Where do I put the Power LED - and Power LED +?
jojellybean
22 (0.01/day)
I plugged the computer fan to system fan.
I plugged the POWER LED
but i don't know where to put power led - and power led +. It's together.
40,435 (6.59/day)
Read your manual
607 (0.10/day)
Omaha, Nebraska, USA
System Name Built By Me
Processor Intel Core i9 9900K @ 5.1 GHz
Motherboard Gigabyte Z390 Aorus Ultra
Cooling Custom Water Cooling - CPU Only
Memory 32GB (2 x 16) GSkill Ripjaws V DDR4
Video Card(s) RTX 4080 - ASUS ROG Strix 16GB OC - P Mode
Storage 1TB Samsung 970 Evo NVMe
Display(s) Alienware AW2723DF @ 280 Hz @ 1440P
Case Fractal Design Define S2
Audio Device(s) Corsair Virtuoso Pro
Power Supply 850W Seasonic Platinum
Mouse Razer Viper V2 Pro @ 2k Hz
Keyboard Asus ROG Strix Scope II 96 Wireless - ROG NX Snow Switches
Well, at the bottom right of your motherboard should be a lot of pins. If you look closely at the pins, they will have something printed on the PCB indicating where to put the positive and negative leads for your power LED.
jojellybean
22 (0.01/day)
On the manual it says the power led. On the number of the slot for number 4 it says 4. - and for 2 it says 2.+
607 (0.10/day)
Well, the numbering might be where it counts up/down vertically and then moves horizontally one space to increment/decrement the count.
jojellybean
22 (0.01/day)
Everything is put except the Power LED part and I have the Power LED cable connector coming from the case. It's just 1 is labeled + and 1 is labeled - . I don't know where to put it in. I'm checking the manual, I have a Z97-G45 Gaming mobo.
607 (0.10/day)
This is what I mean when I say they may use a number system like how I descibed. You can see that if pins 2 and 4 are the way they are, that will enable you to plug your two-pin power LED button in.
607 (0.10/day)
I found out for you. JFP 1 on your mobo
jojellybean
22 (0.01/day)
Yeah, on my manual, I see the pins that are for POWER LED. However, on the cables that are coming from the case, one pin says power led + and one says power led- .
How do I know if 1 is for Power LED + and 2 is for Power LED -. It says this on my manual.
I'm assuming the - goes to the 4th pin and the + on the 2nd pin based on this limited info on the manual? Or, are these + and - what you were referring to? I think it isn't.
607 (0.10/day)
Please reference my post number eight on this thread and match the symbols.
Edit: I am not being condescending, I am just having difficulty understanding what other issues you might be having.
40,435 (6.59/day)
you see in the manual where it says power led then a - and then a +, put the - plug on the - pin and the + plug on the positive pin
jojellybean
22 (0.01/day)
OK GUYS, IT IS SET! :)
Is it okay if I have my computer on this foam?
It's better than it being on carpet.
607 (0.10/day)
I am glad you got it working!
I don't see a problem with the foam, but the foam might break over time or immediately, depending on the weight of the object that is set on top of the foam.
1,980 (0.42/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
"Polystyrene holds a static charge and will attract dust and fluff [*may - damage components if in direct contact]
Note: use a piece of wood; cardboard or old book\s"
http://www.techpowerup.com/forums/t...r-on-foam-like-this-instead-of-carpet.207536/
NB: Stick to one post keep all the info in one place, just noticed you have posted two or three times. maybe ask a mod to merge your post's and place it in the system builders advice section will save other members of the TPU community repeating information.
atb
Law-II
