ATi 2900XT Driver problem need help ASAP
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Update!
I bought an HD3450 which is utter crap but anyhow it works fine, not a single artifact.
So it seems like my 2900XT was dieing. As of now I'll pronounce him dead.
GPU Died: 5th July 2008, 10:38AM
Soooo any suggestions for a top notch ATi card?
Also if possible suggestion for a new PCI-E 2.0 mobo as the one I'm on is 1.0a so yeah.
Thanks in advanced guys and thanks for helping me find the problem!
i have a 3450 in my media PC (asus 512MB passive cooled model)
PCI-E 1.0 and 2.0 dont really mean anything at this point in time, as they're both compatible.
kebabs
125 (0.02/day)
Processor Kentsfield Q6600 @ 3.5Ghz
Motherboard Asus P5W DH Deluxe Wifi
Cooling Zalman 9700
Memory 2x 1gb's DDR2 PC2-6400 Dual Channel
Video Card(s) ATI HD 4870 512MB
Storage 2x 320GB
Display(s) SyncMaster940N 19" + Phillips dunno the model but it's a 17"
Case CM Stacker 832
Audio Device(s) Soundblaster Audigy 2
Power Supply 1010W OCZ Game X Stream
Software Windows Vista Ulimate
So there isn't much of a performance hit?
336 (0.06/day)
System Name Roxy
Processor i7 5930K @ 4.5GHz (167x27 1.35V)
Motherboard X99-A/USB3.1
Cooling Barrow Infinity Mirror, EK 45x420mm, EK X-Res w 10W DDC
Memory 2x16GB Patriot Viper 3600 @3333 16-20-20-38
Video Card(s) XFX 5700 XT Thicc III Ultra
Storage Sabrent Rocket 2TB, 4TB WD Mechanical
Display(s) Acer XZ321Q (144Mhz Freesync Curved 32" 1080p)
Case Modded Cosmos-S Red, Tempered Glass Window, Full Frontal Mesh, Black interior
Power Supply Corsair RM 850x White
Mouse Logitech G403
Keyboard CM Storm QuickFire TK
Benchmark Scores https://valid.x86.fr/e5uz5f
New card depends on your budget:
<£100 - 3870
£100 - £150 - 2x3850 or 4850
£150 - £200 - 3870x2 or 4870
£200 - £300 - 2x4850
£300 - £500 - 2x4870, 2x 3870x2, 3 or 4x4850
£500 - £1000 - 3 or 4 4870
As for boards, Asus P5E/P5E3/Maximus/Rampage for Intel CPUs or MSI K9A2 or ASUS M3A range for AMDs.
For 4000 series cards PCI-E 2.0 does make a difference especially in CF
2,367 (0.38/day)
Nova Scotia, Canada
System Name Main rig
Processor AMD Ryzen 5800X
Motherboard Asus Strix X570-E Motherboard
Cooling Castle 240EX v2 AIO
Memory 2x16GB GSkill Trident Z RGB 3600MHz CL16
Storage 2x1TB M.2 - 3TB Spinny Boi
Display(s) Alienware AW3423DWF
Case Lian Li 011 Air Mini
Audio Device(s) UAD Apollo
Power Supply Thermaltake GF1 ARGB 850W
Mouse Steelseries Aerox 5 Wireless
Keyboard Steelseries Apex 7 TKL blue switches
VR HMD Quest 3
Go with a 4850, or a 3870. I went from a 2900XT to a 4850, and wow. This card is easily twice as fast as my old 2900XT, very impressed for $200:)
Edit: I'm on PCI-e 1.0, and it runs fine.
kebabs
125 (0.02/day)
Cooling Zalman 9700
Storage 2x 320GB
Case CM Stacker 832
Cheers, thanks!
kebabs
125 (0.02/day)
Cooling Zalman 9700
Storage 2x 320GB
Case CM Stacker 832
Just a quick update, I ordered and received an HD4870 which works perfectly :D and I'm also awaiting the replacement of my 2900XT. Thanks for your help guys :)
833 (0.13/day)
UK, Brighton
Processor 9900k @ stock (direct die)
Motherboard Aorus Master z390.
Cooling Dual Loop, Custom
Memory 16GB Corsair RGB Pro
Video Card(s) MSI RTX 2080Ti SEAHAWK EK X
Storage Samsung 960 512, Samsung 860 2TB, Sabrent Rocket 1TB
Display(s) Asus MG278Q/Acer XB270HA
Case MM U2-UFO Extended CYO
Audio Device(s) Asus Xonar Xense & AKG K550 Headphones
Power Supply Corsair HX1000i
Mouse Corsair M65 RGB Elite
Keyboard Corsair K70 mk.2 Silent
Software Win 10 Pro X64
kebabs!
exactly the same happened to me!!!. thats why i got replacement 4870's
GPU Died 29 June 2008, 06:55am :(
he will be missed dearly!
R.I.P My friend
Mussels
58,413 (8.18/day)
Oystralia
so 4870's are randomly dying? odd.
833 (0.13/day)
UK, Brighton
no 2900xt's are randomly dying m8
4870's wont die, they rock :rockout:
