Weirdest PC Issue I've Run into...I need help
39 (0.05/day)
Likes
25
Sydney, Australia
System Name Main Gaming Rig
Processor Intel Core i7 4770K @ 4.4Ghz 1.20V
Motherboard ASUS Maximus VI GENE Z87 Motherboard
Cooling NZXT Kraken X52 in Push Config & 3 Corsair AF140 Case Fans
Memory Corsair Vengeance Pro CMY16GX3M2A1600C9R 8GB (2x8GB) DDR3 x 2
Video Card(s) Asus Strix GTX 1080Ti ROG-STRIX-GTX1080TI-O11G-GAMING
Storage 2 x 1TB Samsung 850 Pro SSD / Seagate Barracuda 2TB ST2000DM001
Display(s) Asus PB278Q 27” 16:9 2560x1440 WQHD
Case Corsair Obsidian 350D with Window
Power Supply Corsair AX860i Platinum Power Supply /w Red Sleeved Cabling
Mouse Razer DeathAdder Chroma
Keyboard Razer Blackwidow Chroma v2
Hey guys,
Long time lurker, first time topic poster here (I will also apologize for the wall of text but please stick with me). I am trying to be a good grandson and have been handed my grandparents PC that's having the weirdest issue I've ever run into. What I'll do first is give you the full specs of the system:
Case: InWin Dragon Slayer mATX
PSU: Corsair AX650 80 Plus Gold
Mobo: ASUS Maximus IV Gene-Z/GEN3
CPU: Intel Core i7 2600K
CPU Cooler: Coolermaster Hyper212 EVO
RAM: 4 x Corsair CML16GX3M4A1600C9 DDR3 = 16GB
GPU: EVGA GTX580
HDD: Samsung 1TB HDD w/ Win 10 Pro
ODD: Liteon DVD-RW
Wireless Card: TP-Link TL-WDN4800
Now, onto the issue...bare with me if my explanation is a bit convoluted but I'll do my very best to make sense.
I'll start with an original issue that the machine was having a little while ago that made me need to check it out the first time. So the PC was supposedly experiencing shut down problems (I wasn't given clear information at the time, which is typical) but I pretty much brought the PC home and when I tested it, the rig would start up fine, run and be all sweet. I stress tested it at that time and it all seemed ok. Then when I shut the machine down, just at the moment the fans stopped spinning, specifically the CPU cooler fans, the machine would suddenly start up again. I was racking my fucking brain for days thinking what it may be. I completely dismantled the rig onto my kitchen table and just tried running it as an open air bench. Issue still happened, I was like wtf (I originally thought it was a PSU issue but I tested the rig with a 100% known good PSU & issue still persisted). Eventually I got the idea in my head to swap out the CMOS battery. Lo and behold, that fixed the problem. I was amazed. So I thought great, it can go back to them all happy. Machine was behaving correctly.
This ended this past weekend where they told me the PC was randomly shutting down, and when it did, it wouldn't power back on. Pushing the power button on the case has no effect. I was told that they had to wait like 2 hours before the system would start up again via the power button.
I was like wtf so I brought the rig home again, plugged it in, it switched on fine and seemed ok. Ran a few games, surfed the net, ran Unigine Heaven for a bit and was ok. I then turned it off and tried to switch it back on again. The rig would not switch on. Neither via the case power button or via the mobo "Start" button on it. I briefly checked to ensure all cables were connected correctly and they are since the last time an issue happened, I rebuilt the whole rig and cleanly managed cables and made sure all was hooked up properly.
I've just spent the last day looking blankly at the PC trying to think of what to do to try and fix this issue without needing to spend any money at the moment lol.
I'll welcome any feedback or suggestions because in all my time working on PC's, what this machine is doing does not make sense. If you need any more information from me, let me know and I'll post as soon as I'm able to.
Again, sorry for the wall of text but I would very much appreciate any assistance from this awesome, and knowledgeable, community.
39 (0.05/day)
Likes
25
Sydney, Australia
Sounds like a Power issue with the PSU
Inspect the PSU/Motherboard Connectors( both the 4+4 and the 24 pin )
for signs of Arcing/burning/overheating
See, the last time this rig had issues, I borrowed a work friend's 100% working PSU but the issue that it was having at the time still persisted. I even took the PSU from the problem PC to work and tried it in a rig there and it worked fine. I originally suspected a bad PSU but this test made me say ok, no, it's not that. I'll take a look at the cables though...
Edit: Ok so I've looked at the cables, the pins look clean & gold. No signs of melting or burns or the like.
2,737 (0.87/day)
Likes
935
System Name Xtreme PC's AMDx8
Processor AMD FX8320 @ 4.0GHz NB/HT @ 2.6GHz
Motherboard Asus Crosshair V Formula
Cooling ThermoLab Baram 2x 120mm Gentle Typhoons 1850rpm
Memory 8GB (2x4GB) Mushkin Blackline DDR3 2400MHz 11/13/13/34/1T 1.65V
Video Card(s) Sapphire Nitro+ RX580 8GB OC 1342/2000 (Core/Mem) BIOS Modded
Storage 2x Kingston V300 120GB SSD's Raid0: 1x Sandisk 128GB SSD 1xWD 2TB red, 1xWD 1TB black 1xWD 2TB nas
Display(s) ViewSonic VX2457 75Hz FreeSync 1920x1080p
Case SilverStone Raven RV02B-W + 3x SS AP181 + USB3.0 upgrade
Audio Device(s) Creative SB X-Fi Titanium Fatal1ty Pro PCIe + Pioneer VSX-D457 amp Technics Speaker set
Power Supply SilverStone ST75F-P Modular 750W
Keyboard Logitech G105
Software Windows 10 X64 PRO (build 1803)
Benchmark Scores it sucks even less much now ;)
#4
Also for the power off and starts straight back up issue check the BIOS for resume on power off make sure it's set to remain off some BIOS's come with it set restart computer
dorsetknob maybe onto something with it being a PSU problem if you unplug the PSU from the power socket wait a few minutes and plug it back in does it then start up if yes it was the PSU going into a protect mode during the shutdown sequence for some reason
39 (0.05/day)
Likes
25
Sydney, Australia
That issue with the machine turning back on again stopped last time after I replaced the CMOS battery (for some weird reason, but it did). I guess I'll need to try another PSU again now to see if the machine reacts the same.
6,486 (4.52/day)
Likes
3,852
Sunshine Coast
System Name Black Box
Processor Intel Xeon E5-2680 10c/20t 2.8GHz @ 3.0GHz
Motherboard Asrock X79 Extreme 11
Cooling Coolermaster 240 RGB A.I.O.
Memory G. Skill 16Gb (4x4Gb) 2133Mhz
Video Card(s) Nvidia GTX 710
Storage Sandisk X 400 256Gb
Display(s) AOC 22" Freesync 1m.s. 75Hz
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Software W10 Home Premium 64 bit
#6
Have you tried disabling the Asus anti-surge in the BIOS?
6,208 (1.35/day)
Likes
1,820
New York
System Name http://www.heatware.com/eval.php?id=73751
Motherboard i7-920 CO@4.2GHZ/MYSTERY P6T Deluxe Intel X58
Cooling MYSTERY Liquid CPU Cooling System
Memory MYSTERY DOMINATOR 6GB (3 x 2GB) DDR3 1600
Video Card(s) 2X ATI Radeon HD 4870 X2 2GB DDR5 PCI-Express
Storage (RAID-0) with 4 Identical Hard Drives (1.28TB (320GBx4)
Display(s) MYSTERY 50" 50PK550 1080p 600Hz Plasma/37 InchMYSTERY @1920x1080
Case MYSTERY e M9 (I hate it its like trying to live in a 1 inch box)
Power Supply MYSTERY ToughPower 1200 Watt
Software Windows 7 professional 64
#7
inspect the motherboard for a bad capacitor.
qubit
Overclocked quantum bit
15,505 (3.93/day)
Likes
9,129
Quantum Well UK
System Name Quantumville™
Processor Intel Core i7-2700K at stock (hits 5 gees+ easily)
Cooling Noctua NH-D14
Memory 16GB (4 x 4GB Corsair Vengeance DDR3 PC3-12800 C9 1600MHz)
Video Card(s) Zotac GTX 1080 AMP! Extreme Edition
Storage Samsung 850 Pro 256GB | WD Green 4TB
Display(s) BenQ XL2720Z | Asus VG278HE (both 27", 144Hz, 3D Vision 2, 1080p)
Case Cooler Master HAF 922
Power Supply Corsair HX 850W v1
#8
It sounds like hardware failure on the mobo and/or PSU. Yes, even though you've done the PSU swap tests it doesn't eliminate the possibility. Try another known good PSU again. I suspect the mobo more though.
