Water cooling vs air cooling ,which is better?
400 (0.29/day)
Likes
41
Lagos, Nigeria
System Name purplekaycee
Processor core I5 650 @3.2ghz. clarkdale 32nm technology
Motherboard intel DQ57TM (LGA 1156)
Memory 8 gb dual channel ddr3 @665 mhz
Video Card(s) gtx gigabyte 780 windforce oc 3gb edition
Storage 500 gb seagate ATA device,1TB Samsung ATA (SATA)device
Software Windows 10 64 bit
#1
Just purchased a core i7 7700k processor and would need serious cooling during gameplay and over clocking.
Which cooling method is better ?
9 (0.02/day)
Likes
1
Bucharest, Romania
System Name Bruno's
Processor i7-3770K
Motherboard Maximus V Gene
Cooling Noctua NH-U14S
Memory 16GB DDR3 1600
Video Card(s) Galax GTX 1050 Ti EXOC White
Storage 120GB Kingston SSD + 1TB Seagate HDD
Display(s) 3x Dell 2412
Power Supply Seasonic 750W
Mouse MSI DS200
Keyboard Microsoft Natural Ergonomic 4000
Software Win 10 x64
#2
First step for better cooling your 7700K is delid and change the thermal interface with better TIM, preferably liquid metal. That will give the CPU at least 20C lower temp on the cores.
Water cooling is better, but can be more expensive than air, for a better performance. Depends on your budget which cooling you are after.
Knoxx29
Xeon Owners Club
5,434 (3.37/day)
Likes
3,890
Behind a VPN
System Name Black Widow/Red Queen X3
Processor i7 8700K 5.0GHz 1.296V/ Xeon X5690 4.5 GHz 1.377
Motherboard Asus Rog Maximus X Hero / Evga X58 Classified 3
Cooling WaterChiller - both Machines looped
Memory G.SKILL Ripjaws V 3000MHz 32GB/ G.SKILL RIPJAWSX 2133Hz 12GB
Video Card(s) EVGA GEFORCE GTX 1080 CLASSIFIED/ Zotac 210
Storage Samsung 960 EVO - Samsung 850 EVO 250GB - WD Blue 1TB - WD Black 1TB/ Samsung EVO 250GB
Display(s) Asus PG278Q ROG/ Samsung
Case Cougar Panzer Max/ Lian Li
Audio Device(s) On Board
Power Supply Enermax Platimax 1000W 80plus platinum Super Overclock Edition ATX2
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard
Software Windows 10 Pro.
#3
I don' know who told you that or where you heard it but it's not true, @Bruno_oc is right about what he said, i have a 7700K 5.0 GHz 1.31V Delidded and cooled with a 280mm Rad that it's looped to a Waterchiller but used just when doing Benchmarks, that said, do you need a serious Watercooling? not really.
9 (0.02/day)
Likes
1
Bucharest, Romania
System Name Bruno's
Processor i7-3770K
Mouse MSI DS200
Software Win 10 x64
#4
For air, I recommend Noctua NH-U14S or NH-D15, if you have the budget for the later. On Amazon, they are 68EUR, respectively 89EUR.
For water, first check if your case supports radiators.
I've found Cooler Master Seidon 240 at 58EUR, which should be a good deal.
7,770 (2.56/day)
Likes
2,037
Jakarta, Indonesia
System Name micropage7
Processor Intel G4400
Motherboard ASUS STRIX
Cooling Deepcool Ice Edge
Memory 8 Gb Team Delta 2
Video Card(s) Radeon R250
Storage Seagate 1 TB, 4Tb and SSD A-Data 128 Gb
Case Icute Super 18
Audio Device(s) Stock
Mouse A4Tech X7
Software Win 10 64-bit
Benchmark Scores Classified
#5
back to your $$$$
liquid cooling especially custom loop with many rads or bigger rads give you room for better heat handling, air cooler i feel it looks like hitting the wall, they are limited coz the size, the weight and at certain points close to liquid cooling
6,373 (1.68/day)
Likes
3,516
S.E. Virginia
System Name Barb's Domain/Barb's Cruncher#2
Processor i7 3930k@3.8ghz/i7 860 @ 3.3ghz
Motherboard ASUS Rampage IV Black Edition/Gigabyte P55-UD3R
Cooling Deep Cool Assassin/Corsair A50
Memory 16gig DDR3 1600/4gig DDR3 1600
Video Card(s) GTX 1070 /MSI HD7770
Storage 500GB WD Blue SSD, 2TB Seagate Hybrid SSHD/ WD Caviar Blue 160gb
Display(s) HP ZR30W 30" 2560*1600/SOYO Topaz S 24" 1920*1200
Case SilverStone Fortress FT04/NZXT Source 210 Black
Audio Device(s) Logitech Z533
Power Supply XFX 750W XXX edition/PC Power Cooling Turbo Cool 860
Mouse Logitect G5
Software Windows 10 Pro 64 bit /Windows 7 Ult 64 bit
Benchmark Scores https://www.3dmark.com/fs/14508101
#6
Custom water cooling will always yield the best cooling performance
AIO water cooling yields about the same, maybe a little bit better, cooling performance as high-end air heatsinks
High-end air heat sinks perform almost the same as AIO water coolers, but are less likely to have a part fail (only thing that can fail on a air heat sink is a fan, which can easily and inexpensively be replaced. AIO water coolers can have fans, pumps and seals that can go bad)
IMHO, unless you are going for a very high 24/7 OC, a high-end air cooled heat sink is all that is needed to keep your CPU at proper running temperatures.
