- Sep 3, 2019
- 2,980 (1.76/day)
- Thessaloniki, Greece
System Name | PC on since Aug 2019, 1st CPU R5 3600 + ASUS ROG RX580 8GB >> MSI Gaming X RX5700XT (Jan 2020) |
Processor | Ryzen 9 5900X (July 2022), 150W PPT limit, 79C temp limit, CO -9~14 |
Motherboard | Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B |
Cooling | Arctic Liquid Freezer II 420mm Rev7 with off center mount for Ryzen, TIM: Kryonaut |
Memory | 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:288, B-die |
Video Card(s) | Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (387W current) PowerLimit, 1060mV, Adrenalin v24.3.1 |
Storage | Samsung NVMe: 980Pro 1TB(OS 2022), 970Pro 512GB(2019) / SATA-III: 850Pro 1TB(2015) 860Evo 1TB(2020) |
Display(s) | Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on |
Case | None... naked on desk |
Audio Device(s) | Astro A50 headset |
Power Supply | Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch) |
Mouse | Logitech MX Master (Gen1) |
Keyboard | Logitech G15 (Gen2) w/ LCDSirReal applet |
Software | Windows 11 Home 64bit (v23H2, OSB 22631.3155) |
Those same educated engineers (and not our groceries salesman) thought that when its not really needed the fan can stop. So the "specifically" in your sentence is simple your opinion and not the reality.Power supplies are engineered specifically to be used with a fan by formally educated electrical, computer, and thermal engineers, designers, manufacturers, and software developers.
10hours of typical and some idle operation at 25C room temp. Do I need to start the fan? Is the PSU going to burn at 45C or even wear out?
Is the 15W avg (Input minus output power) or even the peak 20W heat going to heat up the rest of the system?
Same time and same environment for the GPU.
I guess 40-45C is too much... for something that that has a Tjmax close to 100C
FYI the same GPU under the same operating and environment conditions dumps the same amount of heat into the case with its fan spinning or with it stopped.
