I'll make due.. prob next weekend though.
  10. leemerlord New Member
    Feb 28, 2010
    286 (0.11/day)
    9
    Ramona, California
    im just wondering wheres a good place to get water cooling supplies. im starting to get interested in trying to get my air cooled system to a WC
  11. Kreij
    Feb 6, 2007
    13,826 (3.70/day)
    5,631
    @leemerlord : Post a new thread in this section asking for WC purchasing advice. :toast:
