ASRock 970 Extreme4 problems *I think*
2,417 (0.42/day)
Whitby, Ontario
Processor AMD Ryzen 5 2600
Motherboard MSI B450 Gaming Plus
Memory GSkill 8GB Dual Channel DDR4-2800
Video Card(s) MSI GamingX RX580 4GB
Storage Kingston V300 240GB SSD + WD Green 2TB
Display(s) ACER K212HL 27" + Haier 55" + Lenovo Explorer Mixed Reality Headset
Case Enermax Ostrog (Red)
Power Supply EVGA SuperNOVA B2 750W
Software Win10 64bit
Hey people,
About a month ago I bought an ASRock 970 Extreme4 and swapped it without reinstalling the O/S. When I started the computer I immediately got a "NTLDR is missing, press any key to restart" message. So I checked to make sure in the bios that my HDD's were showing and that they were in the right priorities. Then after a few tries it finally booted. So yaa! I was happy.
Then I noticed that sometimes when I started my computer it would turn on but nothing would happen so I would have to push the power button on and off a few times and then it would boot. Also, sometimes when I restarted the computer it wouldn't restart. Again, it would turn on but then nothing. So again I would have to push the power button a few times and it would boot.
This would happen when running stock and O/Ced. Once the computer was running it was fine. No crashes whatsoever. I figured it was just because I hadn't reinstalled my O/S.
So a few days ago I got around to doing that and the problem still persists. Is it the mobo? Or could it be something else?
95Viper
Super Moderator
12,720 (2.24/day)
Sounds like you got some file corruption, maybe.
Hopefully your drives are healthy.
For a start... try this post and knowledge base article to see if they may help.
How to use the Bootrec.exe tool in the Windows Recovery Environment to troubleshoot and repair startup issues in Windows
Ntdlr is Missing Press any key to restart
If, you replaced the MB with one of a different chipset/design... You, possibly, may be better off re-installing your OS and Apps, as some of the required files for that setup may not be updated/installed properly or at all.
2,417 (0.42/day)
Whitby, Ontario
I guess I didn't make it clear enough from my op.
I just reinstalled my OS and sometimes it still won't boot. I mean the computer turns on but it won't even get to the bios screen. So I have to turn it on and off a few times for it to start.
9,808 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
what about the bios, could be from that so whatever setting that you made it aint saved
1,364 (0.26/day)
TX
System Name Beast
Processor Core i7 10700K 4.5GHZ 24/7
Motherboard MSI MPG Z490 Gaming Plus
Cooling Master Liquid 240
Memory 32 gigs DDR4 3600Mhz Gskill RipJaws
Video Card(s) AMD Raedon 5700XT
Storage 1TB Samsung NVME, Western Digital 4TB storage
Display(s) Dell UltraSharp 34" HD
Case Cooler Master HAF XB EVO
Power Supply EVGA 1000 Watt full modular
Software Win10 ENT 64Bit
Latest bios?
Norton
Moderator - Returning from the Darkness
14,108 (3.12/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Is your boot drive in the lowest possible SATA channel (0 or 1)? I had similar problems on my 790GX board until I realized I had plugged the SATA drive into the last channel instead of the 1st.... read the port order backwards when I checked it in the manual:rolleyes:
2,417 (0.42/day)
Whitby, Ontario
It happens even at default settings.
Latest bios?
Ya, I keep checking for the latest bios updates but so far it hasn't helped
I am using 1,2 and 3 channels. I am afriad to change in case I get the "NTLDR is missing, press any key to restart" message again.
826 (0.13/day)
first 3 sata ports? so 0 1 and 2 is that two hard discs and one optical drive?
if you do not have raid setup and two harddiscs you must ensure that the bios is set to boot from the disc that contains the os otherwise you will get a "file missing" error it is possible every time you flash/stock your bios, change the sata plugs you are reseting/changing the boot priority/device and causing the system not to start, otherwise if you are oc`d check your RAM because 9 times outa 10...
2,417 (0.42/day)
Whitby, Ontario
I thought the problem had gone away but it happened again today. I sent them an e-mail about it a few days ago. They still haven't replied....:ohwell:
