Fitseries3
Eleet Hardware Junkie
- Oct 6, 2007
- 15,508 (2.57/day)
- Republic of Texas
i have this OCZ freeze, shin etsu and AS ceramique
System Name | Rocinante |
Processor | I9 14900KS |
Motherboard | EVGA z690 Dark KINGPIN (modded BIOS) |
Cooling | EK-AIO Elite 360 D-RGB |
Memory | 64GB Gskill Trident Z5 DDR5 6000 @6400 |
Video Card(s) | MSI SUPRIM Liquid X 4090 |
Storage | 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400 |
Display(s) | Odyssey OLED G9 G95SC |
Case | Lian Li o11 Evo Dynamic White |
Audio Device(s) | Moondrop S8's on Schiit Hel 2e |
Power Supply | Bequiet! Power Pro 12 1500w |
Mouse | Lamzu Atlantis mini (White) |
Keyboard | Monsgeek M3 Lavender, Akko Crystal Blues |
VR HMD | Quest 3 |
Software | Windows 11 |
Benchmark Scores | I dont have time for that. |
VR HMD | Quest 3 |
well if you looky here.... you can see i fixed something. dont know what, but one thing is for sure....
1.3v for 4ghz is pretty nice.
VR HMD | Quest 3 |
POS 7 drivers from ATI wont install at all.
VR HMD | Quest 3 |
VR HMD | Quest 3 |
i went from 4.1ghz -> 4.5ghz on that voltage with setfsb in windows. 4.6ghz makes 3dm stop in the cpu test. i esc out and everything is fine. im testing 4.5ghz with 4850 OCed.
VR HMD | Quest 3 |
im using the 1200watt pc power now.
System Name | The ClusterF**k |
Processor | 980X @ 4Ghz |
Motherboard | Gigabyte GA-EX58-UD5 BIOS F12 |
Cooling | MCR-320, DDC-1 pump w/Bitspower res top (1/2" fittings), Koolance CPU-360 |
Memory | 3x2GB Mushkin Redlines 1600Mhz 6-8-6-24 1T |
Video Card(s) | Evga GTX 580 |
Storage | Corsair Neutron GTX 240GB, 2xSeagate 320GB RAID0; 2xSeagate 3TB; 2xSamsung 2TB; Samsung 1.5TB |
Display(s) | HP LP2475w 24" 1920x1200 IPS |
Case | Technofront Bench Station |
Audio Device(s) | Auzentech X-Fi Forte into Onkyo SR606 and Polk TSi200's + RM6750 |
Power Supply | ENERMAX Galaxy EVO EGX1250EWT 1250W |
Software | Win7 Ultimate N x64, OSX 10.8.4 |
Mine walls at 449Mhz. Don't feel bad. Not even clockgen or SETFSB will get me past it. My Q6600 would go all the way up to 475fsb, so it's the chip.i feel like im totally relearning everything on this board.
i have p45 down and i could school anyone on p45 but this x48 is heckling me like MAD.
all the settings seem to do nothing to make things better.
i have already identified that this qx9650 has a few problems...
1. stuck sensors: reads 20, 20, 9, 4 at all times on air , water, and TEC
2. FSB wall at 462mhz: tried all multis from 6 - 14(obviously the higher ones did not boot)
3. needs TONS of voltage to boot into windows although it can post at low volts
When benching, people like Hipro and Kingpin are using both a PCP&C 1200w and a Corsair HX1000 at the same time. Might be a good idea to try the 2 psu solution like Sol said.im using the 1200watt pc power now.
System Name | CrossfireX |
Processor | Intel Core 2 Duo e8600 450x9.5 |
Motherboard | Asus Rampage Extreme |
Cooling | Thermalright Ultra 120 Extreme |
Memory | Corsair Dominator TWIN3X2048-1800C7DF 1800mhz 7-7-7-20 |
Video Card(s) | Visiontek 4870 512mb Crossfire |
Storage | Western Digital 300gb Velociraptor, 750gb RE2 |
Display(s) | Samsung 20.1" 204T (upgrade coming soon) |
Case | Cooler Master HAF 932 |
Audio Device(s) | Asus Xonar D2 |
Power Supply | OCZ EliteStream 1000w |
Benchmark Scores | ~ 20800 3dMark06 |
i have tried all auto
vcore = 1.35 - 1.6v
cpu gtl = auto, .63, .65, .67
pll = auto - 1.74v
fsb term - auto - 1.5v
dram - 1.7 - 2.1v (ddr3)
vNB = auto - 1.71v (fan on NB, temps fine, 35c max)
nb gtl = auto, .61, .67
vSB = auto - 1.2v
tried different FSB straps and memspeeds, loosened timings, everything man.
is this what you expected?
VR HMD | Quest 3 |
so what should i do here? send the board back? RMA the cpu? sell it all and get nehalem?
