pjladyfox
- May 8, 2008
- 232 (0.04/day)
System Name | Eternal |
Processor | AMD Phenom II 955 |
Motherboard | Gigabyte GA-MA790X-UD4P |
Cooling | Corsair H50 water cooling system |
Memory | 8GB Corsair TWIN2X2048-6400C5DHX |
Video Card(s) | ATI Radeon HD 5870 |
Storage | Seagate 7200.10 250GB SATA2, 7200.11 750GB SATA2, and 7200.10 500GB SATA2 |
Display(s) | SAMSUNG 245BW 24" LCD |
Case | Antec Three Hundred - custom mnpctech.com |
Audio Device(s) | Realtek ALC889 onboard sound |
Power Supply | Corsair HX620 |
Software | Windows 7 Home 64-bit Retail |
Everyone,
Wanted to get some of you more seasoned guys and girls opinions on some ideas for trying to bring down the temps on a 4870X2. Now I know there's the fan speed mod via the Catalyst drivers and Rivatuner (I think?) for fan adjustment as well as replacing the stock thermal paste with better stuff. Right now I'm looking at moving to an Antec Three Hundred for better airflow than my current case but I'm looking for something more.
Basically, I'm looking at something a bit different to work in conjunction with the fan speed adjustment (the thermal paste idea is out since I do not wish to void my warranty) and that is a fan cooling card. Now the two that look the most promising are these:
AzenX Blitztorm BT-SC70BBL PCI Slot Case Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114024
VANTEC SP-FC70-BL 70mm PCI Slot Case Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835888112\
Now I did a lot of digging to try and find if anyone had used these with either a 3870X2 or a 4870X2 and came up empty. I did see that some had some decent suggest using either of these to cool a 8800 GTX and even a GTX 260 which are about the same size as the X2's but they run cooler than the X2's do.
Do you guys think either of these would help do the trick or are they just a waste of money?
