Why do you think I might be having 3469 MB reading speed and 63 MB writing speed? KINGSTON SNV2S2000G NVME
MonsterMMORPG
27 (0.03/day)
Turkey
I can't figure out this inconsistency - the cause of it
I have 64 GB ram
Core 13900 K cpu
Windows 10
This is my problematic nvme it is primary disk C
this is my another nvme
here disk info
40,399 (6.81/day)
So what problem are you having with the computer overall as in use?
MonsterMMORPG
27 (0.03/day)
Turkey
well nothing obvious but sometimes i feel like disk is slow at writing
for example when generating proxy media in davinci resolve it waits a lot for writing
MonsterMMORPG
27 (0.03/day)
Turkey
It is running hot, that certainly doesn't help.
i am considering that is this the case
if it is, i can purchase a fan having cooler
it has heatsink and case is open case but still getting these degrees
here photo
545 (0.33/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Motherboard TUF GAMING B550-PLUS WIFI II
Cooling Arctic Liquid Freezer II
Memory 32 gigs - 3600hz
Video Card(s) EVGA GeForce GTX 1080 SC2 GAMING
Storage NvmE x2 + SSD + spinning rust
Display(s) BenQ XL2420Z - lenovo both 27" and 1080p 144/60
Case Fractal Design Meshify C TG Black
Audio Device(s) Logitech Z-2300 2.1 200w Speaker /w 8 inch subwoofer
Power Supply Seasonic Prime Ultra Platinum 550w
Mouse Logitech G900
Keyboard Corsair k100 Air Wireless RGB Cherry MX
Software win 10
Benchmark Scores Super-PI 1M T: 7,993 s :CinebR20: 5755 point GeekB: 2097 S-11398-M 3D :TS 7674/12260
Impressed by poweron count vs power on time :)
i would try to Fan it or maybe get some fin´s on it.
Also this spinning rust just keeps to amaze me lols
545 (0.33/day)
Denmark - Aarhus
System Name Iglo
Processor 5800X3D
Mouse Logitech G900
Software win 10
well, i´m use to pay the powerbills. and we are 5 here. So kinda force my self to do it. price peaked a 1.2$ KW/h here this year.
MonsterMMORPG
27 (0.03/day)
Turkey
wow interesting
i thought we were using the most expensive electricity
so what is its ratio over the lowest wage in your country?
you can use 4200 KW/h with your entire minimum wage salary in Turkey
Lei
1,117 (1.37/day)
usually in my shirt
Processor 3900x - Bykski waterblock
Motherboard MSI b450m mortar max BIOS Date 27 Apr 2023
Cooling αcool 560 rad - 2xPhanteks F140XP
Memory Micron 32gb 3200mhz ddr4
Video Card(s) Colorful 3090 ADOC active backplate cooling
Storage WD SN850 2tb ,HP EX950 1tb, WD UltraStar Helioseal 18tb+18tb
Display(s) 24“ HUION pro 4k 10bit
Case aluminium extrusions copper panels, 60 deliveries for every piece down to screws
Audio Device(s) sony stereo mic, logitech c930, Gulikit pro 2 + xbox Series S controller, moded bt headphone 1200mAh
Power Supply Corsair RM1000x
Mouse pen display, no mouse no click
Keyboard Microsoft aio media embedded touchpad (moded lithium battery 1000mAh)
Software Win 11 build 25281
Benchmark Scores cine23 20000
here photo
Well I can't see anything in this photo. Are they my eyelashes?
Could you put your 2nd nvme in the 1st nvme slot and vice versa. To see if temps and speed will change.
ir_cow
2,900 (0.53/day)
USA
OMG! I'm at $0.11c . I wouldn't turn my computer on if it was that much.
MonsterMMORPG
27 (0.03/day)
Turkey
I may try swap but 2nd has no heatsink and it also runs hot :D
here it is
40,399 (6.81/day)
Get a better drive, not all nvme are created equal, also keep them cool
Lei
1,117 (1.37/day)
usually in my shirt
MonsterMMORPG
27 (0.03/day)
Turkey
So this Kingston?
Is the white şeffaf fan at back of your case intake or exhaust?
SanDisk is below the 2 graphic cards, right?
it is the heatsink. under that Kingston
that fan is not working case is fully open
sandisk is below the graphic cards correct
here my full case
2,285 (0.87/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Storage Too much
Case Thermaltake Core X9
Mouse G305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Are you getting 63c at idle or was that screenshot taken during load? If that's idle it's definitely too high.
40,399 (6.81/day)
Lei
1,117 (1.37/day)
usually in my shirt
here my full case
Let the fan work.
What are your gpu temps.
As you have radiators on top, let the white fan blow into the case. The rads are blowing out of the case right?
Do you have a fan in front side of the case (above hard disks and gpu)? If so, let that be intake and the white fan be exhaust
MonsterMMORPG
27 (0.03/day)
Turkey
Let the fan work.
a big fan works in front of case to cool of those mechanical drives - blows out of case
mechanical disks are 35-36 celcius
gpus are 55 and 45
the rads are blowing out of case too
i think i will put a cooling case which are used to cool drugs and test
lets see if lower temp will fix
ok i put this + plus used air flower
reduced temp to 35 while testing
still issue not fixed
definite not related to tempature
Lei
1,117 (1.37/day)
usually in my shirt
gpus are 55 and 45
You better have this setup:
Gpus are 55 and 45
At idle. But they throttle under load. They're 90+ degrees and they're blowing hot air into each other and your Kingston.
3,189 (3.17/day)
São Paulo, Brazil
System Name Project Kairi Mk. III "Lunar Tear"
Motherboard MSI MEG Z690 ACE (MS-7D27) BIOS 1.C0
Cooling id-cooling Frostflow X 360 w/ Thermalright BCF and Thermal Grizzly Kryonaut Extreme
Memory G.SKILL Trident Z5 RGB 32GB DDR5-6800 F5-6800J3445G16GX2-TZ5RK @ 6400 MT/s 30-38-38-38-70-2
Storage 3x WD Green SN350 480GB + 6x WD VelociRaptor WD3000HLFS 300GB HDDs
Display(s) LG UltraGear 27GN65R-B, 1080p, 144 Hz, G-Sync
Case Cooler Master MasterFrame 700 in bench mode
Audio Device(s) EVGA Nu Audio (classic) + Sony MDR-V7 cans
Mouse Razer DeathAdder Essential Mercury White
Keyboard Logitech G Pro K/DA TKL
Software Windows 11 Enterprise 22H2
Benchmark Scores "Speed isn't life, it just makes it go faster."
That very slow write is not a good sign, even for a throttling drive. See if it gets better if you blow air on it with a fan, if the speeds don't get better, backup and RMA. It might be going the way of the dodo in a way SMART itself will be unaware of.
btw... your PC is giving me nightmares :cry:
You gotta clean that, do some basic cable management and set the airflow direction as @Lei described above. Should greatly improve your thermal situation there.
MonsterMMORPG
27 (0.03/day)
Turkey
just verified that the temperature is not the case
what else could be cause? i really want to avoid this is a very new drive :/
3,189 (3.17/day)
São Paulo, Brazil
Not much I'm afraid. You have to test it in another machine. If no other machine is available, try it on your motherboard's other slot. If the speeds are still limited to 64MB/s write, your drive is defective.
169 (1.19/day)
Processor Ryzen 5500 4450mhz (CO +200 boost)
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory Teamgroup 3600mhz 16GB (2x8)
Video Card(s) Sapphire Nitro+ 6700XT 12GB
Storage 1TB WD PCIE3 NVME, 500GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply EVGA 600W