I'll second drdna on the caps, too. Check for bulging caps, especially.
Another thing to try is a cmos ram clear by removing the battery and touching the pins on the mobo, as per the manual. It's surprising what weirdness this fixes sometimes. You can try this one first, as it's a quickie and costs nothing.
6,493 (1.39/day)
Likes
1,044
System Name money pit..
Processor Intel 8700K at 4800 mhz.. vcore 1.264 volts..
Video Card(s) Palit Super Jetstream 1070 x 2..
Storage Three.. all solid state 128 Transend.. 1 T Sandisk.. 1 T Transend.. plus USB external..
Case Gigabyte mid-tower.. cheap and not really big enough for what is inside..
Audio Device(s) USB Sound blaster Roar 2 all in one unit with bluetooth
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
Benchmark Scores 3Dmark Firestrike Ultra 8542.. Timespy 11508.. everyday settings..
#9
i recon its the motherboard going bad.. meaning maybe it needs replacing.. unless you love banging you head against brick walls.. ..
trog
5,553 (1.78/day)
Likes
1,946
Manchester uk
System Name Quad GT evo V
Processor FX8350 @ 4.6ghz1.435c NB2.44ghz Ht2.64ghz
Motherboard Gigabyte 990X Gaming
Cooling 360EK extreme 360Tt rad all push/pull, cpu,NB/Vrm blocks all EK
Memory Corsair vengeance 16Gb @1600 cas8
Video Card(s) Rx vega 64 waterblockedEK
Storage samsung 840(250OS), WD 1Tb+2Tb +3Tbgrn, 1tb seagate sshd hybrid(games)
Display(s) Samsung uea28"850R 4k freesync, LG 49" 4K 60hz ,Oculus
Case Custom(modded) thermaltake Kandalf
Audio Device(s) Xfi creative 7.1 on board ,Yamaha dts av setup
Power Supply corsair 1200Hxi
Mouse CM optane
Keyboard CM optane
Benchmark Scores 15.69K best overall sandra so far 6600 3dmark
#10
i agree with this but would add that actually jumpering the clear cmoss and leaving it overnight as opposed to a quick clear has worked for me before too(I had tried quick clear).
qubit
15,505 (3.93/day)
Likes
9,129
Quantum Well UK
#11
Doesn't hurt to do that, but I think the benefit varies from mobo to mobo.
I remember on my various Abit boards from a decade+ ago, it was enough to remove the battery and short the pins for a couple of seconds for a complete clear. But yeah, our OP has nothing to lose by taking the unhurried route. :)
26 (0.01/day)
Likes
1
Processor P D920 model 6 step 2 rev b1 @ 3730
Motherboard asus p5wd2-e premium rev 1.xx i975x rev c0
Cooling zalman 9500cu-led thermalright hr-05
Memory kingston Hyperx pc6400 cl5 512 x2
Video Card(s) asus en8800gts 640mb stock
Storage 3x 250gb 1 sata / 2 sata2 raid 5 (466gb volume)
Display(s) lacie electron blue 22"
Case termaltake matrix vx
Audio Device(s) onboard alc 88x
Power Supply raidmax 650w
Software win2000 pro sp4 (untill vista x64 works)
#12
open the window side of the chase. put a fan at side making airflow going full inside the chase and try again.
try withwow tplink wifi inside the chase.
applause when pc is running.
later all
39 (0.05/day)
Likes
25
Sydney, Australia
Ok, so, to wrap up this thread, you guys called it. Dodgy PSU. I tested using another known good PSU again and the machine booted up. I picked up a replacement Corsair RM650x and have whacked it in the system and it's all good now. Boots up, runs and seems fine now. So annoying though, especially since I tested the PSU about a month or two ago and it was all good. Ahh well, these things happen I guess. Thanks to everyone for your input and advice. It's much appreciated!!
6,486 (4.52/day)
Likes
3,852
Sunshine Coast
#14
Like I mentioned earlier in the thread, the Asus anti-surge setting in the BIOS can and will cause this type of behaviour if the PSU is not performing within it's specified range.
8 (0.06/day)
Likes
0
#15
Hi Kids!. @Devastator0 that doesn't seem like a grandparents type of pc at all. Well, except for the mechanical hdd. Otherwise it looks more like a young kids computer!. Young at heart I guess!. Wondering if you sent in the PSU for an RMA. Corsair has excellent warranty/rma service in my experience. In fact, I just looked that model up and it has a 7 year warranty.
39 (0.05/day)
Likes
25
Sydney, Australia
I'll be sure to keep that in mind going forward. I'll monitor how the machine goes with the new PSU for a few days and make the appropriate changes from there. Thanks again for your feedback/suggestion mate :)
39 (0.05/day)
Likes
25
Sydney, Australia
Yeah, it is actually my grandparents rig, Grandfather plays Fifa & a number of racing games. I cobbled it together years ago with parts I had lying around and some people have donated equipment to it, such as the GPU. As an example, the rig originally had a 560, but a friend gave me his 580 when he upgraded. As for the PSU, yeah, I'm aware of the 7 year warranty, but I needed to get the PC up and running quickly. I'm not even sure as to when I originally purchased it so it probably is out of warranty by now.
815 (0.63/day)
Likes
495
#18
The 650AX was built on Seasonic's X series platform and came out in mid 2012 IIRC.... understanding that ya needed to get it up and running, I'd RMA it anyway and keep the replacement as a standby for just the reason that ya needed one here.
189 (0.04/day)
Likes
97
Nashville, Tennessee
System Name DeathAdder
Processor Intel Core i7 6700K @4.6 Ghz 1.31v
Motherboard Gigabyte Gaming 7 Z170X
Cooling NZXT Kraken x61 280mm
Memory 2x8GB G.Skill 3200Mhz
Video Card(s) MSI NVidia GeForce 980 Ti 6GB
Storage Samsung 850 EVO 500 GB + 10 TB in HDDs
Display(s) LG UC87C 34" Ultrawide 3440x1440
Case NZXT H440 White
Power Supply EVGA P2 Platinum 1000 W
Mouse Corsair M65
Keyboard Corsair K70 RGB
The most common reason for this problem is a short on the motherboard. And usually its a case that is shorting the pins behind the motherboard.
I would boot using just the motherboard, CPU and RAM, and that also placed on a plastic bag.
If that is also not working, then try to update BIOS, clear CMOS, re-seat the CPU. Remove RAM, clean the contact points using a rubber eraser, and re-seat the modules.
If none of that works, then try a fail-safe boot - increase voltage to CPU by 0.05v, Don't use XMP timings for RAM, disable all onboard stuff like sound, ethernet, power management etc.
If even that doesn't work, then you've got a bad motherboard.
531 (0.61/day)
Likes
667
System Name BOX
Processor Xeon E5-1680 v2 @ 4,3GHz
Motherboard Sabertooth X79 (BIOS 4801 + NVMe mod + uCode update)
Cooling Thermalright Venomous-X (w/LGA 2011 kit) + 2x Delta PWM Push-Pull
Memory 8x A-Data Xtreme 2000X 2GB (1868MHz CL8.9.8.24 CR2T @ 1,65V)
Video Card(s) ASUS GTX 1080 (FE)
Storage Samsung SM961 256GB NVMe, RAID0 2x WD10EZEX (1TB), HGST HUS726060ALE610 (6TB)
Display(s) Samsung T240
Case NZXT Tempest (Nanoflux/PWM fans only, some w/LEDs)
Audio Device(s) ASUS Essence ST Deluxe 7.1
Mouse Roccat Savu
Keyboard Logitech UltraXPremium
Benchmark Scores https://www.passmark.com/baselines/V9/display.php?id=108080818886
#21
Are all MB standoffs installed (and those that are, do not flex installed board in any way) ?
