What should I do to get my USB 3.0 to truly work? Will I need a hub?
harly
15 (0.00/day)
I've just recently bought a new laptop which includes USB 3.0 ports. Here is the thing they may be slow very slow. My external HDD and my flash drives support high speed USB but my flash usually only gets around 7 mbps and my 1T external only goes up to about 25 mbps. We have tried our USB ports all the same. Even checked device manage to confirm that I have 3. 0 that has been enhanced ports. I don't get what’s going on. If somebody might help me it might be greatly appreciated.
1,706 (0.41/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Display(s) Samsung Odyssey G7
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
in order to get a truly USB 3.0 speed, your flash drive should have same USB 3.0 hardware. Same goes for your external HDD.
can you tell us exactly model of your USB flash drive and external HDD. would be beneficial if you also tell us model of your new laptop
1,486 (0.33/day)
Anchorage Alaska
System Name Matter's / Helios 300 Predator
Processor Ryzen 7 2700 / i7 7700HQ
Motherboard B450 Tomahawk / Acer Helios 300 Predator
Cooling Arctic Freezer eSports Duo
Memory Patriot Viper ddr4 32gb / 32gb gskill ddr4
Video Card(s) MSI RTX 2080 Super Ventus OC / GTX 1060 6gb
Storage Patriot Viper nvme M2, crucial MX300 275gb, Samsung 860 qvo 1tb
Display(s) Acer 24" 1080p / 15.6 1080p HD
Case Antec 300 / Acer Helios 300 Predator
Audio Device(s) On Board - Steel Series Arctis Pro Wireless Cans
Power Supply Antec 850watt high current pro
Mouse Steel series Rival 600
Keyboard Corsair K70 / Acer Helios 300 Predator
Software Win 10 Pro / Win 10 Home
what laptop do you have make and model? What is the make and model #'s of your externals?
also are your external devices usb 3.0? just saying they support high speed means nothing because usb 2.0 says high speed data transfer as well. If you are plugging a usb 2.0 into a 3.0 slot, it will only run at 2.0 speeds and the same if you plug 2.0 into a 1.1/1.0 slot it will run at 1.1/1.0 speeds. But double check that your externals are usb 3.0.
obviously me and night.fox were writing at same time lol :)
1,706 (0.41/day)
System Name Gen2
and have same thoughts. your explanation is better though. just a bit lazy to type more. lol
OP, its like this..... imagine a 10mb/s input, it will still have 10mb/s even the hub is 1000 mb/s.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If port is USB3, there is a driver behind the USB3 ports, device is USB3, device is capable of moving data faster than 60 MB/s, and you are seeing transfer speeds less than 60 MB/s, check the BIOS for anything pertaining to USB and play with it. For example, if there is an option pertaining to "Legacy USB," disable it. If there's something about "Enhanced USB" enable it. BIOS authors have been doing some really silly stuff in regards to USB3 so never assume the option to make it work is obvious.
1,662 (0.34/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, 2 x 512GB Samsung PM981a, 4 x 4TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
I'm sure it just comes down to the confusion between "high speed" USB, which is USB 2.0 and "super speed" USB, which is USB 3.0.
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.63/day)
IA, USA
System Name BY-2021
It's pretty easy to tell if USB3 is supported: it will have 8 electrical contacts instead of 4.
1,706 (0.41/day)
System Name Gen2
one tip on this USB 3.0 thing..... mostly, they use blue connectors (inside the plug) rather than black. unless stated otherwise.
Deleted member 24505
On my usb 3 external, i am getting 100MB/s read/write.
29 (0.00/day)
The limitation may be those high speed devices because USB 3.0 requires super speed to work at its fastest, and there seem to be problems with some super speed connections from making good contact because the plastic ribs separating the 5 pins at the front of the socket are too wide to let the plug's pins from slipping between them.
