ATI Radeon X1600Pro 512 AGP Driver or Problem Elsewhere?
JimBeamNC
6 (0.00/day)
Hey does anyone know a good driver out there that will help boost my fps or some stable settings to tweak it to for a game like Americas Army. I just bought this today and from what I see I only get like 20FPS in action, not what I was looking for!!! I thought it should be I would think about 60FPS or so. So anyone out there that thinks they got a idea of what could be the problem help me out please!! Right now im running the XTreme-G WarCat Driver.
My system specs are as follows:
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: Sony Corporation
System Model: PCV-RS430G(UC)
BIOS: BIOS Date: 10/29/04 13:42:25 Ver: 08.00.08
Processor: Intel(R) Pentium(R) 4 CPU 2.80GHz (2 CPUs)
Memory: 2048MB RAM
Page File: 450MB used, 3492MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Manufacturer: ATI Technologies Inc.
Chip type: Radeon X1600 Series AGP (0x71C2)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_71C2&SUBSYS_030B1002&REV_00
Display Memory: 512.0 MB
Current Mode: 1024 x 768 (32 bit) (75Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6652 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/21/2006 19:25:22, 261120 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 8/4/2004 01:29:26, 701440 bytes
Device Identifier: {D7B71EE2-3282-11CF-4E6A-0123A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x71C2
SubSys ID: 0x030B1002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
652 (0.10/day)
Germany
Processor AMD Phenom II X2 550 @3600MHz (VCore -0.05V)
Motherboard Gigabyte MA-780G-DS3H (AMD SB700), BIOS: 04/14/09
Cooling Scythe Samurai cooled by 2x Enermax Warp 80mm ~700 RPM
Memory 2x 1GB GeIL Ultra DDR2-800 @1066 CL4-5-5-15 2T
Video Card(s) MSI R4830 OC (HD4830)
Storage Samsung 400 GB S-ATA, WD 400GB S-ATA
Display(s) Samsung 2433BW 1920 x 1200 Pixel (16:10)
Case timeless office tower ;)
Audio Device(s) Asus Xonar D1
Power Supply be quiet! Straight Power BQT E7-400W
Software Windows XP Pro 32bit
I´ll make a start, the real experts will slip in later. :)
Does this fit to the specs of your card stock speeds?
http://www.techpowerup.com/gpudb/details.php?id=171
You can read the speeds with ATi Tool, Everest etc.:
http://www.techpowerup.com/downloads/Tweaking/ATITool
http://www.techpowerup.com/downloads/84
You shall not expect too much with this card.
For example: Though it has 512MB RAM it has only 4 Render Output Units (ROPs).
As you can see here http://www.techpowerup.com/gpudb/ it´s not that much.
The size of video memory is NOT making a card a big deal automatically.
There are much more (important) criteria.
BUT: Regardless of any overclocking options you should give it try by playing the game
@ resolution 1024 x 768, 1024 x 600 (depends on 4:3 or another aspect ratio).
Lower your detail settings.
More coming soon, I guess.
JimBeamNC
6 (0.00/day)
Mine is a AGP model does whats the specs on that as far as core and mem
4,899 (0.76/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
The AGP version usually have the same clocks as PCI-E.
And X1600Pro is usually DDR2 memory.
6,959 (1.08/day)
Australia, Sydney
...I have to say, don't take this personally but, the X1600PRO Sucks like shit. 512MB; I don't even know why manufactures have to add more memory buffer which does nothing.
652 (0.10/day)
Germany
1.) The myth keeps selling and selling and selling...
2.) Look at the system requirements for games as they are written by, I think, ALL game manufactors.
What do you read there? Right, memory size, memory size :cool:
Mussels
Freshwater Moderator
58,413 (8.16/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
X1600 - not a bad card.
DO not enable AA (anti aliasing) and dont use AF (anisotropic filtering) above 4x.
In games, disable shadows - thats the largest speed killer.
Cant help you much else until you mention what games your speed issues are in and what resolution/settings you play with.
4,899 (0.76/day)
Hong Kong
Actually the X1600Pro is not too bad when OCed. (I have one sitting right next to me lol)
You can play BF2142 at 2xAA and 4xAF at 1024*768
I bet that looks better than 7300GT...
WarEagleAU
Bird of Prey
10,812 (1.66/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Oc it. I think that has the 128 bit ring bus too. Get a decent Aftermarket cooler and oc the heck out of it. Maybe a voltmod if possible. Turn settings down low and all that and it should be playable. Hope that helps
JimBeamNC
6 (0.00/day)
The game im playing is Americas Army mussles. I have tried to go to my bios and find my ram settings so i can take it off of auto but in the bios it has no such setting why is that?
Mussels
58,413 (8.16/day)
Oystralia
not all bioses have that jim beam, and that wont affect speed in gaming much anyway.
Honestly, overclocking will get you some more power, but the largest speed increase will come from turning in game settings down lower.
652 (0.10/day)
Germany
Can you post a digicam shot of the BIOS enter screen
plus screenshots of your graphics settings in America´s Army?
BlackDemon
6 (0.00/day)
Mobile,AL
Processor AMD Athlon64 3200+ (ClawHammer)
Motherboard ABIT KV8 Pro
Cooling Thermaltake Extreme Volcano
Memory 2 Gigs G-Skill NS (3200) 2.5-3-3-6 (2.8 volts)
Video Card(s) ATI HD 2600 XT 512 AGP
Storage Seagate Barracuda 80GB 7200rpm 8mb cache
Display(s) Samsung SyncMaster 997DF
Audio Device(s) Audigy 2 ZS Gamer
Power Supply Ultra 500 watt
Well just my 2 cents worth, I have 2 X1600 512 Pro's and I had an X1600XT. I know these cards won't win any benchmarks, But you should be able to play better than that. They put up a pretty damn good fight against my 6800 GT OC in most games, except for (OpenGL).
If I were you I would look to another problem other than just the card itself. Maybe you need to do a little OS tweaking. Or when in doubt REFORMAT:laugh:
