what is going on with my L3 Cache speed 46GB/s instead of over 650GB/s (5800X)
1,201 (0.92/day)
London, UK
Yeah OC'ing Ryzens is kinda meh, I just have PBO +200 on my 3600 instead of manual OC. Boosts up to 4300 nicely.
I never used pbo, always manual overclocking, people used to say that pbo is bad, I guess it might have been in the past, they may have fixed some issues it had when it came out, going to try that , thanks.
Maenad
S.T.A.R.S.
6,581 (2.01/day)
Jyväskylä, Finland
System Name Mah buddy
Processor AMD Ryzen 5 3600 @ PBO +200
Motherboard Gigabyte B550M Aorus Elite
Cooling Modified Alphacool Eisbaer 240
Memory 32GB HyperX Fury DDR4-3200 @ 3466 16-18-18-36-1T
Video Card(s) Gigabyte GeForce GTX 1080 Ti Gaming OC Black @ +100/625
Storage 256GB SSD + 3x 480GB SSD + 2TB USB HDD
Display(s) Viewsonic VA2465S (24" 1080p VA) + Dell P2412H (24" 1080p TN)
Case Fractal Design Define Mini C
Audio Device(s) Onboard audio, Superlux HD668B
Mouse Logitech MX518 Legendary
Keyboard Dell Multimedia Pro
VR HMD Oculus Rift CV1
Software Windows 11 Pro English
I guess people think that it's bad as it uses high voltages but in light loads = no worries. If it would use those 1.4V+ on heavy loads, we would had hella lot of dead Ryzens. :D
edit: This went at 4400 without problems but I rather use PBO..
5,624 (1.40/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 5950X
Motherboard ASUS Strix X570-E
Cooling Custom Loop. Two 360ies + 280 rad. 8x Nidec Servo Gentle Typhoons. EK-Quantum Momentum monoblock.
Memory 4x8GB Corsair Vengeance LPX 3000MHz 15-15-15-36 CR1[16-18-18-32-50;TRFC560@3200MHz]]
Video Card(s) ASUS 1080 Ti FE + water block
Storage Optane 900P + Samsung PM981 NVMe 1TB + 750 EVO 500GB
Case Phanteks Enthoo Evolv ATX Tempered Glass
Mouse Razer Basilisk
Software Windows 11 insider
Well for what is worth, cpu is at default settings, no overclocking at all. I used to let it overclocked to 4.5ghz all cores but as I needed a better single core performance, so I let mine 5900x at default to get up to 4.8ghz.
These days there are no no overclocking as such, the the board and CPU always does it for you and is included by default and you call it boost, thus the updates are even coming. Leaving Auto often introduces unwanted results.
Ryzen OC is done normally only with PBO, otherwise you break all the thing that makes the CPU better, most just doesn't know how to do it, because it takes hell of a lot of time to do per core adjustments.
Thinking that default is default for certain motherboard makers is utterly wrong. Some do even overvolt the CPU for the sake stability and less RMA or notoriously stupid VRM design as it is slow to react, it is very board specific and each has to find their own solution.
1,201 (0.92/day)
London, UK
Funny, not sure if is an issue, but on windows 10, my 5900x used to get up to 4.8 but in windows 11 it only reaches 4.6 max, just checked, temperature is at 62c, there is no reason to hold it back like that. I will try pbo then.
5,624 (1.40/day)
Rīga, Latvia
Known issue dude... do you read the news? UEFI CPPC2 (“preferred core”) does not work for now. Welcome to the extended beta test.
You can blame The beta testers who don't properly report and file problems to Microsoft as the problem didn't gain enough traction during the Win11 preview.
1,201 (0.92/day)
London, UK
Yeah I read that, even though I read that, I completely forgot about that. When you said it, I then remembered it, reason I said if motherboards manufactures issued a new bios in order to fix that, I had checked mine and the bios is not out yet. So basically right now, manual overclocking is the best case scenario in my case. I have been playing overclocking it manually, got up to 4.6ghz 1.25 all cores, better than default for sure, anyway, doing some stability tests.
42 (0.07/day)
3rd world sh1thole, AKA italy
System Name AMDream v1.8.0
Processor AMD Ryzen 5 5600X@PBO+Alphacool Eisblock XPX Clear
Motherboard Asus Prime B550-Plus
Cooling CPU+GPU custom loop, 2x240 slim rads, 4xEK Vardar Evo RGB+1x Arctic P12 PWM fans
Memory 2x8GB Crucial Ballistix Red RGB DDR4 3600@3866 15-18-13-35-59 1T
Video Card(s) AMD Radeon RX Vega 64 reference+EK block, OC/UV: 1065mV core,1100MHz@1030mV HBM
Storage 1TB Western Digital SN850+Eluteng NVMe heatsink
Display(s) LG 24ML600S+Dell VESA base
Case Aerocool Aero-800 White
Audio Device(s) Creative Inspire P380
Power Supply EVGA 650GQ
Mouse Steelseries Rival original (white), Steelseries Qck+ mousepad
Keyboard Arealer Roarer with white pudding keycaps (Long Hua blue switches)
Benchmark Scores 11150-1520 Cineb.R23, 4993 Superposition
Disclaimer: the 10 part of the photo is from around 3-4 months ago, and 3 UEFIs back. But it was the only one I had for 10, and subsequent UEFIs didn’t change the scores that much in 10.
As you can see, with my rig, my L3 is awful in write and copy, and bad in read and latency.
The thing is, BTW, I play at 1080p75 max settings, since my oldie but goldie Vega 64 can’t do more and I have a cheap monitor, and I didn’t notice anything strange in 11 vs 10.
EDIT: Despite having a prehistorically old Aida (for running both OSs with the same Aida), nothing significant changed with the latest one, same bad L3 results.
2,042 (0.53/day)
Greece
Processor AMD Ryzen 5 2600X@95W
Motherboard MSI B450 Tomahawk MAX
Cooling Deepcool Gammaxx 400 Black
Memory 2*8GB PATRIOT PVS416G373C7K@3333MT_C16
Video Card(s) Sapphire Radeon RX 5700 Pulse 8GB
Storage Sandisk SSD 128GB, Kingston A2000 NVMe 1TB, Samsung F1 1TB, Hitachi HUS724040ALE640 4TB
Case SHARKOON M25-W 7.1 BLACK
Power Supply Zalman Z550
Keyboard Trust GXT280
Software Win 7 sp1 64bit/Win 10 pro 64bit
Benchmark Scores CB R15 64bit: single core 173p, multicore 1306p
Why should you blame anyone but MS themselves? They named as win11 a major incoming update of win10. Win11 should work with all hw combos as well as win10 since they have the same kernel. MS changed something and totally broke the working almost well cpu scheduler ONLY for Ryzen CPUs and I am not sure it was an accident now that AL is around the corner. There is no excuse of this mess.
5,624 (1.40/day)
Rīga, Latvia
Imagine the zoo of hardware M$ has to test. It ain't closed walled Apple with few devices. It is hard to blame them.
They mostly code on VM's not on real machines. This specific bug exposes only on bare metal, the whole beta testing attitude is rather funny sometimes. Like whining in some random forum will ever help.
136 (0.17/day)
System Name Ryzen 1
Processor Ryzen 5800X
Cooling Scythe Fuma 2
Memory 32GB Patriot Viper 3600 CL16
Video Card(s) EVGA RTX 3060 Ti FTW3 Ultra
Storage SSD's
Display(s) Acer 32" 1440p 75Hz
Case Phanteks P400A
Power Supply Superflower Leadex III 750w
I have similar very poor L3 results with Windows 11. Is there a fix out soon or what? How does everyone not have the Trial version of AIDA64? Are you guys actually buying the software?
freeagent
3,032 (2.60/day)
Winnipeg, Canada
Processor AMD R9 5900X
Motherboard Asus Strix B550-F Gaming
Cooling Thermalright Frost Commander 2x iPPC 3000
Video Card(s) EVGA RTX 3070 Ti FTW3 Ultra
Storage WD SN750 1TB+500GB, 2x Intel 545s 256, WD1TB Black, 1TB Toshiba
Display(s) 22" Sammy, 55" Hisense
Case Fractal Design Meshify C
Audio Device(s) NAD, Mission, Monitor Audio
Power Supply Seasonic Prime GX-750, Zalman ZM-MFC2, Monster HDP1800
Mouse Zowie EC2 Evo
Keyboard Logitech G15
Software Yes
Benchmark Scores Yes
I’ve had a key for like 17 years.. :D
2,180 (1.51/day)
Buenos Aires, Argentina
System Name System V
Motherboard Asus Prime X570-P
Cooling AMD Wraith Stealth // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Storage SHFS37A240G / DT01ACA200 / WD20EZRX / MKNSSDTR256GB-3DL / LG BH16NS40 / ST10000VN0008
Case NZXT Source 210
Power Supply Corsair CX650M
Mouse Microsoft Trackball Optical 1.0
Keyboard HP Vectra VE keyboard (Part # D4950-63004)
Software Whatever build of Windows 11 is being served in Dev channel at the time.
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
freeagent
3,032 (2.60/day)
Winnipeg, Canada
Mouse Zowie EC2 Evo
Software Yes
350 (0.88/day)
Austria
System Name Old but Gold
Processor A8 5500 3,84GHz with 1,18V
Motherboard Biostar A68H
Cooling ZeroTherm BTF95 Full Copper
Memory Gskill 16GB DDR3 1939 MHz
Video Card(s) GT 710 2GB GDDR5 massive OC
Storage 480GB SSD, 500GB HDD
Display(s) Nec EA 241 WM
Case Nanoxia DS4
Audio Device(s) Onkyo ......
Power Supply Super Flower Leadx 550W
Mouse Steelseries Rival 3 Wireless
Keyboard Logitech K270 Wireless
Software Deepin, BSD and 10 LTSC
Poor L3 Cache 60-80 GB/s :laugh:
2,180 (1.51/day)
And I'd argue that to a point the blame rests mostly on the CEO and bean counters that decided to cut the resources for QA.
Yeah, that's strange as hell. Why or how they broke the Ryzen part of the scheduler I have no idea. It's too damn suspicious, and I don't really like to don the tinfoil hat or whatever.
And when I discovered the bug I reported it. Can't do much more than that, I'm not Nadella's neighbor.
350 (0.88/day)
Austria
Case Nanoxia DS4
Good a long time ago beta testers got money for that and now u got a temeltric OS and play for free beta testers, thanks to you all.
Greentings a Win 10 LTSC 1809 User (Without Consumer Temeletry, Cortana and Store crap) :peace:
700 (0.19/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 7 3700X with Fclk and Uclk at 1:1
Memory 16 GB Corsair Vengeance LPX 3000 in XMP mode
Video Card(s) MSI Gaming X Radeon RX5600XT
Storage Samsung 970 Pro 512 GB NVMe SSD
Display(s) Asus VG278QR
Case Corsair 275R
Mouse Logitech Pro (Hero)
Software Windows 10 Pro x64 21H1
It maybe be stable on stress, full load. Problems with bad OC using PBO that because Win11 doesn't boost the right cores it stresses out poor OC or even default motherboard settings that are often not so default at all, and not the instability on full load but on medium no or weak load, ie the voltage is not enough for some bad cores. Sudden death, without bsod is usually culprit for not enough voltage.
I often get "IRQL_NOT_LESS_OR_EQUAL" BSOD with not enough Vcore. Sometimes, it just crashes, like you said.
Mussels
Freshwater Moderator
51,775 (8.27/day)
Oystralia
System Name Rainbow Sparkles
Processor Ryzen R7 5800X (PBO tweaked, 4.4-5.05GHz)
Motherboard Asus x570 Gaming-F
Cooling EK Quantum Velocity AM4 + EK Quantum ARGB 3090 w/ active backplate. Dual rad.
Memory 2x32GB DDR4 3600 Corsair Vengeance RGB @3800 C18 TRFC704 (1.4V, SoC 1.15V Hynix MJR)
Video Card(s) Galax RTX 3090 SG 24GB: Often underclocked to 1500Mhz 0.737v
Display(s) Gigabyte G32QC (4k80Hz, 1440p 165Hz) + Phillips 328m6fjrmb (4K 60Hz, 1440p 144Hz)
Case Fractal Design R6
Audio Device(s) Logitech G560 |Razer Leviathan | Corsair Void pro RGB |Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Keyboard Razer Huntsman TE (custom white and steel keycaps)
VR HMD Oculus Rift S
Software Windows 11 pro x64 (Yes, it's genuinely a good OS)
Benchmark Scores I don't quite know how i managed to get such a top tier PC, I am not rich.
16,500 (3.16/day)
System Name Pioneer
Processor Ryzen R9 5950X
Motherboard GIGABYTE Aorus Elite X570
Memory G.SKILL TridentZ 32GB (4 x 8GB) @ DDR4-3600 (Samsung B-Die)
Video Card(s) EVGA GeForce RTX 3070 FTW3
Storage 2x Mushkin Pilot-E 2TB NVMe SSDs
Case Thermaltake Core X31
Audio Device(s) VGA HDMI->LG B9 OLED/Schiit Modi MB/Asgard 2 DAC/Amp to AKG Pro K712 Headphones
Power Supply EVGA SuperNova T2 Titanium 850W
Mouse Razer Deathadder v2
Keyboard 1991 IBM Model M (Second Generation White Label Part #1391401)
Software Windows 11 Enterprise (yes, it's legit)
To all the people still making a fuss about this:
AMD Ryzen CPU's L3 Latency Performance Fix To Be Resolved By Microsoft Through Windows 11 Update on 19th October, CPPC Driver on 21st (wccftech.com)
Yes it's an issue. But it's a known one with a fix already existing on the dev branch and a known release date.
Use 10, or deal with it. I see no issues with gaming on 11 despite being hit by this.
That's nice, just after Intel reviews hit, right? If so, wtf...
136 (0.17/day)
System Name Ryzen 1
Storage SSD's
Case Phanteks P400A
How is this?
412 (2.12/day)
Processor Ryzen 5 3600
Motherboard B550 Elite
Cooling Hyperx 212
Memory Hyperx fury 16Gb DDR4 3333Mhz
Video Card(s) 3060 ti gaming oc pro
Storage Samsung 970 Evo 1Tb plus some HDDs
Power Supply MSI 750w
Mouse G502
so is it solved?
136 (0.17/day)
System Name Ryzen 1
Storage SSD's
Case Phanteks P400A
2,180 (1.51/day)
106 (0.31/day)
São Paulo, Brazil
System Name Unova
Processor AMD Ryzen 9 5950X 16-Core Processor
Motherboard ASUS ROG STRIX B550-E Gaming
Cooling id-cooling Frostflow X 360 + Thermal Grizzly Aeronaut
Memory 64 GB (4x 16) Corsair Dominator Platinum @ DDR4-3600 16-17-16-34-1 1.375V
Video Card(s) ASUS TUF Gaming GeForce RTX 3090 24 GB GDDR6X OC Edition (Non-LHR)
Storage XPG SPECTRIX S40G 512 GB
Display(s) Sony XBR-55X905F
Case Lian Li PC-O11 Air
Audio Device(s) EVGA Nu Audio (classic)
Power Supply EVGA SuperNOVA 1300 G2 1300W 80+ Gold
Mouse Corsair M55 RGB Pro
Keyboard Logitech G213 Prodigy
VR HMD OG HTC Vive
Software Windows 11 Pro for Workstations
Benchmark Scores Imagine imagining imagination :D
For the most part. Some claim bandwidth is still a little low.
Yeah, this is my experience as well. The bandwidth and latency actually varies quite a bit, between 60-75 ns memory and 300 GB/s to almost 1 TB/s on the L3. It's kind of wobbly.
One run I get this:
Just for the very next, get this:
and then it's suddenly fine again. Performance is noticeably improved, though. AMD also released a chipset driver update to address the UEFI CPPC2/core scheduling issue.
246 (0.25/day)
Texas
Processor AMD R9 5900x
Cooling I forgot to get a aio I r stupidity
Memory corsair vengeance rgb pro 32gb
Video Card(s) xfx rx5600xt
Storage 4 ssd 2 hdd
Display(s) 40" samsung
Case Corsair icue 220t rgb
Power Supply corsair RM850 modular
Mouse logitech
Keyboard logitech
Software w10
on w11 and i don't know what to thank of AIDA64.last night my L3 cache was ~660 today
going to put aida 64 in the toilet.
