Windows 10 Build 17093 Causing problems with system. Send Help!
1,257 (0.37/day)
Likes
172
Delhi,India
System Name Mr. 97
Processor Intel Core i7 4790k @4.6GHz
Motherboard MSI Gaming 5 Z97
Cooling Nepton 240M + 6 Case fans
Memory Kingston HyperX Fury @2200MHz 16GB (2x8GB)
Video Card(s) MSI GTX970 Gaming 4G @ 1552MHz
Storage WD Cavier Green 1TB 64 MB Cache @7200RPM
Display(s) LG 29UB67 21:9 2560x1080
Case Cooler Master cm690
Audio Device(s) on Board
Power Supply Corsair RM750 750W PSU
Mouse Logitech G400s
Keyboard TVS Gold from 1996
Software Windows 10.1 64BIT
#1
Hey guys,
Hope you all are doing good!
Long time since I posted something here. Started facing some problem with my PC again, searched online and nothing seem to work. So back here to ask you guys for help.
So my PC was facing some trouble with Windows Insider Build since build 17074. Read online that Kaspersky Internet Security could be the problem and uninstalling it certainly fixed it. But since then my pc has updated to 17093 and every boot after complete shutdown PC gets stuck in boot loop.
The boot loop does not even reach windows screen, motherboard goes through its error codes : "99...9C...A2...MSI Gaming Series logo" and then reboots and same thing continues infinitely.
I tried to fix this by rebuilding bcd using Windows 10 install pendrive repair option, which seemed to work only once and since then has not worked.
One thing that always seems to work is bootrec /fixboot in cmd from bootable pendrive repair option. So, I am guessing it is a Software or Drive issue more than Hardware issue. I am actually using my PC at this moment using the fixboot technique.
Hardware side of things are all in perfect condition(cleaned my PC just in case), CPU is not overheating, GPU is not overheating.
Installing Windows again is the last option I have as I think this could be fixed as most likely this is a software issue.
So, guys if you have any whats going on, any input is appreciated.
Thanks for reading. Have a great day ahead :)
regards,
mafia97
6,079 (1.34/day)
Likes
1,729
New York
System Name http://www.heatware.com/eval.php?id=73751
Processor Tracer II 15 VR800 I7 7700HQ/GTX1070 16GB DDR4/2133MHz /ASUS GL553VW GTX 960M 4GB i56300HQ 8GB DDR4
Motherboard i7-920 CO@4.2GHZ/Asus P6T Deluxe Intel X58
Cooling Asetek Liquid CPU Cooling System
Memory CORSAIR DOMINATOR 6GB (3 x 2GB) DDR3 1600
Video Card(s) 2X ATI Radeon HD 4870 X2 2GB DDR5 PCI-Express
Storage (RAID-0) with 4 Identical Hard Drives (1.28TB (320GBx4)
Display(s) LG 50" 50PK550 1080p 600Hz Plasma/37 Inch WestingHouse @1920x1080
Case Thermaltake M9 (I hate it its like trying to live in a 1 inch box)
Power Supply ThermalTake ToughPower 1200 Watt
Software Windows 7 professional 64
#2
My guess is it is a buggy insider build for your hardware configuration and it would probably be best to deal with this issue with Windows Insider Program (that is what this platform is for), but if this is your only PC to use you may have to roll it back for now. Good luck and welcome back !
1,257 (0.37/day)
Likes
172
Delhi,India
System Name Mr. 97
#3
Well I tried that too. Windows rolled me back to the same build. And yes, this is the only PC I have.
6,079 (1.34/day)
Likes
1,729
New York
#4
Do you have a OEM or Retail windows license you could use to install the Official Windows Release?
1,257 (0.37/day)
Likes
172
Delhi,India
System Name Mr. 97
#5
Hi Guys, I have fixed the issue. It was a windows fast boot issue.
I ran command prompt in admin mode and just wrote the command "powercfg -h off"
and this fixed the issue.
Mods please keep the thread open for a few days, if there are any developments I will post here.
1,952 (0.92/day)
Likes
787
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
#6
So another issue with hibernation? I'm on RS3 release170928 and never had boot loop issues with any versions. Maybe because I always turn off hibernation using the command prompt. Sometimes the update will turn it back on, but I always check afterwards (run WinDirStat). Hibernation sucks, half the time it doesn't work, requires reboot anyway. I would only try to use it on a laptop, for battery life.
Mussels
Moderprator
46,396 (9.22/day)
Likes
13,980
Australalalalalaia.
System Name OCD (Overclocking Compulsive Disorder)
Processor Ryzen R7 1700, 3.7Ghz 1.25V
Motherboard MSI X370 Gaming PRO carbon (really nice board, bad vdroop under load w/ an 8 core)
Cooling Corsair H115i Pro (yay for maglev fans!)
Memory 16GB DDR4 3200 @ 3600 C18 (Corsair Vengeance RGB Pro)
Video Card(s) MSI GTX 1080 Gaming X (BIOS modded to Gaming Z - faster and solved black screen bugs!)
Storage 1TB Intel SSD Pro 6000p (+60TB USB3 storage)
Display(s) Samsung 4K 40" HDTV (UA40KU6000WXXY) / 32" HP 1440p
Case Fractal Design R5 White Gold edition + corsair RGB lighting
Audio Device(s) Pioneer VSX-519V + Yamaha YHT-270 + Corsair Void pro RGB, Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Mouse Logitech G703 + PowerPlay mousepad
Keyboard Corsair K65 Rapidfire
Software Windows 10 pro x64 (all systems)
Benchmark Scores Laptops: i7-4510U + 840M 2GB (touchscreen) 275GB SSD + 16GB i7-2630QM + GT 540M + 8GB
#7
Could this be related to the buggy spectre/meltdown patches everyone was unhappy about? You do have a 4000 series intel, which was one of the affected models.
4,837 (1.61/day)
Likes
2,162
#8
I thought I recognised that cmd as I always turn off hibernation by default, never had that issue though, how did you roll back or enter admin mode when it wasn't even getting to Windows loading screen?
rtwjunkie
PC Gaming Enthusiast
10,184 (2.79/day)
Likes
14,271
System Name Bayou Devil
Processor Core i7-4790k 4.4Ghz @ 1.18v
Motherboard ASUS Z97 Deluxe
Cooling All air: 2x140mm Fractal exhaust; 3x 140mm Cougar Intake; Enermax T40F CPU cooler
Memory 2x 8GB Mushkin Redline DDR-3 1866
Video Card(s) MSI GTX 980 Ti Gaming 6G LE
Storage 1x 500 MX500 SSD; 2x 2TB WD Black; 1x4TB WD Black;1x 2TB WD Green (eSATA)
Display(s) HP 25VX 25" IPS @ 1920 x 1080
Power Supply Seasonic X-850
Mouse Coolermaster Sentinel III
#9
The is been a fairly widespread but intermittent problem with hibernation since W8.1. Works for some, goes apeshit for others.
My advice to people I know with SSD's is always turn it off.
1 (0.01/day)
Likes
0
#10
Great information. I had the same endless boot cycle with my ASUS. I got around it temporarily by interrupting the boot cycle (F11) and selecting to boot from the SANdisk. The long way home. I will turn off hibernation and see if this fixes my issue.
peche
Thermaltake fanboy
6,558 (4.86/day)
Likes
5,393
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
#11
1,257 (0.37/day)
Likes
172
Delhi,India
System Name Mr. 97
#12
I used windows bootable pendrive to access command prompt via that and used fixboot command to access my windows.
I dont think thats the case here as the switching off fast boot has fixed it.
