- Mar 9, 2009
- 471 (0.09/day)
System Name | AMD Black Dragon |
Processor | AMD Phenom II X4 940 Black Edition |
Motherboard | Gigabyte MA790X-UD4P |
Cooling | Cooler Master Hyper 212+ |
Memory | 4GB OCZ PC2-6400 Platinum (2x2GB) |
Video Card(s) | ATi Radeon HD4870 512MB GDDR5 w AC Twin Turbo |
Storage | Crucial C300 64GB SSD, 500GB and 2TB Drives |
Display(s) | Samsung 2494hm, Dell (Samsung?) 1907FP |
Case | Lancool (Lian-Li on a budget) K7 |
Audio Device(s) | Onboard Realtek ALC889A, M-Audio Fast Tracks |
Power Supply | OCZ Mod-X-Stream Pro 600W |
Software | Windows 7 Home Premium x64, XP Pro |
Yeah so I picked up a 4870 the other day but the thing is WAY too loud. Its ridiculously loud I don't know how Palit could even consider this acceptable. I can hear the damn thing from 3 rooms away! It has 2 fans on the card and for whatever sense this makes only 1 of the 2 fans is on the fan controller. So even if you turn the fan speed down to %20 the one fan still goes full bore! I considered unhooking the constant fan and just running the 1 variable fan but fear the heatsink design may have been built with two fans in mind and I don't want to overheat the card. The consistent fan is positioned over the voltage regulators also. I think one central fan would be better than just running one off to one side. I must say from what I've heard about 4870's this one does run cool so I'll give it that.
So basically I don't need something that's going to cool better just quieter because this one already does a great job with the cooling. I'm not overclocking I just want something that is acceptable. Put into perspective this card is 4 times louder than my reference 9600GT witch was nearly silent actually.
Thanks,
Jake
Thanks,
Jake