12,355 (3.96/day)
Likes
6,904
Ohio
System Name Daily Driver
Processor 7960X 4.5GHz 16c/16t 1.17V
Motherboard MSI XPower Gaming Titanium
Cooling MCR320 + Kuplos Kryos NEXT CPU block
Memory GSkill Trident Z 4x8 GB DDR4 3600 MHz CL16
Video Card(s) EVGA GTX 1080 FTW3
Storage 512GB Patriot Hellfire, 512GB OCZ RD400, 640GB Caviar Black, 2TB Caviar Green
Display(s) 27" Acer Predator 2560x1440 144hz IPS + Yamakasi 27" 2560x1440 IPS
Case Thermaltake P5
Power Supply EVGA 750W Supernova G2
Benchmark Scores Faster than most of you! Bet on it! :)
#7
lol, that depemds on the heatsink and water. Water can cool better...again, it depends. See barbaric soul's post.
this.
I wouldnt delid unless you have to...chances are it can drop 10c or so (20c is BS or a fringe case). But it isnt for everyone.
10,633 (3.42/day)
Likes
7,448
Oregon
System Name Delta // Alpha-HTPC
Processor Intel i7 6700K // Intel i5 4570
Motherboard GIGABYTE Z270X-Gaming K7 // Gigabyte H97M -D3H
Cooling Corsair H80i V2 // Silverstone NT-06 Pro
Memory Corsair DDR4 3000 32gb //G.SKILL Ripjaws X Series 8GB 1600
Video Card(s) EVGA GTX980ti// EVGA GTX 1050ti
Storage Samsung 950 Pro 512, 2 Tb FireCuda// Samsung 850 Pro, Synology NAS with 2X Toshiba 6Tb
Display(s) ASUS PB278Q 27" 1440X 2560 // 50" Samsung Plasma 720p
Case Corsair Obsidian Series 550D // Silverstone Granada GD05
Audio Device(s) ASUS Xonar DGX // HDMI to Yamaha RX V571
Power Supply Corsair TX850M // SeaSonic G Series 550w
Keyboard Corsair K70
Software Windows 10 64bit // Windows 7 64bit with Kodi
#8
For most people ether one is adequate for moderate over clocking. Deliding and custom loops are not for most people.
9 (0.02/day)
Likes
1
Bucharest, Romania
System Name Bruno's
Processor i7-3770K
Mouse MSI DS200
Software Win 10 x64
#9
@EarthDog, it is not BS.
I delided 6x 6700k and all gain around 16-18C core temp. 7700K is even worse. Mine gain 26C after delid.
TIM used: Gelid GC Extreme. Liquid metal may gain another 2-3C.
All test were done using custom water cooling with 560mm radiator.
12,355 (3.96/day)
Likes
6,904
Ohio
Case Thermaltake P5
#10
If you gained that much, something else was wrong. Either the mount or something was off. That is not REMOTELY common to see 20C drops. 10C give or take a few is about right.
9 (0.02/day)
Likes
1
Bucharest, Romania
System Name Bruno's
Processor i7-3770K
Mouse MSI DS200
Software Win 10 x64
#11
12,355 (3.96/day)
Likes
6,904
Ohio
Case Thermaltake P5
#12
It's not 20C bad for most. As I said, fringe case. Expect 10C. If you get more than that......... greaaaaaaaaaaaaaaaaaat. :)
4,474 (1.23/day)
Likes
1,097
Clifton Park, NY
System Name [Uber Noober Setup]
Processor [i7 3770K]
Motherboard [MSI P67A-G45(B3)]
Memory [32GB Corsair Vengeance (8GBx4)]
Video Card(s) [EVGA GTX 1080]
Storage [128GB OCZ VTX4 SSD, 2TB Internal HDD]
Display(s) [2x 27" ASUS at 1920x1080p - 1x 34" Samsung at 1440p]
Case [Coolermaster CM 690]
Audio Device(s) [X-Fi XtremeGamer]
Power Supply [CORSAIR 850W]
Software [Windows 10 64-Bit]
#13
A good air cooled will work fine and wont have the potential headaches of water.
