Application to test CPU
421 (0.07/day)
Thailand
Processor AMD Phenom II 720 3x2,8 GHz BE
Motherboard MSI 870A Fuzion A770 SAM3
Cooling Scythe Zipang SCZP-1000
Memory Crucial 4GB DDR3 1600MHz Ballistix Sport CL9
Video Card(s) PALIT GeForce GTX 560Ti 1GB
Storage TOSHIBA 1000GB 32MB 3,5'' 7200 SATA III
Display(s) Gateway FPD2275W `22
Case Shinobi SH09A
Power Supply Thermaltake Toughpower W0116 750W
Software Windows 7 Ultimate 64bit
I`m looking for an application to test if my CPU is working properly. Any suggestions, guys? :)
18,584 (2.64/day)
System Name AlderLake
421 (0.07/day)
Thailand
Case Shinobi SH09A
Thanks!
How can I test its general stability?
18,584 (2.64/day)
Use the FPU stress test in AIDA64.
You can also play some games.
13,844 (1.84/day)
System Name Dark Monolith
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS Strix X570-E
Case Silverstone Kublai KL-07
I prefer ASUS RealBench
http://rog.asus.com/tag/realbench/
The most real-world test plus video encoder test is using AVX which is ideal for stability testing. Plus it has an OpenCL test that stresses GPU.
95Viper
Super Moderator
13,301 (2.20/day)
If you have AMD Overdrive installed, it can test your CPU.
Quote from the tuning guide pdf:
AMD OverDrive™ utility Stability Test
The AMD OverDrive™ utility features an impressive system stability assessment. The “Stability Test” tab under “Performance Control” incorporates AMD‟s CPU test algorithms to stress the CPUs worst-case scenario. The test consists of various parts that can be set to run only on a specific CPU core or on all CPU cores. It is also possible to select only specific tests to run. The amount of time the test will run can also be adjusted with the slider.
hat
Enthusiast
21,753 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Experience tells me that no one test is the best. When I'm testing my overclock for stability, I use two different tests. I will run Prime95 Blend for 24 hours, and I will run 100 passes of LinX (all memory loaded).
Some people don't test at all, they just clock and go. If it doesn't crash while gaming or whatever, they call it good. Truth be told some problems can crop up there, but I've had unstable overclocks game fine. Some people will use testing tools, but only for a short amount of time. Me, I like to be sure it's stable, and my way of being sure is to run extensive tests and see that they come back with no errors. After that I'll begin using my rig as per usual. Even my testing isn't a guarantee, but I think it's a damn good start.
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
OCCT is one of my favorite because its covers a gamut of tests for your CPU and system. Generally my baseline stability test and it's damn good at what it does. Used it for years with excellent success in stability testing and diagnostics. Do note that if your PC is joined to a domain you'll have to buy a license...otherwise it's free.
Everyone has their own flavor of testing...I prefer OCCT and have used it on dozens of builds and deployments...systems I build and validate stability with OCCT when tuning don't come back until something fails. Granted there's more to building and tuning than a single stress test application...it's a vital step IMHO.
My final test is a 6+hr run of the PSU test. This verifies a lot about a build...power consumption, heat output and handling, voltage and system stability, noise under load, etc.
Again we all have methods and any of them are good...I'd suggest you try out what interests you most and see if it works for you or not.
There's Prime95, Asus ROG Realbench, AIDA64, Intel XTU, 3Dmark, Intel Burn Test, etc..etc..etc. Loads of good info out there and experienced members here!
:toast:
3,471 (0.61/day)
Czech republic
Processor Ryzen 5800X
Motherboard Asus TUF-Gaming B550-Plus
Memory 32GB G.Skill Trident Z Neo F4-3600C16D-32GTZNC
Video Card(s) Sapphire AMD Radeon RX 7900 XTX Nitro+
Storage HP EX950 512GB + Samsung 970 PRO 1TB
Display(s) Cooler Master GP27Q
Case Fractal Design Define R6 Black
Power Supply Seasonic PRIME Ultra 650W Gold
Mouse Roccat Kone AIMO Remastered
Prime95 above everything else, however you should add IntelBurnTest to the mix because it can catch other instabilities.
7,023 (1.31/day)
/ measuring nostalgia
Back in the day when I was into programming I usually wrote my own programs such as solving systems of linear equations with gigantic matrices of zillion elements, or plotting graphs with zillion dots, what else .. I dunno .. dividing two numbers without losing precision, multiplying two zillion digit numbers and all that fun with arbitrary-precision arithmetic and of course fractals! Man, that was amazing times indeed. That was the best way to challenge myself.
