Watercooling AIO pump speed on a curve ?
Asryan
9 (0.90/day)
Likes
0
#1
I have an Eisbaer LT 360 which performs well. Though, at 100% i can hear the pump buzzing a bit, not a lot but since my rig is pretty silent, I find it annoying.
I read somewhere, I don't remember where that AIO pumps were supposed to run 100%...
In the bios, i set up a curve for the pump. Now, untill 45c, it rune at 75% and then goes up to 100% at 50c
Will that somehow hurt the AIO ?
Thanks
5,048 (0.99/day)
Likes
2,099
Canuck in Norway
System Name Hellbox 3.0(same case new guts)
Processor i7 4790K 4.6
Motherboard Asus Z97 Sabertooth Mark 1
Cooling TT Kandalf L.C.S.(Water/Air)AC Cuplex Kryos CPU Block/Noctua
Memory 2x8GB Corsair Vengance Pro 2400
Video Card(s) Sapphire Nitro+ Vega 64
Storage WD Caviar Black SATA 3 1TB x2 RAID 0 2xSamsung 850 Evo 500GB RAID 0 1TB WD Blue
Display(s) Samsung CGH70 27” 1440 144hz Freesync 2 HDR
Case TT Kandalf L.C.S.
Power Supply Seasonic X-1050W 80+ Gold
Mouse G502 Proteus Spectrum
Keyboard G19s
Software Win 10 Pro x64
#2
Thanks
No as long as it’s not effecting your cooling performance there’s no reason you can’t slow it down if it has the means to do so.
Asryan
9 (0.90/day)
Likes
0
#3
So i can make a custom curve with lower speed on idle and higher on heavy tasks / gaming?
5,048 (0.99/day)
Likes
2,099
Canuck in Norway
Keyboard G19s
#4
If the pump is allowing you to chage the RPM there’s no reason you can’t. Mine runs top speed all the time with no means to slow it down. I know some If the earlier AIOs had knobs right on the pump to adjust the speed. If you can control via the BIOS all the better.
5,048 (0.99/day)
Likes
2,099
Canuck in Norway
Keyboard G19s
#6
1,129 (0.84/day)
Likes
662
Long Island
#7
I generally control pump speed via the Motherboard utility. In this build it's FanXpert which is part of the Asus utility
Channel 0
CPU Fan Header => Pump No. 1
CPU Opt Header => Pump No. 2
Channel 1
CHA_1 Header => Fan PCB No. 1 => (6) 140mm Fans on 3 x 140mm 45mm Radiator
Channel 2
CHA_2 Header => Fan PCB No. 2 => (4) 140mm Fans on 2 x 140mm 60mm Radiator
Channel 3
CHA_3 Header => Fan PCB No. 3 =>(6) 140mm Case Fans
