Waterfox (Firefox 64bit) blocks M-Lab's speedtest
7,539 (1.04/day)
System Name Lynni Zen | Lenowo TwinkPad L14 G2 | Tiny Tiger
Processor AMD Ryzen 7 7700 Raphael | i5-1135G7 Tiger Lake-U | i9-9900k (Turbo disaabled)
Motherboard ASRock B650M PG Riptide Bios v. 3.20 AMD AGESA 1.2.0.3a | Lenowo BDPLANAR Bios 1.68 | Lenowo M720q
Cooling AMD Wraith Cooler | Lenowo C-267C-2 | Lenowo 01MN631 (65W)
Memory Flare X5 2x16GB DDR5 6000MHZ CL36 (AMD EXPO) | Willk Elektronik 2x16GB 2666MHZ CL17 | Crucial 2x16GB
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris Xe Graphics | Intel® UHD Graphics 630
Storage Gigabyte M30 1TB|Sabrent Rocket 2TB| HDD: 1TB | WD RED SN700 1TB | M30 1TB\ SSD 1TB HDD: 16TB\10TB
Case Asus Prime AP201 White Mesh | Lenowo L14 G2 chassis | Lenowo M720q chassis
Power Supply Be Quiet! Pure Power 12 M 750W Goldie | Cyberpunk GaN 65W USB-C charger | Lenowo 95W slim tip
yesterday when i wanted to test my connection on http://www.measurementlab.net/run-ndt i found out the site is blocked but it works fine in IE and i put in *.measurement-lab.org into Waterfox's expections... under security but that's not working i keep getting this "Application Blocked" popup how can i fix this?
hmm apparently it's java settings, bcs if i turn Java security settings down to medium i get my run popup and at very high i don't :mad:
*spanks java for being lame :nutkick:*
No probs running it .....
java 7 update 21 (x64)
Would you rather that it let malicious Java run on your computer no matter what? I would rather be more careful than less careful when it comes to Java. This is nothing to get angry or upset about, quite the opposite in fact.
i r on Windows 8 i am on 7 and i am using both x64 and x86 of Java 7 update 21...
I use Cyberfox and Java 7 U21 and I have no problem with this.
The problem is in the browser so try reinstall with cleaning everything data.
Also you can try Cyberfox. It's much better than Waterfox.
not a waterfox setting problem bcs i have been using the site before java got all crazy with blocking everything...
Using FF 20.0.1.
I do not have Java installed, and the test will not run.
So, I would agree with the others, it is probably a Java thing.
From what little I could read of your comments I got the idea that you started giving less of a crap about what Java code runs on your computer, which is a really stupid idea. I suggest you uninstall Java, avoid anything that uses it, and get on with your daily life.
I think it's a Java security setting as it works fine for me in Waterfox.
Proof:
It sounds like what you need to do is loosen up your Java security settings. Open up Java in your Control Panel and click the security tab. Mine looks like this.
Aquinus yap as i said in my second post, i needed to change java settings, and today i heard there won't be any more Java 7 updates if something major don't happen, the only Java release that will come would be version 8.