Testing my brain and fpu/alu of my computer, solving real problems and having fun instead of doing some meaningless synthetic tests.
end /
Now I don't give a banana about my cpu. But I play games to test it lol
3,471 (0.61/day)
Czech republic
That's not a reliable way to test stability in the slightest.
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
If he's only gaming and its stable in said games, then clearly that option works fine for his situation and needs. There is no one right answer here, only opinions.
3,016 (0.51/day)
vermont
System Name The wifes worst enemy
Processor i5-9600k
Motherboard Asrock z390 phantom gaming 4
Cooling water
Memory 16gb G.skill ripjaw DDR4 2400 4X4GB 15-15-15-35-2T
Video Card(s) Asrock 5600xt phantom gaming 6gb 14gb/s
Storage crucial M500 120GB SSD, Pny 256GB SSD, seagate 750GB, seagate 2TB HDD, WD blue 1TB 2.5" HDD
Display(s) 27 inch samsung @ 1080p but capable of much more ;)
Case Corsair AIR 540 Cube Mid tower
Power Supply EVGA GQ1000W MODULAR
Mouse generic for now
Keyboard generic for now
Software gotta love steam, origin etc etc
Benchmark Scores http://hwbot.org/user/philbrown_23/
there are tons of bench'es/ stability tests but the most common are:
Prime95
intel burn test
and occt
me personally I don't use occt as it seems to be the harshest of the the stability tests. and one time i had a power supply blow up from running it which was good because i found out the psu was faulty but it wasn't because i didn't have a spare lol. prime 95 or ibt are my tests of choice.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.93/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Power Supply Corsair
Mouse cheap
Keyboard under going restoration
Recently i have been using the stress test in CPUZ and monitoring it with HWmonitor
(yes, i need to clean my rad)
501 (0.14/day)
Skopje, Macedonia
System Name The Tesseract Cube
Processor AMD Ryzen 5 3600
Motherboard MSI X570A-PRO
Cooling DeepCool Maelstrom 240mm, 2 X DeepCool TF120S (radiator fans), 4 X DeepCool RF120 (case fans)
Memory 2 x 16gb Kingston HyperX 3200mhz
Video Card(s) Sapphire Radeon RX 6800 Nitro + 16GB
Storage Corsair MP400 G3 1TB, Western Digital Caviar Blue 1TB
Display(s) MSI MAG241C Full HD, 144hz FreeSync
Case DeepCool Matrexx 55
Audio Device(s) MB Integrated, Sound Blaster Play 3 (Headset)
Power Supply Corsair CX650M Modular 80+ Bronze
Mouse Corsair Dark Core Pro Wirless RGB
Keyboard MSI GK30 Mecha-Membrane
Benchmark Scores CPUZ: Single Thread - 510 Multi Thread - 4.050 Cinebench R20: CPU - 3 500 score
Basically i use aida and p95 for stress test on a cpu, but before that, i double check all the hardware, and i more or lesz know how far i can push a cpu, by the capabilities of the mobo, psu and cooler.
For oc, first of all i prepare the hardware required to do oc (good mobo, better cooler for cpu and a good psu).
An Overclocker Mobo ( P, Z or X series of sockets) is usually the first step.
Next, i use a cooler that can overpower your cpu. My gammaxx can cool cpus with 130w tdp, and my i5 is only 95w tdp, so i can oc it for sure.
Finnaly, i calculate the watts that my psu has to spare so i can make sure that my psu can hold its own if more power is drawn from it.
2,668 (0.42/day)
Earth
Thanks for the info, I never heard of it and just downloaded it. Then i ran it on my new system that i just took out of mothballz.
Still not tuned yet but i am wondering if this is a good score.....
thanks
25 (0.01/day)
Processor 4770k @ 4,4Ghz
Motherboard z87x-ud4h
Cooling custom EKWB water
Memory Corsair 8-8-8-26 1600 @ 9-10-10-28 2000Mhz 32GB
Video Card(s) MSI 980ti Gaming
Storage Samsung 850 EVOs, M4, OCZ Vector2, WD Red & Black
Display(s) Acer xb271hu & Dell u2713h
Case Define S
Audio Device(s) ASUS Zonar U5
Power Supply EVGA G2 850W
Mouse G700s
Keyboard G810
Software OSX & win10
