- Apr 17, 2017
- 401 (0.16/day)
Processor | AMD Ryzen 1700X 8-Core 3.4Ghz |
Motherboard | ASRock X370 Taichi |
Cooling | Thermalright Le Grand Macho RT, 2x front Aerocool DS 140mm fans, 1x rear Aerocool DS 140mm fan |
Memory | 16GB G.Skill Flare X DDR4 3200Mhz |
Video Card(s) | PowerColor Red Devil Vega 64 |
Storage | Samsung 960 Evo 500GB NVME SSD - Boot drive, Samsung 850 Evo 1TB SSD - Main storage |
Display(s) | Acer XG270HU Red 27" 1ms 144HZ WQHD 2K FreeSync Gaming Monitor |
Case | Fractal Design Define R6 USB C-Type Blackout Edition (Non TG) |
Audio Device(s) | Sennheiser GSP 301 Headset, Sennheiser Game Zero Special Edition Headset, Logitech Z623 System |
Power Supply | Seasonic AirTouch 850w 80 Plus Gold |
Mouse | SteelSeries Rival |
Keyboard | Razer Ornata Chroma |
Software | Windows 10 Professional 64bit |
So later this year I will be upgrading to the Zen 2, I will be using the successor to the MSI B450 (maybe it's B550?) Pro Carbon AC and the successor to the Ryzen 5 2600X. Besides these upgrades, my system components will be the same as they are now. I also have a Sound Blaster ZxR which is not listed in my system specs.
Anyways, the configuration will be in my current Define R6 Blackout (non-TG) case. I will have two Aerocool DS 140mm fans in the front of the case for intake, one Aerocol DS 140mm fan in the rear for exhaust, and for my CPU cooler I will be using a NZXT Kraken X62 Rev 2 at the top. It is important to note that I will be running this cooler in performance mode which will not only slightly beat my Thermalright Le Grand Macho RT in thermals, but it will only produce a sound level of 26 dB while running at 800 RPM (this sound level is based on an overclocked load on an i7-6700k so it may be slightly off).
Based on the above setup would this perform nicely for airflow and cooling? I also want to make sure that the fans are configured to at the correct RPMs to limit any access noise of possible.