Hell if you run stock clocks you can get away with a stock cooler.
1,476 (0.42/day)
Likes
660
Processor 3930K
Motherboard Asus X79 DELUXE
Cooling WATER
Memory 16GB 2133 G skillz
Video Card(s) Asus 2 X 780TI DCII OC
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
#14
Knoxx29
Xeon Owners Club
5,434 (3.37/day)
Likes
3,890
Behind a VPN
#15
That is not REMOTELY common to see 20C drops, It's not 20C bad for most. As I said, fringe case. Expect 10C. If you get more than that......... greaaaaaaaaaaaaaaaaaat. :)
Let me join this Conversation.
Do you remember back at the end of 2016 or beginning 2017 ( I don't remember exactly when it was ) when i Delidded my 7700K, temps dropped 20+? you are witness when that happened.
I wouldn't waste my money buying a 7700K and run it at stock;) Ops, sorry i forgot that's me.
It is boring to set an Aircooler on your CPU and you are done, fun begins when you build a custom Watercooler:D
12,355 (3.96/day)
Likes
6,904
Ohio
Case Thermaltake P5
#16
Again, typically those type of drops are not COMMON. It is MUCH MORE typical to see ~10C drops on chips. 20C is not the norm. And because a couple of people saw 20C and others have links, doens't make it common. I can google plenty of delid threads where ~10C was the norm. We can take turns pissing on one offs or realize that 20C isn't common and move forward. ;)
Knoxx29
Xeon Owners Club
5,434 (3.37/day)
Likes
3,890
Behind a VPN
#17
peche
Thermaltake fanboy
6,570 (4.86/day)
Likes
5,400
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
#18
infrared
4,471 (0.93/day)
Likes
2,196
Southampton, UK
System Name Raisin
Processor Ryzen 7 1800X 4.15GHz @ 1.44V (or 4.0 @ 1.33V for WCG)
Motherboard Asus Crosshair VI Hero <3
Cooling 2x 240mm rads, Corsair ML fans, EKWB pump/res and GPU block. XSPC Raystorm pro CPU block
Memory G.Skill TridentZ DDR4-4266 16GB @ 3466-3600MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W. 2088mhz
Storage Samsung 960 Evo 500GB + Corsair 120GB ssd (linux) + WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 165hz 1440P
Case Phanteks Enthoo Pro
Audio Device(s) Phillips Fidelio X2 headphones
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0
Software Win 10 & Linux Mint 18.3
Benchmark Scores https://hwbot.org/user/infrared
#19
You're more likely to de-lid if you're on the worse end of the temp scale imo. My 6700k dropped 20c, but then it was up in the 80's with watercooling so it was an unusually bad cpu. People with already good temps won't (or shouldn't) bother de-lidding. We just need to make sure people understand that there is a variance, not everyone will get the same result. I think it's fair to say expect ~10c, anything more is a bonus.
And to back peche up, if you're gonna de-lid, use liquid metal. If you're gonna void the warranty you might as well get the most benefit.
Edit: We need to hear back from the OP, even a budget aftermarket air cooler will probably be sufficient.
676 (0.24/day)
Likes
340
#20
It's very common to drop 20c on skylake and kabylake. The drop on coffeelake is half that. My delid dropped 20c, Kyle's review at [H] dropped 20c. The only one in disbelief is you.
Knoxx29
Xeon Owners Club
5,434 (3.37/day)
Likes
3,890
Behind a VPN
#21
peche
Thermaltake fanboy
6,570 (4.86/day)
Likes
5,400
System Name Athenna
#23
+ 1, there is no exact number when it comes to delid, the most popular drop is like 10-15c beyond that you will be part of the "Lucky-People" of this realm,
Regards
42,800 (9.76/day)
Likes
18,715
Processor i7 8700K
Motherboard Asus Maximus Hero X WiFi
Cooling Water
Memory 16GB G.Skill 3200Mhz CL14
Video Card(s) GTX 1080
Storage SSD's
Display(s) Nixeus EDG27
Case Thermaltake Core X5
Audio Device(s) Soundblaster Zx
Power Supply Corsair H1000i
Mouse Zowie EC1-B
#24
Water cooling = Better.
Air Cooling = Easier. Generally less to mount.
peche
Thermaltake fanboy
6,570 (4.86/day)
Likes
5,400
System Name Athenna
#25
I disagree. Liquid metal will void the warranty, but using a good TIM (with the same color as Intel's :p) and a good silicon to relid, will keep your warranty. ;)
give your facts straight bro, since you took IHS apart you are voiding your warranty....
Just have my morals and ethics in order. You delid, you obliterate the warranty. :)
all my respect.....with this...
