X1950 Pro AGP 4-Pin Power supply
Discussion in 'Graphics Cards' started by kebabs, Mar 7, 2007.
  1. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Hey, I just recieved my order of a X1950 Pro AGP graphics card.
    My question to you lot out there is, it has 2, 4-pin powersupply sockets on it.
    Now do I need to plug a 4-pin head in both?
    ( I Came to ask because I don't want to fry it :( )
    I plugged one in the top slot and the monitor picks it up but the PC Crashes on booting, but when I plug it into the other one, the monitor doesn't pick up the graphics card at all.
    So do I plug it in both?
    Thankz
    Kefrog
    10 Year Member at TPU
  2. Completely Bonkers New Member
    Feb 6, 2007
    2,576 (0.68/day)
    516
    Yes. But what watt rating is your PSU? There is a common problem of underpowered PSU on older AGP mainboards.
    (update your profile to include your system specs)
  3. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Damn, I've just answered my own question. My PSU is 350W but I didn't check how hungry the card was. Anyways will any PSU that has a 20 Pin ATX connector work with my mobo?
    ( Just asking, because I'm not sure. Also did you say I need both 4-pin plugs plopped into the card? )
  4. Brutalfate New Member
    Sep 12, 2006
    374 (0.10/day)
    7
    AUS, NSW, Sydney
    Yeah use both 4-pin connectors. All modern Psu's should have the same 20pin power connector..
  5. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Ok Cheers, so if I got a 550W PSU 20pin ATX, it would work yeah? ( Sorry I am a computer noob )
  6. Brutalfate New Member
    Sep 12, 2006
    374 (0.10/day)
    7
    AUS, NSW, Sydney
    Hehe, yup. :) Sounds all good.
  7. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Does it matter what hardware I have?
    ( Also could you help me find a good midranged price 550W PSU?, SKT 478 :( I know :p. And I don't use PCI-E. I have 2 HD's needing power and 2x DVD's )
  8. tkpenalty New Member
    Sep 26, 2006
    6,956 (1.78/day)
    345
    Australia, Sydney
    hmm... try getting a PSU with modular cables around 500-600W, anything over $100USD, you CANNOT compromise on the PSU, it can lead to fires and broken PCs as well as a heftier power bill.
    (Next time post problems about the X1950 series in the X1950PRO Clubhouse, a support thread to make life easier).
  9. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Oh sorry I didn't see that section.
  10. Zubasa
    Zubasa
    Oct 1, 2006
    3,998 (1.03/day)
    470
    Hong Kong
    Pretty much all modern ATX PSUs have a 20+4pin connector for the mobo.
    So for older mob just plug in the 20 pin and newer ones plug in 24 pin.
    And yes you should plug in both 4-pin molex. (Thats why they are there:p)
    It is safer to do so also because the 4-pin molex connector is designed for HDD which require a low current.
  11. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Thanks dude, I am going to get a new PSU soon but I've seen PSU's on the internet that say
    20pin + 4pin does that mean it's detachable?
  12. Zubasa
    Zubasa
    Oct 1, 2006
    3,998 (1.03/day)
    470
    Hong Kong
    Exactly, the 20+4pin makes it compatible for new and old ATX mobos.
    [​IMG]
  13. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Cheers for that dude. I am gonna get a 570W PSU now lol. Cheers ^^
  14. Zubasa
    Zubasa
    Oct 1, 2006
    3,998 (1.03/day)
    470
    Hong Kong
    Make sure it has a nice powerful +12V output.
    Better be sure than sorry.
  15. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
  16. Zubasa
    Zubasa
    Oct 1, 2006
    3,998 (1.03/day)
    470
    Hong Kong
  17. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
  18. Zubasa
    Zubasa
    Oct 1, 2006
    3,998 (1.03/day)
    470
    Hong Kong
    It should work if you convert the 6-pin PCI-E connector in to 2 4-pin molex.
  19. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    Ok thanks dude. Isn't there any other molex power cable on there?
  20. Completely Bonkers New Member
    Feb 6, 2007
    2,576 (0.68/day)
    516
    kebabs... I would take a look at REVIEWS for power supplies. While Trust is not bad... they are not the best either. They typically make the OEM PSUs that come "free" in cases. I think you can do better... but will be spending more like £50-80. Get one that is QUIET/SILENT. A noisey PSU will soon get on your nerves.
  21. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    I've already got it and it makes no noise and works perfectly. But :( The card still isn't working. It boots but doesn't make it to the Loading XP sign, it just crashes before that and stays on the start screen.
  22. KennyT772
    KennyT772 New Member
    Dec 21, 2005
    3,572 (0.85/day)
    103
    driver issue? can you boot into safe mode?
  23. kebabs New Member
    Dec 25, 2006
    125 (0.03/day)
    3
    How do I boot in Safe mode anyway? Also I don't even think it is Booting. It just goes to the main Intel screen and then goes black and then goes back to the intel screen and stays there.
  24. lufrey New Member
    Jan 21, 2007
    130 (0.03/day)
    0
    Perth, Australia
    The below mentioned power connector is part of the ATX 2.0 spec, so when you get a PSU, just make sure it is ATX 2.0 spec, don't just go by the power rating.
  25. dashsmashed New Member
    Mar 3, 2007
    31 (0.01/day)
    0
    dude - i had this problem and i took me ages to figure it out... :banghead: there is a solution suggested in the 1950 club thread to boot in safe mode then lower the resolution...i'm sure I tried that but it didnt work for me but worth a shot...
    my solution was to start your machine and switch the monitor off when the splash screen appears...wait till you hear the windows 'chime' then switch your monitor on (bet its an old CRT?) and hopefully it should work...;)
    I ended up buying a new lcd 'cause it was such a pain in the butt :wtf:
    good luck
    edit - sorry didnt read your problem properly... not the same as mine ! - to boot into safe mode press F8 before the splash screen loads..
