AIDA64 GPGPU Benchmark
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
The latest version of AIDA seems to have a GPGPU benchmark. Like any other benchmark, let's pull together some numbers and start making some magic!
If you would be so kind to include a screenshot plus the table code, I will throw the results into this table for all to see and use. :toast:
Thanks to a recommendation by @kn00tcn, here is a table string template:
Code:
TYPE|MODEL|PHYSICALCHIPS|CORESSHADINGUNITS|SMCU|MHZ|MEMREAD|MEMWRITE|MEMCOPY|SPFLOPS|DPFLOPS|24BITIOPS|32BITIOPS|64BITIOPS|SPJULIA|DPMANDEL
Note: Please format the data yourself. I will not do it for you, so please don't only provide a screenshot. Thanks!
So, lets collect some data, shall we? For SCIENCE!
Type|Hardware name|Physical CPUs/GPUs|Total cores|Total compute units (GPU) or threads (CPU)|Core clock (Mhz)|Memory Read (MB/s)|Memory Write (MB/s)|Memory Copy (MB/s)|SP FLOPS (GFLOPS)|DP Flops (GFLOPS)|24-bit int IOPS (GIOPS)|32-bit int IOPS (GIOPS)|64-bit int IOPS (GIOPS)|SP Julia (FPS)|DP Mandel (FPS)
x64 CPU|Intel Core i7 3820|1|4|8|4500|53558|62302|53341|130.2|75.83|76.24|75.65|17.05|118.6|62.83
2 GPUs|AMD Radeon HD 6870|2|2240|28|920|12289|11641|204820|3217|Not Supported|800.3|800.3|161.4|450.2|Not Supported
x64 CPU|AMD A6-3500|1|3|3|3450|23111|18677|18040|82.33|41.17|26.35|26.35|9.94|33.09|17.66
1 GPU|Nvidia Geforce GTX 285|1|240|30|648|7102|7006|124983|687.3|86.04|681.3|137.6|30.96|152.5|19.77
x64 CPU|Intel Core i7 4770k|1|4|8|4500|30431|31185|27484|572.8|286.1|143.5|143.4|35.67|173.8|89.03
GPU|nVidia GTX 770 2GB|1|1536|8|1189|12088|11812|173079|3321|157.1|628.7|628.6|157.1|593.6|40.05
x64 CPU|Intel Core i7 2670QM|1|4|8|2200|19770|20555|19681|169.7|84.72|88.10|88.09|22.01|70.05|36.64
1 GPU|Nvidia Geforce GTX 570M|1|336|7|575|5149|5166|57097|692.6|58.10|233.8|233.7|57.77|132.7|16.52
x64 CPU|Intel Core i5 3570K|1|4|4|4500|23957|24608|23215|283.9|142.0|141.6|141.6|35.52|110.7|61.43
1 GPU|nVIDIA GeForce GTX 680|1|1536|8|1058|12087|11921|150138|2968|140.4|561.8|561.8|140.4|497.7|35.79
x64 CPU | Intel i7 2600k | 1 | 4 | 8 | 4600 | trial version | 24598| 23359 | trial version | 145.1 | 144.8 | 144.8 | 36.25 | Trial Version | 64.3
1 GPU | Nvidia GTX780 ti | 1 | 2880 | 15 | 1274 | 6310 | Trial Version | 271714 | 5724 GFLOPS | 297.2 | 1175 | Trial Version | 292.5 | 1025 | Trial Version
x64 CPU|Intel Xeon E3 1220|1|4|4|3100|TRIAL|20571|19562|TRIAL|97.59|97.37|97.36|24.44|TRIAL|42.21
1 GPU|Nvidia Geforce GTX 550 Ti|1|192|4|900|6113|TRIAL|70735|684.6|57.37|229.8|TRIAL|57.04|130|TRIAL
x86 CPU|AMD Athlon XP 3000+|1|1|1|2166|2537|2330|2361|8.62|4.31|1.69|1.64|0.36|2.99|1.36
Q9550|1|4|4|3570|9395|8903|8761|114.2|57.09|57.09|57.09|14.27|48.92|25.82
1 GPU|Nvidia GTX 780|1|4|2304|1202|11965|11885|231119|4618|223.7|915.8|915.8|192.8|878.4|58.52
x64 CPU|Intel i7 3770k|1|4|8|4600|28731|36305|31129|290.6|145.5|144.9|144.9|36.31|121.2|64.23
2 GPUs|nVIDIA 560Ti|2|768|16|875|9030|8326|215508|2660|223.5|893.9|893.9|222.3|504.5|62.81
X64 CPU|Intel Core i7 950|1|4|8|4273|30331|24702|30328|135.5|67.75|67.42|67.49|33.82|70.27|34.16
2 GPUs|Nvidia GTX 780|2|4608|24|901|12130|12033|435708|7514|364.7|1493|1493|314.7|1432|94.64
X64 CPU|Intel Core i7 4770K|1|4|8|4400|32474|41603|35923|562.9|281.4|140.8|140.8|35.18|174.5|93.41
Gpu|Amd 7970|1|2048|32|1000|3272|trial|235123|4256|1060|4253|trial|202.7|625.2|trial
x64 CPU|Intel Core i7 720QM|1|4|8|2800|15308|12734|14157|55.28|27.65|27.65|27.60|13.80|26.45|12.89
1 GPU|nVIDIA GeForce GT 240M|1|48|6|1210|3209|2909|20866|115.9|Not Supported|114.9|22.93|5.31|24.20|Not Supported
x64 CPU|Intel Pentium E2160|1|2|2|1800|4766|3656|3904|28.89|14.45|14.45|14.45|3.61|10.90|5.63
1 GPU|nVIDIA GeForce GT 430|1|96|2|1400|408.3|327.4|21096|266.5|22.37|89.47|89.48|22.27|48.70|6.22
2 GPUs|AMD R7 250+7850K|2|896|14|1100/720|16981|16625|52420|1579|98.71|1579|316.1|75.21|311.8|32.18
x64 CPU|AMD A10-7850K|1|4|4|4200|21621|11726|20375|133.8|67.03|33.51|33.51|4.15|35.55|18.27
x64 CPU|Intel i7 4770|1|4|8|4134|trial version|36489|33370| trial version |262.9|131.9|131.9|32.88|Trial Version|87.75
1 GPU|Nvidia GTX780|1|2304|15|1267|12752|Trial Version|245354 MB/s|4810 GFLOPS|233.5|955.5|Trial Version|201.4|916.5|Trial Version
x64 CPU | Intel i7 4770 | 1 | 4 | 8 | 4134 | trial version | 36489 | 33370 | trial version | 262,9 | 131.9 | 131.9 | 32.88 | Trial Version | 87.75FPS
1 GPU | Nvidia GTX780 | 1 | 2304 | 15 | 1267 | 12752 | Trial Version | 245354 | 4810 | 233.5 | 955.5 | Trial Version | 201.4 | 916.5 | Trial Version
x86 CPU|Intel Pentium 4|1|1|2|2800|3123|3095|3089|11.23|5.61|3.06|3.06|0.37|4.63|2.34
x86 CPU|Intel Pentium 4|1|1|1|2000|1952|2057|1903|6.97|3.68|3.84|3.84|0.18|3.32|1.77
X64 CPU|Intel Core i7-3930k|1|6|12|4704.4|66361|70235|63530|445.5|222.8|222.3|222.3|55.73|186.0|98.63
2 GPU|Nvidia GTX 780|2|4608|12|1254|23518|22229|505482|9513|472.4|1911|1911|477.1|1801|122.3
1 GPU|AMD Radeon HD 6770|1|800|16|960|5451|5328|62343|1231|Not Supported|304.4|304.5|61.30|170.7|Not Supported
x64 CPU|AMD Phenom II X4 955BE|1|4|4|3740|20880|11178|17634|119.6|59.80|38.28|38.28|14.44|47.57|24.23
x64 CPU|AMD Athlon 5350|1|4|4|2050|8622|4705|7799|63.46|16.36|30.79|30.77|4.02|26.12|11.71
1 GPU|AMD Radeon R3|1|128|2|600|3525|4727|9140|153.2|9.57|153.1|30.62|7.29|29.94|3.10
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
For CPU:
For GPUs:
792 (0.17/day)
Denmark
System Name Waterfall | xe
Processor Core i3-12100F | i5-1240P
Motherboard Gigabyte B660M-DS3H | HP laptop
Cooling Custom Watercooling | Stock laptop
Memory 2*16GB | 16GB DDR4
Video Card(s) RX 5700 with WC blocks | Iris Xe
Storage Intel 660 1TB + Crucial BX100 500GB | 1TB SSD
Display(s) U24E850R+U2515H | Internal 16"
Case Be Quiet! Dark Base 900 | Laptop
Audio Device(s) Audio 2 DJ + Xenyx Q802USB | Realtek
Power Supply Seasonic Focus Plus Gold 750W | 65W USB-C Power brick
Mouse Logitech M330
Keyboard Logitech G610 Orion Brown | Laptop
Software Gentoo + Windows 10 Pro | Gentoo
CPU:
GPU:
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
CPU:
GPU:
1,618 (0.27/day)
does opencl performance change across driver versions like dx & ogl do?
cpu turbo enabled makes the core clock numbers misleading, you can have turbo even with all your cores active in many applications
CPU:
GPU:
we should make some text that users can copy to make it easier
each item is 1 word no symbols so you can double click to select it for editing
498 (0.09/day)
System Name Dell Vostro 5630 | PHaS3-XXI
Processor Intel Core i7 1360P | AMD Ryzen 7 5700X PBO
Motherboard Asus ROG Strix B450-F Gaming
Cooling Corsair H105 (AM4 Retention yay!)
Memory 16GB Quad Channel LPDDR5 4800 | Crucial 64GB DDR4 Pro 3200 C16
Video Card(s) Nvidia RTX 2050 | Gigabyte Radeon RX 5700 Stock Cooler @ XT BIOS
Storage Kioxia 512GB NVMe |Crucial MX200 SSD + Samsung 980 1TB + 870QVO 1TB + 12TB HDDs
Display(s) Dell Laptop Display 1920x1200 | Dell UltraSharp U2719D
Case Fractal Design Define R4
Power Supply Corsair RM750
Mouse Logitech G403 | Logitech G Pro
Keyboard Logitech MX Keys
Benchmark Scores @_@
Thanks!
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Excellent suggestion. It has been added to the OP. :cool:
The table has been updated.
6,790 (1.34/day)
Processor 7800x3d
Case ThermalTake P3
Software Windows 11 64 Bit
Does cpu matter in the benchmarks?
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
6,871 (1.10/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Software Windows 11 Pro 64 bit
Benchmark Scores https://www.3dmark.com/spy/34962882
x64 CPU | Intel i7 2600k | 1 | 4 | 8 | 4600mhz | trial version | 24598MB/s | 23359MB/s | trial version | 145,1 GFLOPS | 144.8 GIOPS | 144.8 GIOPS | 36.25 GIOPS | Trial Version | 64.3FPS
1 GPU | Nvidia GTX780 ti | 1 | 2880 | 15 | 1274mhz | 6310 MB/s | Trial Version | 271714 MB/s | 5724 GFLOPS | 297.2 GFLOPS | 1175 GIOPS | Trial Version | 292.5GIOPS | 1025 FPS | Trial Version
6,790 (1.34/day)
Processor 7800x3d
Case ThermalTake P3
It's just for comparison purposes. It's worth comparing CPUs to CPUs imho. Comparing CPUs to GPUs isn't quite fair. :p
Why I asked was because I have my 7970 in a celeron machine for troubleshooting, but if I was going to do a benchmark I might want to put a beefier overclocked cpu in there. Or would the celeron not limit me.
Frick
Fishfaced Nincompoop
20,047 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Keyboard Dell SK3205
3,668 (0.67/day)
Portugal
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Updated. Try to stick with just the numbers, the units aren't important since the table header already has them. :cool:
1,618 (0.27/day)
a barton eh? i can test a 2.4ghz OC mobile barton on xp32
what kind of celeron, as in, what model & year/bios date of motherboard? i'm planning to go 7970/280x/290 but with a P5Q-E mobo with a bios from 2008
6,790 (1.34/day)
Processor 7800x3d
Case ThermalTake P3
Its an ivy bridge celeron g1620 2.7ghz, that I have overclocked to 2.8ghz because data loss is a non issue. Msi p67gd53 with bios from 2013.
I just decided to run the benchmark on my celeron anyways, and then on a beefier chip when I get the 7970 back where it belongs. See if there is a difference. Why not.
X64|Intel Celeron G1620|1|2|SMCU?|2800|trial|12955|12517|trial|22.07|43.95|43.95|64|11.05|trial|11.71
Gpu|Amd 7970|1|2048|SMCU?|1000|3272|trial|235123|4256|1060|4253|trial|202.7|625.2|trial
1,618 (0.27/day)
ah dang, have you tried games on it? how cpu limited does it get? mine would be a Q9550 3.6ghz OC, which i guess i'll have to post the results here as well
would have 4870x2 gpgpu results but the vram has failed
6,790 (1.34/day)
Processor 7800x3d
Case ThermalTake P3
Pm'd as to not disrupt thread more.
1,618 (0.27/day)
how much variance are you all seeing between runs?
the memory read in particular, but my test is done with no gfx driver so maybe every little UI update is taking up cpu usage
i'll put in my high numbers except the first mem read which was running while i closed the teamviewer connection, couldnt see anything close to 9500 since then so it must be a bad result
x64 CPU|Intel Core 2 Quad Q9550|1|4|4|3570|9395|8903|8761|114.2|57.09|57.09|57.09|14.27|48.92|25.82
also seems like aida's cpuid is not as good as cpuz's, it's not displaying the load clocks
EDIT: OP, i think a couple entries need to be adjusted, the gtx770 doesnt list the brand so it's not part of the sorting, the 2600k is missing 'core' so it's also not in the right spot when sorting
4,686 (0.75/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Updated with new scores.
4,686 (0.75/day)
System Name Obelisc
Cooling H110
Case T81
The number sorting seems to not recognize decimal points.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
That's because the "sort" that javascript is doing is a string sort, not a numeric sort. Unfortunately it doesn't give me the option of what kind of sort to do. Nor would it work if numerical fields have strings in them.
2,632 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01 w/Alphacool Apex RAM X4 Water Cooler and Core DDR5-RAM Module
Video Card(s) MSI Suprim SOC w/Alphacool Core Geforce RTX 5080 Suprim + Vanguard with Backplate
Storage Samsung 990 PRO 1TB M.2
Display(s) MSI 321URX
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
2GPU|nVIDIA 560Ti|2|768|16|875|9030|8326|215508|2660|223.5|893.9|893.9|222.3|504.5|62.81
