what can cause pc to power up for a second, then power itself off?
Discussion in 'General Hardware' started by ny_driver, Dec 17, 2009.
  1. ny_driver
    ny_driver New Member
    Dec 28, 2006
    777 (0.20/day)
    28
    central new york
    it was doing it yesterday when I first got it, but then that ceased to happen. I finally got it programmed with OS and stuff, then today I had a bad flash, took it all apart, then decided to try to recover the bios before getting a new chip, put it back together, and now it's doing this again. It's only powering up by the switch on the PSU also, which it was also doing yesterday at first.
    Another day, another problem.........
    10 Year Member at TPU
  2. TheCrow
    TheCrow New Member
    Mar 8, 2007
    398 (0.10/day)
    55
    Lincoln, UK
    Sounds like a short on the power switch to the chassis (case).
    Try unplugging the power switch from the board and see if it does it then. You can switch the pc on by just shorting the two contacts where the power switch plugs in.
  3. suraswami
    suraswami
    Apr 5, 2005
    6,548 (1.46/day)
    1,117
    Republic of Asia (a.k.a Irvine), CA
    Did u pull out the motherboard from the case? If so did you put the mobo risers on the case or is the mobo mounted on the small ant hills?
  4. ny_driver
    Dec 28, 2006
    777 (0.20/day)
    28
    central new york
    I didn't personally mount the mobo, but it looks like it's just on the metal anthills. I'm listening....
    I'm checking the possible short also. EDIT: It's not starting off the power switch or shorting the 2 pins together, only starts when I flip the PSU switch.
  5. ny_driver
    Dec 28, 2006
    777 (0.20/day)
    28
    central new york
    It appears to have been the PSU. It was quite a chore to get the one out of my personal system, but it powered this Neo2 right up, and my bios recovery floppy disk worked too....I'm very happy. I'm on the Neo2 right now!! Thanks for the suggestions guys. Have a Merry Christmas.
